How do I write for ato timer?
Re: How do I write for ato timer?
lnevo wrote:I made a mistake. Used the wrong memory location.
InternalMemory.ATOHighExtendedTimeout_read()
it should be
InternalMemory.ATOExtendedTimeout_read()
I'll have to look more into this to confirm.
Roberto i confirmed already after going on a wild goose chase after updating the wrong controller. It should be without the High and I did misspell Angel
troylong45
Post by troylong45 »
seems to work just fine today
lnevo wrote:Roberto i confirmed already after going on a wild goose chase after updating the wrong controller. It should be without the High and I did misspell Angel
Can you send a patch?
No libraries are fine. It was me giving the wrong code
troylong45
I updated the code and removed the high line I don't see a effect but it is working so fine with me
The effect is that now if you change the timeout in the portal it should adjust accordingly.
troylong45
O I thought that but it was working fine at current setting so wasn't adjustin it but I figured that's what it was and updated code to correct it and still good lol some good to go. TanKS a mil as always Nevo
troylong45
been trying to find out y mt ato times out even when increasing the time but i just relized the ato cycle is atoextendedtimeout should that be like that or just atotimeout or do i just need to adjust both if the atoextendedtimeout need to be higher the the atotimeout?
Should be atoextendedtimeout but I've been having a lot of problems with timeout. It ALWAYS timed out after 2 minutes then I clear it and it runs for the rest of the time. My timeout is an hour. I think something is wrong with timeout code honestly.
troylong45
Makes sense. Mine is glitchie sometimes too. be fine then have to reset ato once then good sometimes gotta reset it multiple times o well I always get a email so not like ill for get with 1hr reminder lol
