#define NUMBERS_8x16
ReefAngel.LCD.DrawText(COLOR_INDIGO, COLOR_WHITE,25,5, "Jeremy's Reef");
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit;
InternalMemory.OverheatTemp_write( 790 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.DosingPumpRepeat1( Port1);
ReefAngel.DosingPumpRepeat2( Port2);
ReefAngel.StandardATO( Port3,30 );
ReefAngel.StandardHeater( Port7);
ReefAngel.PWM.Channel0PWMSlope();
ReefAngel.PWM.Channel1PWMSlope(-5,5);
ReefAngel.PWM.Channel2PWMSlope(-10,10);
ReefAngel.PWM.Channel3PWMSlope(-15,15);
ReefAngel.PWM.Channel4PWMSlope(-20,20);
ReefAngel.PWM.Channel5PWMSlope(-25,25);
if (ReefAngel.DCPump.Mode==Custom)
ReefAngel.PWM.SetDaylight( ElseMode(70,30,true )); // ElseMode on sync mode, 70 +/- 30%
ReefAngel.PWM.SetActinic( ElseMode(70,30,false ));
ReefAngel.Portal( "jjdezek" );
void DrawParamsa(int x, int y){
char buf[16];
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,x+70,y+10,"WP40L:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+108, y+10,1);
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+70,y+20,"WP40R:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),APColor, x+108, y+20,1);
char buf[16];
// Temp and PH
y+=10;
ReefAngel.LCD.DrawLargeText(T2TempColor, DefaultBGColor, x+5, y+12, buf, Num8x16);
ReefAngel.LCD.DrawLargeText(T3TempColor, DefaultBGColor, x+40, y+12, buf, Num8x16);
y+=5;
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,10,18, "SAL:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.Salinity,COLOR_DARKKHAKI,33,18, 10 );
int t=x;
