Wave and feed code help
Posted: Mon Mar 07, 2016 4:07 pm
New coding help I need add a few things need dc pump mode for a adjustable amount of hours maybe time can be different but would like it to switch from sine , and short pulse , and when leaving feed mode to be in nutrient expor mode for a adjustable about of time and to have a max setting for adjustable nighttime
So I would like to adjust the hours inbetween switchING modes
Adjustable time for leaving feed mode for length of nutrient mode
Adjustable limitING speed and when it starts and ends night mode
then other for my return pump to delay adjustable mins after leaving feed mode (I currently useing delay on but it also effects waterchange and I don't want delay in water change mode)
also I want to add on/off/auto over idea in the menu for if my router stops I can manually switch relay on or off.
and last want to add my ato on cycle code to be in memory so i can edit the time on the url memory location where it says 3 in this code
ReefAngel.SingleATO(true, Port7, InternalMemory.ATOExtendedTimeout_read(), 3);
#include <SunLocation.h>
#include <Tide.h>
#include <WiFiAlert.h>
// Won't compile without this...
// ReefAngel.DCPump.UseMemory=true;
// Custom menus
#include <avr/pgmspace.h>
prog_char menu1_label[] PROGMEM = "Feeding Mode";
prog_char menu3_label[] PROGMEM = "ATO Clear";
prog_char menu4_label[] PROGMEM = "Overheat Clear";
prog_char menu5_label[] PROGMEM = "PH Calibration";
prog_char menu6_label[] PROGMEM = "Date / Time";
menu4_label, menu5_label, menu6_label
// Define Custom Memory Locations
#define Mem_I_Latitude 108
#define Mem_I_Longitude 110
#define Mem_B_AcclRiseOffset 112
#define Mem_B_AcclSetOffset 113
#define Mem_B_AcclDay 114
#define Mem_B_LightMode 160
#define Mem_B_LightOffset 161
#define Mem_I_RiseOffset 162
#define Mem_I_SetOffset 164
#define Mem_B_AcclActinicOffset 166
#define Mem_B_AcclDaylightOffset 167
#define Mem_B_LightsOffPerc 171
#define Mem_B_PrintDebug 198
#define Mem_B_ResetMemory 199
void init_memory() {
// Initialize Custom Memory Locations
InternalMemory.write_int(Mem_I_Latitude,-21);
InternalMemory.write_int(Mem_I_Longitude,-147);
InternalMemory.write(Mem_B_AcclRiseOffset,11);
InternalMemory.write(Mem_B_AcclSetOffset,11);
InternalMemory.write(Mem_B_AcclDay,0);
InternalMemory.write(Mem_B_LightOffset,30);
InternalMemory.write(Mem_B_LightMode,1);
InternalMemory.write_int(Mem_I_RiseOffset,21);
InternalMemory.write_int(Mem_I_SetOffset,21);
InternalMemory.write(Mem_B_AcclActinicOffset,166);
InternalMemory.write(Mem_B_AcclDaylightOffset,66);
InternalMemory.write(Mem_B_LightsOffPerc,1);
InternalMemory.write(Mem_B_ResetMemory,false);
#define NUMBERS_8x16
// Define Relay Ports by Name
#define Return 1
#define Heater 2
#define WhiteLeft 3
#define BlueLeft 4
#define WhiteRight 5
#define BlueRight 6
#define Autotopoff 7
#define Skimmer 8
// Custom classes
SunLocation sun;
Tide tide;
// For Cloud and preset code
int DaylightPWMValue=0;
int ActinicPWMValue=0;
int DaylightPWMValue0=0; // For cloud code, channel 0
int DaylightPWMValue2=0; // For cloud code, chennel 2
int ActinicPWMValue1=0; // For cloud code, channel 0
int ActinicPWMValue3=0; // For cloud code, chennel 2
// Needs to be global for DrawCustomGraph()
int ScreenID=1;
// Setup on controller startup/reset
ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); // Initialize Menu
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit ;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit;
ReefAngel.Relay.On( Port1 ); // Return Pump
if (InternalMemory.read(Mem_B_ResetMemory))
init_memory();
ReefAngel.Relay.DelayedOn( Port1 ); // Return Pump
ReefAngel.SingleATO(true, Port7, InternalMemory.ATOExtendedTimeout_read(), 3); // ato cycle once every 3 hour
ReefAngel.Relay.Set(Port8, ReefAngel.HighATO.IsActive()); // Skimmer no time out
ReefAngel.DCPump.ExpansionChannel[4] = Sync; // Left Jebao RW4
ReefAngel.DCPump.ExpansionChannel[5] = Sync; // jebao rw4
ReefAngel.StandardHeater(Heater);
// Lighting and Flow
SetSun(); // Setup Sun rise/set lighting
AcclimateLED(); // Apply acclimation dimming
LEDPresets();
CheckCloud(); // Check for cloud and lightning.
UpdateLED();
ReefAngel.Portal( "troylong45" );
ReefAngel.DDNS( "1" ); // Your DDNS is troylong45-1.myreefangel.com
void SetSun() {
// Start acclimation routine
int acclRiseOffset=InternalMemory.read(Mem_B_AcclRiseOffset)*60;
int acclSetOffset=InternalMemory.read(Mem_B_AcclSetOffset)*60;
byte acclDay=InternalMemory.read(Mem_B_AcclDay);
// See if we are acclimating corals and decrease the countdown each day
static boolean acclCounterReady=false;
if (now()%SECS_PER_DAY!=0) acclCounterReady=true;
if (now()%SECS_PER_DAY==0 && acclCounterReady && acclDay>0) {
acclDay--;
InternalMemory.write(Mem_B_AcclDay,acclDay);
// End acclimation
// Add some customizable offsets
sun.Init(InternalMemory.read_int(Mem_I_Latitude), InternalMemory.read_int(Mem_I_Longitude));
int riseOffset=InternalMemory.read_int(Mem_I_RiseOffset);
int setOffset=InternalMemory.read_int(Mem_I_SetOffset);
sun.SetOffset(riseOffset,(acclDay*acclRiseOffset),setOffset,(-acclDay*acclSetOffset)); // Bahamas
sun.CheckAndUpdate(); // Calculate today's Sunrise / Sunset
byte lightOffset=InternalMemory.read(Mem_B_LightOffset); // left right separation
byte actinicOffset=InternalMemory.ActinicOffset_read();
// Make sure light resets to zero at night.
for(int i=0;i<4;i++) { ReefAngel.PWM.SetChannel(i,0); }
switch(InternalMemory.read(Mem_B_LightMode)) {
case 0: {
// Daylights
ReefAngel.PWM.Channel0PWMSlope(lightOffset,0);
ReefAngel.PWM.Channel2PWMSlope(0,lightOffset);
// Actinics
ReefAngel.PWM.Channel1PWMSlope(actinicOffset+lightOffset,actinicOffset);
ReefAngel.PWM.Channel3PWMSlope(actinicOffset,actinicOffset+lightOffset);
break;
case 1: {
// Daylights
ReefAngel.PWM.Channel0PWMParabola(lightOffset,0);
ReefAngel.PWM.Channel2PWMParabola(0,lightOffset);
// Actinics
ReefAngel.PWM.Channel1PWMParabola(actinicOffset+lightOffset,actinicOffset);
ReefAngel.PWM.Channel3PWMParabola(actinicOffset,actinicOffset+lightOffset);
break;
case 2: {
// Daylights
ReefAngel.PWM.Channel0PWMSmoothRamp(lightOffset,0);
ReefAngel.PWM.Channel2PWMSmoothRamp(0,lightOffset);
// Actinics
ReefAngel.PWM.Channel1PWMSmoothRamp(actinicOffset+lightOffset,actinicOffset);
ReefAngel.PWM.Channel3PWMSmoothRamp(actinicOffset,actinicOffset+lightOffset);
break;
case 3: {
// Daylights
ReefAngel.PWM.Channel0PWMSigmoid(lightOffset,0);
ReefAngel.PWM.Channel2PWMSigmoid(0,lightOffset);
// Actinics
ReefAngel.PWM.Channel1PWMSigmoid(actinicOffset+lightOffset,actinicOffset);
ReefAngel.PWM.Channel3PWMSigmoid(actinicOffset,actinicOffset+lightOffset);
break;
case 4: { // Reverse the actinics in the morning
// Daylights
ReefAngel.PWM.Channel0PWMParabola(lightOffset+actinicOffset,0);
ReefAngel.PWM.Channel2PWMParabola(actinicOffset,lightOffset);
// Actinics
ReefAngel.PWM.Channel1PWMParabola(lightOffset,actinicOffset);
ReefAngel.PWM.Channel3PWMParabola(0,actinicOffset+lightOffset);
break;
void AcclimateLED() {
if (acclDay > 0) {
float acclActinicOffset=acclDay*(40.95*(((float)InternalMemory.read(Mem_B_AcclActinicOffset)/100)));
float acclDaylightOffset=acclDay*(40.95*((float)InternalMemory.read(Mem_B_AcclDaylightOffset)/100));
float endPerc;
endPerc=40.95*InternalMemory.PWMSlopeEnd1_read();
ReefAngel.PWM.SetChannelRaw(1,map(ReefAngel.PWM.GetChannelValueRaw(1),0,endPerc,0,endPerc-acclActinicOffset));
endPerc=40.95*InternalMemory.PWMSlopeEnd3_read();
ReefAngel.PWM.SetChannelRaw(3,map(ReefAngel.PWM.GetChannelValueRaw(3),0,endPerc,0,endPerc-acclActinicOffset));
endPerc=40.95*InternalMemory.PWMSlopeEnd0_read();
ReefAngel.PWM.SetChannelRaw(0,map(ReefAngel.PWM.GetChannelValueRaw(0),0,endPerc,0,endPerc-acclDaylightOffset));
endPerc=40.95*InternalMemory.PWMSlopeEnd2_read();
ReefAngel.PWM.SetChannelRaw(2,map(ReefAngel.PWM.GetChannelValueRaw(2),0,endPerc,0,endPerc-acclDaylightOffset));
#define LED_1to1 Box1_Port1
#define LED_2to1 Box1_Port2
#define LED_3to1 Box1_Port3
#define LED_4to1 Box1_Port4
#define LED_BLUE Box1_Port5
#define LED_WHITE Box1_Port6
#define LED_STORM Box1_Port8
void resetRelayBox(byte ID) {
// toggle all relays except for the one selected
for (int i=Box1_Port1;i<=Box1_Port4;i++) {
if (i!=ID) ReefAngel.Relay.Auto(i);
void LEDPresets() {
static byte lastPreset=0;
DaylightPWMValue0=ReefAngel.PWM.GetChannelValueRaw(0);
ActinicPWMValue1=ReefAngel.PWM.GetChannelValueRaw(1);
DaylightPWMValue2=ReefAngel.PWM.GetChannelValueRaw(2);
ActinicPWMValue3=ReefAngel.PWM.GetChannelValueRaw(3);
DaylightPWMValue=ReefAngel.PWM.GetDaylightValueRaw();
ActinicPWMValue=ReefAngel.PWM.GetActinicValueRaw();
if (ReefAngel.Relay.isMaskOn(LED_1to1)) {
if (lastPreset!=1) resetRelayBox(LED_1to1);
DaylightPWMValue0=90*40.95;
ActinicPWMValue1=10*40.95;
DaylightPWMValue2=90*40.95;
ActinicPWMValue3=10*40.95;
lastPreset=1;
if (ReefAngel.Relay.isMaskOff(LED_1to1)) {
if (lastPreset!=2) resetRelayBox(LED_1to1);
DaylightPWMValue0=10*40.95;
ActinicPWMValue1=90*40.95;
DaylightPWMValue2=10*40.95;
ActinicPWMValue3=90*40.95;
lastPreset=2;
if (ReefAngel.Relay.isMaskOn(LED_2to1)) {
if (lastPreset!=3) resetRelayBox(LED_2to1);
DaylightPWMValue0=60*40.95;
ActinicPWMValue1=40*40.95;
DaylightPWMValue2=60*40.95;
ActinicPWMValue3=40*40.95;
lastPreset=3;
if (ReefAngel.Relay.isMaskOff(LED_2to1)) {
if (lastPreset!=4) resetRelayBox(LED_2to1);
DaylightPWMValue0=40*40.95;
ActinicPWMValue1=60*40.95;
DaylightPWMValue2=40*40.95;
ActinicPWMValue3=60*40.95;
lastPreset=4;
if (ReefAngel.Relay.isMaskOn(LED_3to1)) {
if (lastPreset!=5) resetRelayBox(LED_3to1);
DaylightPWMValue0=75*40.95;
ActinicPWMValue1=25*40.95;
DaylightPWMValue2=75*40.95;
ActinicPWMValue3=25*40.95;
lastPreset=5;
if (ReefAngel.Relay.isMaskOff(LED_3to1)) {
if (lastPreset!=6) resetRelayBox(LED_3to1);
DaylightPWMValue0=25*40.95;
ActinicPWMValue1=75*40.95;
DaylightPWMValue2=25*40.95;
ActinicPWMValue3=75*40.95;
lastPreset=6;
if (ReefAngel.Relay.isMaskOn(LED_4to1)) {
if (lastPreset!=7) resetRelayBox(LED_4to1);
DaylightPWMValue0=80*40.95;
ActinicPWMValue1=20*40.95;
DaylightPWMValue2=80*40.95;
ActinicPWMValue3=20*40.95;
lastPreset=7;
if (ReefAngel.Relay.isMaskOff(LED_4to1)) {
if (lastPreset!=8) resetRelayBox(LED_4to1);
DaylightPWMValue0=20*40.95;
ActinicPWMValue1=80*40.95;
DaylightPWMValue2=20*40.95;
ActinicPWMValue3=80*40.95;
lastPreset=8;
if (ReefAngel.Relay.isMaskOn(LED_BLUE)) {
if (lastPreset!=9) resetRelayBox(LED_BLUE);
lastPreset=9;
if (ReefAngel.Relay.isMaskOff(LED_BLUE)) {
if (lastPreset!=10) resetRelayBox(LED_BLUE);
ActinicPWMValue1=0;
ActinicPWMValue3=0;
lastPreset=10;
if (ReefAngel.Relay.isMaskOn(LED_WHITE)) {
if (lastPreset!=11) resetRelayBox(LED_WHITE);
ActinicPWMValue1=0;
ActinicPWMValue3=0;
lastPreset=11;
if (ReefAngel.Relay.isMaskOff(LED_WHITE)) {
if (lastPreset!=12) resetRelayBox(LED_WHITE);
lastPreset=12;
// Write updated values to the channels
void UpdateLED() {
ReefAngel.PWM.SetChannelRaw(0,DaylightPWMValue0);
ReefAngel.PWM.SetChannelRaw(1,ActinicPWMValue1);
ReefAngel.PWM.SetChannelRaw(2,DaylightPWMValue2);
ReefAngel.PWM.SetChannelRaw(3,ActinicPWMValue3);
ReefAngel.PWM.SetDaylightRaw(DaylightPWMValue);
ReefAngel.PWM.SetActinicRaw(ActinicPWMValue);
byte LightsOffPerc=40.95*InternalMemory.read(Mem_B_LightsOffPerc);
if (ReefAngel.PWM.GetChannelValueRaw(0)>=LightsOffPerc) ReefAngel.Relay.On(WhiteLeft); else ReefAngel.Relay.Off(WhiteLeft);
if (ReefAngel.PWM.GetChannelValueRaw(1)>=LightsOffPerc) ReefAngel.Relay.On(BlueLeft); else ReefAngel.Relay.Off(BlueLeft);
if (ReefAngel.PWM.GetChannelValueRaw(2)>=LightsOffPerc) ReefAngel.Relay.On(WhiteRight); else ReefAngel.Relay.Off(WhiteRight);
if (ReefAngel.PWM.GetChannelValueRaw(3)>=LightsOffPerc) ReefAngel.Relay.On(BlueRight); else ReefAngel.Relay.Off(BlueRight);
// Menu Code
void MenuEntry1() {
ReefAngel.FeedingModeStart();
void MenuEntry2() {
void MenuEntry3() {
ReefAngel.ATOClear();
void MenuEntry4() {
ReefAngel.OverheatClear();
void MenuEntry5() {
ReefAngel.SetupCalibratePH();
void MenuEntry6() {
ReefAngel.SetupDateTime();
// Custom Main Screen
void DrawCustomMain() {
const int NumScreens=4;
static boolean drawGraph=true;
// Main Header
// ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 35, 2,"Troy's Reef");
ReefAngel.LCD.DrawDate(5,2);
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 128, 11);
// Param Header
DrawParams(5,14);
switch (ScreenID) {
case 0:
if (drawGraph) { ReefAngel.LCD.DrawGraph(5,40); drawGraph=false; }
break;
case 1: { DrawStatus(5,40); break; }
case 2: { DrawSunMoon(5,40); break; }
// Draw Relays
DrawRelays(12,94);
// Date+Time
// ReefAngel.LCD.DrawDate(5,122);
if (ReefAngel.Joystick.IsLeft()) {
ScreenID--; drawGraph=true;
if (ReefAngel.Joystick.IsRight()) {
ScreenID++; drawGraph=true;
if (ScreenID<0) ScreenID=NumScreens-1;
if (ScreenID>=NumScreens) ScreenID=0;
void DrawCustomGraph() {
if (ScreenID==0)
ReefAngel.LCD.DrawGraph(5, 40);
void DrawParams(int x, int y) {
char buf[16];
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+5,y,"Temp:");
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+80, y, "PH:");
// Temp and PH
y+=2;
ConvertNumToString(buf, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawText(T2TempColor, DefaultBGColor, x+45, y, buf);
y+=6;
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+80, y, buf, Num8x16);
y+=5;
ConvertNumToString(buf, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawText(T3TempColor, DefaultBGColor, x+45, y, buf);
void DrawStatus(int x, int y) {
int t=x;
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,y,"High",Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,85,y,"Low",Font8x16);
ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_GREEN);
} else {
ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_RED);
if (ReefAngel.LowATO.IsActive()) {
ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_GREEN);
} else {
ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_RED);
y+=12;
// Display Acclimation timer
if (acclDay > 0) {
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"Acclimation Day:"); x+=100;
ReefAngel.LCD.DrawSingleMonitor(acclDay,DefaultFGColor,x,y,1);
} else {
ReefAngel.LCD.Clear(DefaultBGColor,x,y,128,y+8);
void DrawSunMoon(int x, int y) {
char buf[16];
int t=x;
y+=2;
/// Display Sunrise / Sunset
sprintf(buf, "%02d:%02d", sun.GetRiseHour(), sun.GetRiseMinute());
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"Rise:"); x+=31;
ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,buf);
sprintf(buf, "%02d:%02d", sun.GetSetHour(), sun.GetSetMinute()); x+=36;
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"Set:"); x+=25;
y+=15; x=t;
void DrawRelays(int x, int y) {
// Draw Relays
ReefAngel.LCD.DrawOutletBox(x, y, TempRelay);
void DelayedOnModes(byte relay) {
static unsigned long startTime=now();
if ( (startTime==LastStart) && ReefAngel.HighATO.IsActive()) {
ReefAngel.Relay.On(relay);
} else {
ReefAngel.Relay.DelayedOn(relay);
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 45
#define Min_Cloud_Duration 1
#define Max_Cloud_Duration 5
#define Min_Clouds_per_Day 2
#define Max_Clouds_per_Day 30
// In this example, start cloud after noon
#define Start_Cloud_After NumMins(10,00)
#define End_Cloud_Before NumMins(18,00)
#define Lightning_Change_per_Cloud 25
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes
// of effects or unforseen result could happen.
// In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the
// 250 minutes (or 500 minutes) can fit in that 510 minutes window.
// Add Random Lightning modes
#define Calm 0 // No lightning
#define Slow 1 // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2 // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3 // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4 // Like Mega, but with more lightning
// Example: { Calm, Fast, Mega, Mega2 } to randomize all four modes.
// { Mega2 } for just Mega2. { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
byte LightningModes[] = { Calm, Slow };
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
static byte lightningMode=0;
static time_t DelayCounter=millis(); // Variable for lightning timing.
static int DelayTime=random(1000); // Variable for lightning timimg.
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
randomSeed(millis()); // Seed the random number generator
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue/40.95,0,180)*40.95;
if (chooseLightning)
chooseLightning=false;
switch (lightningMode)
case Calm:
break;
case Mega:
// Lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
// Send the trigger
Strike();
DelayCounter=millis(); // If we just had a round of flashes, then lets put in a longer delay
DelayTime=random(1000); // of up to a second for dramatic effect before we do another round.
break;
case Mega2:
// Higher lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
Strike();
break;
case Fast:
Strike();
break;
case Slow:
// Slow lightning for 5 seconds in the middle of the cloud. Suitable for slower ELN style drivers
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=4095;
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
if (cloudindex < numclouds)
/*ReefAngel.LCD.Clear(255,0,120,132,132);
ReefAngel.LCD.DrawText(0,255,51,120,"00:00"); */
int x=0;
else x=17;
//ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart/60));
ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
else x=35;
//ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart%60));
ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
//ReefAngel.LCD.DrawText(0,255,90,120,cloudduration);
ReefAngel.CustomVar[7]=(cloudduration); // Put the duration of the next cloud in a custom var for the portal
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51;
else x=57;
//ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))/60));
ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60; // Write the hour of the next lightning to a custom variable for the Portal
if (((cloudstart+(cloudduration/2))%60)>=10) x=69;
else x=75;
//ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
void Strike()
int a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
for (int i=0; i<a; i++)
// Flash on
int newdata=4095;
Wire.beginTransmission(0x40); // Address of the dimming expansion module
Wire.write(0x8+(4*0)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 1.
Wire.write(newdata&0xff); // Send the data 8 bits at a time. This sends the LSB
Wire.write(newdata>>8); // This sends the MSB
Wire.endTransmission();
Wire.write(0x8+(4*2)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 1.
int randy=random(20,80); // Random number for a delay
if (randy>71) randy=((randy-70)/2)*100; // Small chance of a longer delay
delay(randy); // Wait from 20 to 69 ms, or 100-400 ms
// Flash off. Return to baseline.
newdata=ReefAngel.PWM.GetChannelValueRaw(0); // Use the channel number you're flashing here
Wire.beginTransmission(0x40); // Same as above
delay(random(30,50)); // Wait from 30 to 49 ms
wdt_reset(); // Reset watchdog timer to avoid re-boots
cstart*=60;
cend*=60;
if (n>cend) return (int) PWMStart;
