I have my dual Jaebo RW-4's on a "SetMode" schedule. They will not physically change when the time event occurs. The only fix I have for now is rebooting my relay box. Any thoughts?
#include <Tide.h>
Tide tide;
// Define Relay Ports by Name
#define MoonLights 1
#define MainPump 2
#define WhiteLED 3
#define Skimmer 4
#define BlueLED 5
#define Unused 6
#define Unused 7
#define ATO_Pump 8
ReefAngel.AddPHExpansion(); // pH Expansion Module
ReefAngel.FeedingModePorts = Port2Bit | Port4Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port4Bit;
ReefAngel.DCPump.FeedingSpeed = 0;
ReefAngel.DCPump.WaterChangeSpeed = 0;
ReefAngel.LightsOnPorts = Port1Bit | Port3Bit | Port5Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port5Bit;
InternalMemory.OverheatTemp_write(869);
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Port8);
switch (tmWday)
case 1: //Sunday
if (hour() >= 11 || hour() < 8) {
ReefAngel.StandardLights(Port1, 0);
ReefAngel.StandardLights(Port1, 20, 0, 7, 0);
ReefAngel.StandardLights(Port3, 11, 0, 19, 0);
ReefAngel.StandardLights(Port5, 11, 0, 19, 0);
break;
case 2: //Monday
if (hour() >= 12 || hour() < 8) {
ReefAngel.StandardLights(Port3, 12, 0, 20, 0);
ReefAngel.StandardLights(Port5, 12, 0, 20, 0);
break;
case 3: //Tuesday
break;
case 4: //Wednesday
break;
case 5: //Thursday
break;
case 6: //Friday
break;
case 7: //Saturday
ReefAngel.StandardLights(Port3, 11, 0, 20, 0);
ReefAngel.StandardLights(Port5, 11, 0, 20, 0);
break;
default:
ReefAngel.StandardLights(Port3, 0, 0, 0, 0);
ReefAngel.StandardLights(Port5, 0, 0, 0, 0);
break;
//ReefAngel.DCPump.SetMode(ReefCrest, 45, 5);
if (hour() >= 20 || hour()<7) {
//ReefAngel.DCPump.SetMode(TideMode(15, 3, 7), 15, 10);
ReefAngel.DCPump.SetMode(Lagoon, 20, 5);
else if (hour() >= 7 || hour()<20)
ReefAngel.DCPump.SetMode(ReefCrest, 45, 10);
//ReefAngel.DCPump.SetMode(TideMode(45, 3, 10),45,10);
ReefAngel.Portal("CaliFSU");
