So, for the RW pumps since it can run at a lower speed than the WP series and it seems like the ReefAngel DC pump settings are default to a min. 30% since I never see it go below that.
So, how do I program for... let's say else mode for 30% is the median and 15% up/down from there? Because ReefAngel.DCPump.SetMode (Else, 30, 15); is going min. 30 and max 45, when I want min. 15 and max 45.
Also, why can't we get a sticky that explains these pump settings and what they do? The DC Pump thread is if you understand programming, why not have anything in laymen's terms?
Coding Jebao RW series pumps
Re: Coding Jebao RW series pumps
I think you need to change the threshold.
Add this to your setup()
InternalMemory.DCPumpThreshold_write(15);
You should be able to also add a hardcode
ReefAngel.DCPump.Threshold=15;
Awesome. Thanks everyone.
