#include <WiFiAlert.h>
// Define Custome Memory Locations
#define Mem_B_SkimmerWL 100
#define Mem_B_PHDayPower 101
#define Mem_B_PHNightPower 102
#define Mem_B_PHDuration 103
#define Mem_I_ChillerPumpT 104
#define Mem_B_CPumpMax 106
#define Mem_B_CPumpMin 107
#define Return 1
#define Pwm_Exp 2
#define ATI 3
#define Modem 4
#define Jebao1_Rhs 5
#define Jebao2_Rhs 6
#define Jebao1_Lhs 7
#define Jebao2_Lhs 8
#define ATO Box1_Port1
#define Fuge_Led Box1_Port2
#define Heater1 Box1_Port3
#define Doser Box1_Port4
#define Heater2 Box1_Port5
#define Skimmer Box1_Port6
#define Swabby Box1_Port7
#define CPump Box1_Port8
#define MH1 Box2_Port1
#define MH2 Box2_Port2
#define Actinics Box2_Port3
#define Day Box2_Port4
#define Fan Box2_Port5
#define Unused Box2_Port6
#define Unused Box2_Port7
#define Unused B0x2_Port8
ReefAngel.OverheatShutoffPortsE[1] = Port1Bit | Port2Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port5Bit;
ReefAngel.Relay.On( Pwm_Exp );
ReefAngel.Relay.On( Return );
ReefAngel.Relay.On( ATI );
ReefAngel.Relay.On( Doser );
ReefAngel.Relay.On( CPump );
ReefAngel.Relay.On( Modem );
ReefAngel.Relay.On( Skimmer );
ReefAngel.MHLights( MH1 );
ReefAngel.MHLights( MH2 );
ReefAngel.ActinicLights( Actinics );
ReefAngel.DayLights( Day );
ReefAngel.ActinicLights( Fuge_Led );
ReefAngel.ActinicLights( Fan );
ReefAngel.StandardHeater( Heater1 );
ReefAngel.StandardHeater( Heater2 );
ReefAngel.WaterLevelATO( ATO );
CheckPower();
ReefAngel.DosingPumpRepeat1(Swabby);
ReefAngel.Relay.Off(Skimmer);
ReefAngel.Relay.On(Skimmer);
if (hour()>=6 && hour()<12)
ReefAngel.PWM.SetDaylight( ReefCrestMode(InternalMemory.read(Mem_B_PHDayPower),InternalMemory.read(Mem_B_PHDuration),true) );
ReefAngel.PWM.SetActinic( ReefCrestMode(InternalMemory.read(Mem_B_PHDayPower),InternalMemory.read(Mem_B_PHDuration),true) );
ReefAngel.Relay.Off( Jebao1_Lhs );
ReefAngel.Relay.Off( Jebao2_Lhs );
ReefAngel.Relay.On( Jebao1_Rhs );
ReefAngel.Relay.On( Jebao2_Rhs );
else if (hour()>=12 && hour()<18)
ReefAngel.PWM.SetChannel( 0, ReefCrestMode(InternalMemory.read(Mem_B_PHDayPower),InternalMemory.read(Mem_B_PHDuration),true) );
ReefAngel.PWM.SetChannel( 1, ReefCrestMode(InternalMemory.read(Mem_B_PHDayPower),InternalMemory.read(Mem_B_PHDuration),true) );
ReefAngel.Relay.Off( Jebao1_Rhs );
ReefAngel.Relay.Off( Jebao2_Rhs );
ReefAngel.Relay.On( Jebao1_Lhs );
ReefAngel.Relay.On( Jebao2_Lhs );
else if (hour()>=18 && hour()<24)
ReefAngel.PWM.SetDaylight( ReefCrestMode(InternalMemory.read(Mem_B_PHNightPower),InternalMemory.read(Mem_B_PHDuration),true) );
ReefAngel.PWM.SetActinic( ReefCrestMode(InternalMemory.read(Mem_B_PHNightPower),InternalMemory.read(Mem_B_PHDuration),true) );
ReefAngel.PWM.SetChannel( 0, ReefCrestMode(InternalMemory.read(Mem_B_PHNightPower),InternalMemory.read(Mem_B_PHDuration),true) );
ReefAngel.PWM.SetChannel( 1, ReefCrestMode(InternalMemory.read(Mem_B_PHNightPower),InternalMemory.read(Mem_B_PHDuration),true) );
ReefAngel.Portal( "sabo","****" );
void CheckPower() {
static boolean powerOutage=false;
static WiFiAlert powerAlert;
// Power Outage - turn off everything
if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY)) // Expansion Relay NOT present
powerOutage=true;
powerAlert.Send("Power+outage!");
// Power Restored - Turn things back on
if (powerOutage && ReefAngel.Relay.IsRelayPresent(EXP1_RELAY))
LastStart=now();
powerOutage=false;
powerAlert.Send("Power+restored.",true);
