AWC Code
Re: AWC Code
I finally got my pump and plumbing hooked up for my AWC last night. I put a bucket at the discharge tubing end to see if it was actually pumping water from the sump. I got home from work today to find that there was no water in the bucket when there should have been about a gallon. I checked the portal to see if that port turned on but it hadn't all day. Not sure if something is wrong with by code or not. Here is my most recent one.
#include <Tide.h>
Tide tide;
ReefAngel.DDNS("Damien");
ReefAngel.AddMultiChannelWaterLevelExpansion(); // Multi-Channel Water Level Expanion Module
ReefAngel.FeedingModePorts = Port1Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port5Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit;
ReefAngel.Relay.Set(Port8, now()%6*SECS_PER_HOUR<30*SECS_PER_MIN);
InternalMemory.WaterLevelMax_write(1800);
tide.Init(55,10,30);
tide.SetWaveLength(12+SECS_PER_HOUR);
ReefAngel.StandardHeater( Port3,780,785 );
ReefAngel.WaterLevelATO(4,Port4,240,28,31);
if (ReefAngel.WaterLevel.GetLevel(1)<5) //Disable the port until overriden manually
ReefAngel.Relay.Override(Port8,0); //Saltwater Reservoir
if (ReefAngel.WaterLevel.GetLevel(1)>80) // Set port back to auto
ReefAngel.Relay.Override(Port8,2);
if (ReefAngel.WaterLevel.GetLevel(2)>80) //Overflow
ReefAngel.Relay.Off(Port1);
ReefAngel.Relay.On(Port1);
if (ReefAngel.WaterLevel.GetLevel(3)>87) //ATO Reservoir
ReefAngel.Relay.Off(Port5);
if (ReefAngel.WaterLevel.GetLevel(3)<1)
ReefAngel.Relay.On(Port5);
ReefAngel.Portal( "Ismaclst" );
byte setMaxspect(byte minSpeed, byte maxSpeed, boolean PulseSync)
int reverse_speed=0;
int forward_speed=45;
// swap between forward and reverse every X seconds
reverse_speed = ShortPulseMode(0,100,ReefAngel.DCPump.Duration*2,true);
if (reverse_speed == 100) {
// while we are going in reverse increase the speed by 10
forward_speed = ShortPulseMode(35+10, 60+10,ReefAngel.DCPump.Duration,true);
// while we are going forward set speed to 25-40 to keep
// from blowing corals off the rocks
forward_speed = ShortPulseMode(35,70, ReefAngel.DCPump.Duration, true);
if (PulseSync) {
return forward_speed;
return reverse_speed;
Re: AWC Code
I'm using port 8 for the AWC pump.
Re: AWC Code
Why would you expect water in the bucket?
There is nothing that triggers anything in your code.
What is your trigger?
Re: AWC Code
I thought this triggered port 8?
Re: AWC Code
I put that line in the void setup but should it go in the void loop instead?
Re: AWC Code
Sorry. Didn't see that because it was in the wrong section.
setup() only runs at the initialization of the controller.
It should be in the loop() section.
Re: AWC Code
Thanks, hopefully that fixes it.
Re: AWC Code
I think something is wrong with that line of code. I needed it to run for 30 minutes every 6 hours. Right now its turning off and on about every 6 seconds.
Re: AWC Code
I think you need to some parenthesis to isolate the math.
You have to think it just like you would interpret it. If you have doubts, so does the controller.
So, now()%6*SECS_PER_HOUR<30*SECS_PER_MIN would be read like this:
now() modulo 6 * 3600 < 30 * 60
the first calculation is now() modulo 6. The result is multiplied by 3600. The result is checked if it is less than 30 and then the result is multiplied by 60.
Definitely not what you want.
Just like regular math, parenthesis is very important.
You math should be:
(now()%(6*SECS_PER_HOUR))<(30*SECS_PER_MIN)
You math should be:
Re: AWC Code
Thanks, Roberto. I have a hard time understanding the code.
Re: AWC Code
Sorry to keep asking questions but when I went to verify the new code it had some errors. Not sure if I missed something or what.
#include <Tide.h>
Tide tide;
ReefAngel.Relay.Set(Port8, (now()%(6*SECS_PER_HOUR))<(30*SECS_PER_MIN);
if (PulseSync) {
Re: AWC Code
Copy and paste in place of the other one. You are missing one parenthesis.
It's just like when you did math in high school. One opening parenthesis needs to have its corresponding closing parenthesis to complete the formula.
Re: AWC Code
Ok, I see. I forgot the second parenthesis at the end.
