It has nothing to do with the timeout memory location. As long as you don't exceed 69 seconds it won't be a problem. If you want to incorporate the memory info, you can replace the 70 with the following
Sweat thanks as always lee. If I write a line like the overheat turn off port code with ato time out would that work? Cus when the float gets toggled again it cycles even tho ato time out flag is on
lnevo wrote:It has nothing to do with the timeout memory location. As long as you don't exceed 69 seconds it won't be a problem. If you want to incorporate the memory info, you can replace the 70 with the following
The true is used if it's for ATOLow, the port obviously, the timeout, and then the 6 represents how many hours apart since the last top off. That should be much easier to use
Ok that is for every 6 hours ato Will cycle one time if float is in need of top off till next 6th hour?
Does it as well do the ato time out and stop it from cycling again till ato time out is cleared?(cus I am having issue with time out when it time out it will stop and flag then next time float toggles it will cycle again even when time out is flagged)
I think it works perfectly. The other one didn't work cus during the timer hold it didn't hold the ato timeout and would not work after the time out cus the code still thought it was running when the time out stoped it and never got to cycle after timed out. But this new one seems to be perfect.
Roberto i confirmed already after going on a wild goose chase after updating the wrong controller. It should be without the High and I did misspell Angel
lnevo wrote:Roberto i confirmed already after going on a wild goose chase after updating the wrong controller. It should be without the High and I did misspell Angel
O I thought that but it was working fine at current setting so wasn't adjustin it but I figured that's what it was and updated code to correct it and still good lol some good to go. TanKS a mil as always Nevo
been trying to find out y mt ato times out even when increasing the time but i just relized the ato cycle is atoextendedtimeout should that be like that or just atotimeout or do i just need to adjust both if the atoextendedtimeout need to be higher the the atotimeout?
Should be atoextendedtimeout but I've been having a lot of problems with timeout. It ALWAYS timed out after 2 minutes then I clear it and it runs for the rest of the time. My timeout is an hour. I think something is wrong with timeout code honestly.
Makes sense. Mine is glitchie sometimes too. be fine then have to reset ato once then good sometimes gotta reset it multiple times o well I always get a email so not like ill for get with 1hr reminder lol
