Hi all
Wondering if there is a way to set a port so it will activate according to lights. So when a certain channel is above 0 a certain port is activated.
Port switch on 0 dimming
tyson_mitchell_88
Last edited by tyson_mitchell_88 on Mon Jan 25, 2016 11:08 am, edited 1 time in total.
Re: Port control
Do you mean a dimming channel?
If so, something like this:
Or a simplified version:
If not the actinic channel, change it to GetDaylightValue() for daylight or GetChannelValue(0) for channel 0 of dimming expansion module.
if (ReefAngel.PWM.GetActinicValue()>0)
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
ReefAngel.Relay.Set(Port1,ReefAngel.PWM.GetActinicValue()>0);
tyson_mitchell_88
tyson_mitchell_88
Re: Port control
Worked well thanks Roberto.
How would I set up a port so it's usually off, though if I manually activate it, through portal or app, it works to ATOHigh.
Re: Port control
What do you mean ATOHigh.
That code has nothing to do with ATOHigh.
It will be off when Actinic channel is 0 and on for anything greater than 0. That's that the request was for.
Not sure what you mean as usually off.
tyson_mitchell_88
Re: Port control
This is for another job on another port mate. Trying to set up some manual water change.
tyson_mitchell_88
