So i got a few other issues out the way and im moving on to the next. I want to use one of the float switchs to shut off my ato pump when its low. i tried to use the code below i took from another topic with no luck. Ideas?
if(ReefAngel.HighATO.IsActive())
ReefAngel.Relay.Override(Port8, 0);
ReefAngel.Relay.On(Port8);
Float to cut off ato pump when low
Re: Float to cut off ato pump when low
Did you try flipping the switch? It should work. Post your full code.
When i change terminals neither switch works
ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port5Bit | Port8Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.CustomLabels[0]="RETURN";
ReefAngel.CustomLabels[1]="HEATER";
ReefAngel.CustomLabels[2]="SKIMMER";
ReefAngel.CustomLabels[3]="WP 10";
ReefAngel.CustomLabels[4]="ACTINICS";
ReefAngel.CustomLabels[5]="DAY LIGHTS";
ReefAngel.CustomLabels[6]="FAN";
ReefAngel.CustomLabels[7]="ATO";
ReefAngel.CustomLabels[8]="UV";
ReefAngel.CustomLabels[9]="DP-4";
ReefAngel.CustomLabels[10]="FUGE LIGHT";
ReefAngel.CustomLabels[11]= "LEDS";
ReefAngel.CustomLabels[12]="UNUSED";
ReefAngel.CustomLabels[13]="UNUSED";
ReefAngel.CustomLabels[14]="GYRE";
ReefAngel.CustomLabels[15]="Reactor";
ReefAngel.StandardHeater( Port2,770,790 );
ReefAngel.Relay.DelayedOn( Port3,10 );
ReefAngel.StandardLights( Port5,10,0,21,0 );
ReefAngel.StandardLights( Port6,12,0,19,30 );
ReefAngel.StandardFan( Port7,790,800 );
ReefAngel.SingleATO( true,Port8,1440,0 );
ReefAngel.StandardLights( Box1_Port4,9,0,23,0 );
ReefAngel.StandardLights( Box1_Port8,6,0,22,0 );
if (hour()>=10 && hour()<19) ReefAngel.Relay.Off(Box1_Port4);
No i meant if you manually trip the switch
And the same results apply. Don't work. I changed high n low as well. Didn't respond as intended.
Do you see the switch change in portal or app or of you having it display on the screen?
The next steps if you cofirm the switch is registering as intended then you need some debug code to see why your not getting into that if statement and monitor in serial monitor
