ATO Reservoir refill every few days
PostPosted: Mon Jul 10, 2017 3:03 pm
Here they are:
CMD
get w
SSID=Fish
Chan=0
ExtAnt=0
Join=1
Auth=WPA2
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
Passphrase=FishfisH
EAP_Id=userid
EAP_User=peap-user
<4.00>
get i
IF=UP
DHCP=ON
IP=192.168.1.200:2000
NM=255.255.255.0
GW=192.168.1.1
HOST=104.36.18.155:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
<4.00>
PostPosted: Mon Jul 10, 2017 10:36 pm
Looks correct.
Are you sure your code has the correct forum username?
PostPosted: Tue Jul 11, 2017 6:39 am
It is. Does the forum name matter for the rest of the web portal? I am able to see all the items. I can control the relays and get updates on my parameters. The only 2 things I can't get are the relay activity and the web chart.
The Relay Activity says no data and the web chart is just blank..
Here's the code, is there a problem with it somewhere maybe?
    ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.FeedingModePortsE[0] = Port3Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port3Bit;
    ReefAngel.LightsOnPortsE[0] = Port1Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.Relay.On( Port3 ); //Sump Powerhead. Main Relay Port 3
    ReefAngel.Relay.On( Port4 );//Display Lights
    ReefAngel.Relay.On( Port5 ); //Display Tank Power Heads MaiRelay Port 5
    ReefAngel.Relay.On( Port8 ); //Return Pump Relay 1 Port 8
    ReefAngel.Relay.On( Box1_Port1 ); //ATS Air Pump. Relay 2 Port 1
    ReefAngel.Relay.On( Box1_Port2 ); //Media Reactor. Relay 2 Port 2
    ReefAngel.Relay.On( Box1_Port3 ); //Aqualifter. Relay 2 Port 3
    ReefAngel.Relay.Off( Box2_Port8 );//Referencing Relay 3
    ReefAngel.SingleATOLow( Port1 );
    ReefAngel.Relay.DelayedOn( Port7 ); //Skimmer Relay 1 Port 7
    ReefAngel.MHLights( Box1_Port4 ); //ATS Light Relay 2 Port 4
    ReefAngel.DCPump.UseMemory = false; //ignore programming and use memory locations if true
    ReefAngel.Relay.Set(Box1_Port6,((now()%259200)<3600));
    if ((now()%SECS_PER_DAY==31320)) //if it is 8:42 AM
    {ReefAngel.FeedingModeStart();} //START FEEDING MODE
    if ((now()%SECS_PER_DAY==67320)) //if it is 6:42 PM
    if (hour()>=22 || hour()<9)
    { // Sleep mode - slow things down
    ReefAngel.DCPump.SetMode( Lagoon,40,66 );
    // Normal power
    ReefAngel.DCPump.SetMode( Constant,70,10 );
    ReefAngel.Portal( "Spotted" );
    ReefAngel.DDNS( "7730.homeip.net:2000" ); // Your DDNS is spotted-7730.homeip.net:2000.myreefangel.com
PostPosted: Tue Jul 11, 2017 10:08 am
It is probably the DDNS line.
Remove it and see if it works.
PostPosted: Tue Jul 11, 2017 4:45 pm
Ok, that did it.
Another question. I am running both my Jebao pumps on one side of my tank now, kind of like a gyre configuration. They are of course run by my RA. There are a couple lines in the code that looks like they define Sync and AntiSync. I assume that on is for on channel ,the other is the opposite channel. Is it possible to change one line so both say Sync or AntiSync and they both act as one pump even though they are on different dimming channels?
Thanks again.
Previous
Return to How do I code ...
