When I added this part to my code I had a few errors. It said lowLevel, level and VO_RefillATO was not declared in the scope.lnevo wrote:I believe you have to turn this port back to auto otherwise you've triggered refill mode and it will stay on until the level is reached.Code: Select all
if (level<lowLevel) { ReefAngel.Relay.Override(VO_RefillATO,1); // We turn on the refill port. }
I think it might be worth a checkpoint to post your full code.
RO/DI valve
Re: RO/DI valve
Re: RO/DI valve
That makes no sense because that code is not in the post from 3/14 that I used...
Re: RO/DI valve
Oh, sorry. I thought you wanted me to add both of them to my code. Sorry about that.
Re: RO/DI valve
Ok, it seems to be working fine now. Thanks for your help!
