calibration with 4.0 and 7.0 pH solutions
marcoc
Post by marcoc »
Hi everybody,
is there a way to change the calibration points (buffer solutions) used for the pH sensors from 7.0 and 10.0 to 4.0 and 7.0?
Can these values be selected within the calibration mode?
Thank you.
Cheers,
Marco
Re: calibration with 4.0 and 7.0 pH solutions
Yes there is a way, but I don't have the answer at hand. Roberto should be able to direct you later today.
The current libraries allow you to do that without any modifications.
Simply scroll through and you will be able to change the pH values of choice.
