Auto Water Change Code
Re: Auto Water Change Code
Try this. It will wait for a joystick up movement before moving to the fill stage
byte wc_status = 0;
ReefAngel.AddMultiChannelWaterLevelExpansion(); // Multi-Channel Water Level Expanion Module
ReefAngel.FeedingModePorts = Port2Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.CustomLabels[0]="LEDs";
ReefAngel.CustomLabels[2]="SumpToFishQT";
ReefAngel.CustomLabels[3]="SumpDrain";
ReefAngel.CustomLabels[4]="Wave R";
ReefAngel.CustomLabels[5]="Wave L";
ReefAngel.CustomLabels[6]="Heaters";
ReefAngel.CustomLabels[7]="Constant";
ReefAngel.CustomLabels[8]="SumpATO";
ReefAngel.CustomLabels[9]="FishQTATO";
ReefAngel.CustomLabels[10]="FishQTDrain";
ReefAngel.CustomLabels[11]="SaltToSump";
ReefAngel.StandardLights( Port1,16,0,22,0 );
ReefAngel.Relay.DelayedOn( Port2,5 );
ReefAngel.WavemakerRandom( Port5,60,100 );
ReefAngel.WavemakerRandom( Port6,60,100 );
//ReefAngel.Relay.Set( Port6, !ReefAngel.Relay.Status( Port5 ) );
ReefAngel.StandardHeater( Port7,775,785 );
ReefAngel.PWM.SetChannel( 3, PWMParabola(16,0,22,0,10,50,10) );
ReefAngel.PWM.SetChannel( 4, PWMParabola(16,0,22,0,10,50,10) );
ReefAngel.PWM.SetChannel( 5, PWMParabola(16,0,22,0,10,50,10) );
//ATO For Main Sump
if (hour()==19 && minute()==0) //Only run ATO between 7:00pm and 7:01pm daily
if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE) ReefAngel.Relay.Off(Box1_Port1); //don't run ATO during a water change
if (ReefAngel.WaterLevel.GetLevel(1)<=70 && ReefAngel.DisplayedMenu != WATERCHANGE_MODE) ReefAngel.Relay.On(Box1_Port1);
if (ReefAngel.WaterLevel.GetLevel(1)>=80) ReefAngel.Relay.Off(Box1_Port1);
//ATO For Fish QT
if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE) ReefAngel.Relay.Off(Box1_Port2); //don't run ATO during a water change
if (ReefAngel.WaterLevel.GetLevel(3)<=80 && ReefAngel.DisplayedMenu != WATERCHANGE_MODE) ReefAngel.Relay.On(Box1_Port2);
if (ReefAngel.WaterLevel.GetLevel(3)>=90) ReefAngel.Relay.Off(Box1_Port2);
// Emergency Sump Low Check
if ( ReefAngel.WaterLevel.GetLevel(1) <= 20 && ReefAngel.DisplayedMenu!=WATERCHANGE_MODE && millis() > 5000)
ReefAngel.Relay.Off(Port8); //Turn off return pumps
//Water Change Process
if(ReefAngel.DisplayedMenu!=WATERCHANGE_MODE && wc_status != 0) wc_status = 0;
//0 - Top Off Sump
if(ReefAngel.DisplayedMenu==WATERCHANGE_MODE && wc_status == 0)
if( ReefAngel.WaterLevel.GetLevel(1)<80) ReefAngel.Relay.On(Box1_Port1);
if( ReefAngel.WaterLevel.GetLevel(1)>=80) ReefAngel.Relay.Off(Box1_Port1);
if( ReefAngel.WaterLevel.GetLevel(1)>=80) wc_status = 1;
//1 - Top Off FishQT
if(ReefAngel.DisplayedMenu==WATERCHANGE_MODE && wc_status == 1)
if( ReefAngel.WaterLevel.GetLevel(3)<90) ReefAngel.Relay.On(Box1_Port2);
if( ReefAngel.WaterLevel.GetLevel(3)>=90) ReefAngel.Relay.Off(Box1_Port2);
if( ReefAngel.WaterLevel.GetLevel(3)>=90) wc_status = 2;
//2 - Drain FishQT Tank
if(ReefAngel.DisplayedMenu==WATERCHANGE_MODE && wc_status == 2)
if( ReefAngel.WaterLevel.GetLevel(3)>85) ReefAngel.Relay.On(Box1_Port3);
if( ReefAngel.WaterLevel.GetLevel(3)<=85) ReefAngel.Relay.Off(Box1_Port3);
if( ReefAngel.WaterLevel.GetLevel(3)<=85) wc_status = 3;
//3 - Fill FishQT From Sump
if(ReefAngel.DisplayedMenu==WATERCHANGE_MODE && wc_status == 3)
if( ReefAngel.WaterLevel.GetLevel(3)<90) ReefAngel.Relay.On(Port3);
if( ReefAngel.WaterLevel.GetLevel(3)>=90) ReefAngel.Relay.Off(Port3);
if( ReefAngel.WaterLevel.GetLevel(3)>=90) wc_status = 4;
//4 - Drain Sump To Floor Drain
if(ReefAngel.DisplayedMenu==WATERCHANGE_MODE && wc_status == 4)
if( ReefAngel.WaterLevel.GetLevel(2)>75) ReefAngel.Relay.On(Port4);
if( ReefAngel.WaterLevel.GetLevel(2)<=75) ReefAngel.Relay.Off(Port4);
if( ReefAngel.WaterLevel.GetLevel(2)<=75) wc_status = 5;
//5 - Wait for Joystick Move
if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE && wc_status == 5)
 if (ReefAngel.Joystick.IsUp()) wc_status=6;
//6 - Fill Sump With Fresh Saltwater
if(ReefAngel.DisplayedMenu==WATERCHANGE_MODE && wc_status == 6)
if( ReefAngel.WaterLevel.GetLevel(2)<80) ReefAngel.Relay.On(Box1_Port3);
if( ReefAngel.WaterLevel.GetLevel(2)>=80 && ReefAngel.WaterLevel.GetLevel(1)>=80) ReefAngel.Relay.Off(Box1_Port3);
if( ReefAngel.WaterLevel.GetLevel(2)>=80 && ReefAngel.WaterLevel.GetLevel(1)>=80) ButtonPress++;
//Water Change Complete
