power head and moon ?
troylong45
Post by troylong45 »
im looking to add moon and replicate the jabeos to nature to be more life like what do i add to my code for this and doo i need to remove .. i plan on useing the day and night ports for left the right moon lights and the dimming expansion is in below
    #include <SunLocation.h>
    #include <Tide.h>
    #include <WiFiAlert.h>
    // Won't compile without this...
    // ReefAngel.DCPump.UseMemory=true;
    // Custom menus
    #include <avr/pgmspace.h>
    prog_char menu1_label[] PROGMEM = "Feeding Mode";
    menu4_label, menu5_label, menu6_label
    // Define Custom Memory Locations
    #define Mem_I_Latitude        108
    #define Mem_I_Longitude       110
    #define Mem_B_AcclRiseOffset  112
    #define Mem_B_AcclSetOffset   113
    #define Mem_B_AcclDay         114
    #define Mem_B_LightMode       160
    #define Mem_B_LightOffset     161
    #define Mem_I_RiseOffset      162
    #define Mem_I_SetOffset       164
    #define Mem_B_AcclActinicOffset     166
    #define Mem_B_AcclDaylightOffset    167
    #define Mem_B_LightsOffPerc   171
    #define Mem_B_PrintDebug      198
    #define Mem_B_ResetMemory     199
    void init_memory() {
      // Initialize Custom Memory Locations
      InternalMemory.write_int(Mem_I_Latitude,-21);
      InternalMemory.write_int(Mem_I_Longitude,-147);
      InternalMemory.write(Mem_B_AcclRiseOffset,12);
      InternalMemory.write(Mem_B_AcclSetOffset,13);
      InternalMemory.write(Mem_B_AcclDay,0);
      InternalMemory.write(Mem_B_LightOffset,10);
      InternalMemory.write(Mem_B_LightMode,1);
      InternalMemory.write_int(Mem_I_RiseOffset,21);
      InternalMemory.write_int(Mem_I_SetOffset,21);
      InternalMemory.write(Mem_B_AcclActinicOffset,250);
      InternalMemory.write(Mem_B_AcclDaylightOffset,125);
      InternalMemory.write(Mem_B_LightsOffPerc,1);
      InternalMemory.write(Mem_B_ResetMemory,false);
    #define NUMBERS_8x16
    // Define Relay Ports by Name
    #define Return             1
    #define Heater             2
    #define WhiteLeft          3
    #define BlueLeft           4
    #define WhiteRight         5
    #define BlueRight          6
    #define Autotopoff         7
    #define Skimmer            8
    // Custom classes
    SunLocation sun;
    Tide tide;
    // For Cloud and preset code
    int DaylightPWMValue=0;
    int ActinicPWMValue=0;
    int DaylightPWMValue0=0;        // For cloud code, channel 0
    int DaylightPWMValue2=0;        // For cloud code, chennel 2
    int ActinicPWMValue1=0;        // For cloud code, channel 0
    int ActinicPWMValue3=0;        // For cloud code, chennel 2
    // Needs to be global for DrawCustomGraph()
    int ScreenID=1;
    // Setup on controller startup/reset
      ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); // Initialize Menu
      ReefAngel.FeedingModePorts = Port1Bit | Port2Bit ;
      ReefAngel.WaterChangePorts = Port1Bit | Port2Bit  | Port7Bit  | Port8Bit;
      ReefAngel.LightsOnPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.Relay.On( Port1 ); // Return Pump
      if (InternalMemory.read(Mem_B_ResetMemory))
        init_memory();
    ReefAngel.Relay.DelayedOn( Port1 ); // Return Pump
    ReefAngel.SingleATO(true, Port7, InternalMemory.ATOExtendedTimeout_read(), 3); // ato cycle once every 3 hour
    ReefAngel.Relay.Set(Port8, ReefAngel.HighATO.IsActive()); // Skimmer no time out
    ReefAngel.DCPump.ExpansionChannel[4] = Sync; // Left Jebao RW4
    ReefAngel.DCPump.ExpansionChannel[5] = Sync; // Right jebao rw4
    ReefAngel.StandardHeater(Heater);
      // Lighting and Flow
      SetSun();               // Setup Sun rise/set lighting
      AcclimateLED();         // Apply acclimation dimming
      LEDPresets();
      CheckCloud();           //  Check for cloud and lightning.
      UpdateLED();
       ReefAngel.Portal( "troylong45" );
    ReefAngel.DDNS( "1" ); // Your DDNS is troylong45-1.myreefangel.com
    void SetSun() {
      // Start acclimation routine
      int acclRiseOffset=InternalMemory.read(Mem_B_AcclRiseOffset)*60;
      int acclSetOffset=InternalMemory.read(Mem_B_AcclSetOffset)*60;
      byte acclDay=InternalMemory.read(Mem_B_AcclDay);
      // See if we are acclimating corals and decrease the countdown each day
      static boolean acclCounterReady=false;
      if (now()%SECS_PER_DAY!=0) acclCounterReady=true;
      if (now()%SECS_PER_DAY==0 && acclCounterReady && acclDay>0) {
        acclDay--;
        InternalMemory.write(Mem_B_AcclDay,acclDay);
      // End acclimation
      // Add some customizable offsets
      sun.Init(InternalMemory.read_int(Mem_I_Latitude), InternalMemory.read_int(Mem_I_Longitude));
      int riseOffset=InternalMemory.read_int(Mem_I_RiseOffset);
      int setOffset=InternalMemory.read_int(Mem_I_SetOffset);
      sun.SetOffset(riseOffset,(acclDay*acclRiseOffset),setOffset,(-acclDay*acclSetOffset)); // Bahamas
      sun.CheckAndUpdate(); // Calculate today's Sunrise / Sunset
      byte lightOffset=InternalMemory.read(Mem_B_LightOffset); // left right separation
      byte actinicOffset=InternalMemory.ActinicOffset_read();
      // Make sure light resets to zero at night.
      for(int i=0;i<4;i++) { ReefAngel.PWM.SetChannel(i,0); }
      switch(InternalMemory.read(Mem_B_LightMode)) {
        case 0: {
          // Daylights
          ReefAngel.PWM.Channel0PWMSlope(lightOffset,0);
          ReefAngel.PWM.Channel2PWMSlope(0,lightOffset);
          // Actinics
          ReefAngel.PWM.Channel1PWMSlope(actinicOffset+lightOffset,actinicOffset);
          ReefAngel.PWM.Channel3PWMSlope(actinicOffset,actinicOffset+lightOffset);
          break;
        case 1: {
          // Daylights
          ReefAngel.PWM.Channel0PWMParabola(lightOffset,0);
          ReefAngel.PWM.Channel2PWMParabola(0,lightOffset);
          // Actinics
          ReefAngel.PWM.Channel1PWMParabola(actinicOffset+lightOffset,actinicOffset);
          ReefAngel.PWM.Channel3PWMParabola(actinicOffset,actinicOffset+lightOffset);
          break;
      case 2: {
          // Daylights
          ReefAngel.PWM.Channel0PWMSmoothRamp(lightOffset,0);
          ReefAngel.PWM.Channel2PWMSmoothRamp(0,lightOffset);
          // Actinics
          ReefAngel.PWM.Channel1PWMSmoothRamp(actinicOffset+lightOffset,actinicOffset);
          ReefAngel.PWM.Channel3PWMSmoothRamp(actinicOffset,actinicOffset+lightOffset);
          break;
      case 3: {
          // Daylights
          ReefAngel.PWM.Channel0PWMSigmoid(lightOffset,0);
          ReefAngel.PWM.Channel2PWMSigmoid(0,lightOffset);
          // Actinics
          ReefAngel.PWM.Channel1PWMSigmoid(actinicOffset+lightOffset,actinicOffset);
          ReefAngel.PWM.Channel3PWMSigmoid(actinicOffset,actinicOffset+lightOffset);
          break;
      case 4: { // Reverse the actinics in the morning
          // Daylights
          ReefAngel.PWM.Channel0PWMParabola(lightOffset+actinicOffset,0);
          ReefAngel.PWM.Channel2PWMParabola(actinicOffset,lightOffset);
          // Actinics
          ReefAngel.PWM.Channel1PWMParabola(lightOffset,actinicOffset);
          ReefAngel.PWM.Channel3PWMParabola(0,actinicOffset+lightOffset);
          break;
    void AcclimateLED() {
      if (acclDay > 0) {
        float acclActinicOffset=acclDay*(40.95*(((float)InternalMemory.read(Mem_B_AcclActinicOffset)/100)));
        float acclDaylightOffset=acclDay*(40.95*((float)InternalMemory.read(Mem_B_AcclDaylightOffset)/100));
        float endPerc;
        endPerc=40.95*InternalMemory.PWMSlopeEnd1_read();
        ReefAngel.PWM.SetChannelRaw(1,map(ReefAngel.PWM.GetChannelValueRaw(1),0,endPerc,0,endPerc-acclActinicOffset));
        endPerc=40.95*InternalMemory.PWMSlopeEnd3_read();
        ReefAngel.PWM.SetChannelRaw(3,map(ReefAngel.PWM.GetChannelValueRaw(3),0,endPerc,0,endPerc-acclActinicOffset));
        endPerc=40.95*InternalMemory.PWMSlopeEnd0_read();
        ReefAngel.PWM.SetChannelRaw(0,map(ReefAngel.PWM.GetChannelValueRaw(0),0,endPerc,0,endPerc-acclDaylightOffset));
        endPerc=40.95*InternalMemory.PWMSlopeEnd2_read();
        ReefAngel.PWM.SetChannelRaw(2,map(ReefAngel.PWM.GetChannelValueRaw(2),0,endPerc,0,endPerc-acclDaylightOffset));
    #define LED_1to1  Box1_Port1
    #define LED_2to1  Box1_Port2
    #define LED_3to1  Box1_Port3
    #define LED_4to1  Box1_Port4
    #define LED_BLUE  Box1_Port5
    #define LED_WHITE Box1_Port6
    #define LED_STORM Box1_Port8
    void resetRelayBox(byte ID) {
      // toggle all relays except for the one selected
      for (int i=Box1_Port1;i<=Box1_Port4;i++) {
        if (i!=ID) ReefAngel.Relay.Auto(i);
    void LEDPresets() {
      static byte lastPreset=0;
      DaylightPWMValue0=ReefAngel.PWM.GetChannelValueRaw(0);
      ActinicPWMValue1=ReefAngel.PWM.GetChannelValueRaw(1);
      DaylightPWMValue2=ReefAngel.PWM.GetChannelValueRaw(2);
      ActinicPWMValue3=ReefAngel.PWM.GetChannelValueRaw(3);
      DaylightPWMValue=ReefAngel.PWM.GetDaylightValueRaw();
      ActinicPWMValue=ReefAngel.PWM.GetActinicValueRaw();
      if (ReefAngel.Relay.isMaskOn(LED_1to1)) {
        if (lastPreset!=1) resetRelayBox(LED_1to1);
        DaylightPWMValue0=90*40.95;
        ActinicPWMValue1=10*40.95;
        DaylightPWMValue2=90*40.95;
        ActinicPWMValue3=10*40.95;
        lastPreset=1;
      if (ReefAngel.Relay.isMaskOff(LED_1to1)) {
        if (lastPreset!=2) resetRelayBox(LED_1to1);
        DaylightPWMValue0=10*40.95;
        ActinicPWMValue1=90*40.95;
        DaylightPWMValue2=10*40.95;
        ActinicPWMValue3=90*40.95;
        lastPreset=2;
      if (ReefAngel.Relay.isMaskOn(LED_2to1)) {
        if (lastPreset!=3) resetRelayBox(LED_2to1);
        DaylightPWMValue0=60*40.95;
        ActinicPWMValue1=40*40.95;
        DaylightPWMValue2=60*40.95;
        ActinicPWMValue3=40*40.95;
        lastPreset=3;
      if (ReefAngel.Relay.isMaskOff(LED_2to1)) {
        if (lastPreset!=4) resetRelayBox(LED_2to1);
        DaylightPWMValue0=40*40.95;
        ActinicPWMValue1=60*40.95;
        DaylightPWMValue2=40*40.95;
        ActinicPWMValue3=60*40.95;
        lastPreset=4;
      if (ReefAngel.Relay.isMaskOn(LED_3to1)) {
        if (lastPreset!=5) resetRelayBox(LED_3to1);
        DaylightPWMValue0=75*40.95;
        ActinicPWMValue1=25*40.95;
        DaylightPWMValue2=75*40.95;
        ActinicPWMValue3=25*40.95;
        lastPreset=5;
      if (ReefAngel.Relay.isMaskOff(LED_3to1)) {
        if (lastPreset!=6) resetRelayBox(LED_3to1);
        DaylightPWMValue0=25*40.95;
        ActinicPWMValue1=75*40.95;
        DaylightPWMValue2=25*40.95;
        ActinicPWMValue3=75*40.95;
        lastPreset=6;
      if (ReefAngel.Relay.isMaskOn(LED_4to1)) {
        if (lastPreset!=7) resetRelayBox(LED_4to1);
        DaylightPWMValue0=80*40.95;
        ActinicPWMValue1=20*40.95;
        DaylightPWMValue2=80*40.95;
        ActinicPWMValue3=20*40.95;
        lastPreset=7;
      if (ReefAngel.Relay.isMaskOff(LED_4to1)) {
        if (lastPreset!=8) resetRelayBox(LED_4to1);
        DaylightPWMValue0=20*40.95;
        ActinicPWMValue1=80*40.95;
        DaylightPWMValue2=20*40.95;
        ActinicPWMValue3=80*40.95;
        lastPreset=8;
      if (ReefAngel.Relay.isMaskOn(LED_BLUE)) {
        if (lastPreset!=9) resetRelayBox(LED_BLUE);
        lastPreset=9;
      if (ReefAngel.Relay.isMaskOff(LED_BLUE)) {
        if (lastPreset!=10) resetRelayBox(LED_BLUE);
        ActinicPWMValue1=0;
        ActinicPWMValue3=0;
        lastPreset=10;
      if (ReefAngel.Relay.isMaskOn(LED_WHITE)) {
        if (lastPreset!=11) resetRelayBox(LED_WHITE);
        ActinicPWMValue1=0;
        ActinicPWMValue3=0;
        lastPreset=11;
      if (ReefAngel.Relay.isMaskOff(LED_WHITE)) {
        if (lastPreset!=12) resetRelayBox(LED_WHITE);
        lastPreset=12;
    // Write updated values to the channels
    void UpdateLED() {
      ReefAngel.PWM.SetChannelRaw(0,DaylightPWMValue0);
      ReefAngel.PWM.SetChannelRaw(1,ActinicPWMValue1);
      ReefAngel.PWM.SetChannelRaw(2,DaylightPWMValue2);
      ReefAngel.PWM.SetChannelRaw(3,ActinicPWMValue3);
      ReefAngel.PWM.SetDaylightRaw(DaylightPWMValue);
      ReefAngel.PWM.SetActinicRaw(ActinicPWMValue);
      byte LightsOffPerc=40.95*InternalMemory.read(Mem_B_LightsOffPerc);
      if (ReefAngel.PWM.GetChannelValueRaw(0)>=LightsOffPerc) ReefAngel.Relay.On(WhiteLeft); else ReefAngel.Relay.Off(WhiteLeft);
      if (ReefAngel.PWM.GetChannelValueRaw(1)>=LightsOffPerc) ReefAngel.Relay.On(BlueLeft); else ReefAngel.Relay.Off(BlueLeft);
      if (ReefAngel.PWM.GetChannelValueRaw(2)>=LightsOffPerc) ReefAngel.Relay.On(WhiteRight); else ReefAngel.Relay.Off(WhiteRight);
      if (ReefAngel.PWM.GetChannelValueRaw(3)>=LightsOffPerc) ReefAngel.Relay.On(BlueRight); else ReefAngel.Relay.Off(BlueRight);
    // Menu Code
    void MenuEntry1() {
      ReefAngel.FeedingModeStart();
    void MenuEntry2() {
    void MenuEntry3() {
      ReefAngel.ATOClear();
    void MenuEntry4() {
      ReefAngel.OverheatClear();
    void MenuEntry5() {
      ReefAngel.SetupCalibratePH();
    void MenuEntry6() {
      ReefAngel.SetupDateTime();
    // Custom Main Screen
    void DrawCustomMain() {
      const int NumScreens=4;
      static boolean drawGraph=true;
      // Main Header
      // ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 35, 2,"Troy's Reef");
      ReefAngel.LCD.DrawDate(5,2);
      ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 128, 11);
      // Param Header
      DrawParams(5,14);
      switch (ScreenID) {
        case 0:
          if (drawGraph) { ReefAngel.LCD.DrawGraph(5,40); drawGraph=false; }
          break;
        case 1: { DrawStatus(5,40); break; }
        case 2: { DrawSunMoon(5,40); break; }
      // Draw Relays
      DrawRelays(12,94);
      // Date+Time
      // ReefAngel.LCD.DrawDate(5,122);
      if (ReefAngel.Joystick.IsLeft()) {
        ScreenID--; drawGraph=true;
      if (ReefAngel.Joystick.IsRight()) {
        ScreenID++; drawGraph=true;
    void DrawCustomGraph() {
      if (ScreenID==0)
        ReefAngel.LCD.DrawGraph(5, 40);
      char buf[16];
      // Temp and PH
      y+=2;
      y+=6;
      y+=5;
      int t=x;
      y+=12;
      // Display Acclimation timer
      if (acclDay > 0) {
        ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"Acclimation Day:"); x+=100;
        ReefAngel.LCD.DrawSingleMonitor(acclDay,DefaultFGColor,x,y,1);
        ReefAngel.LCD.Clear(DefaultBGColor,x,y,128,y+8);
    void DrawSunMoon(int x, int y) {
      char buf[16];
      int t=x;
      y+=2;
      /// Display Sunrise / Sunset
      sprintf(buf, "%02d:%02d", sun.GetRiseHour(), sun.GetRiseMinute());
      ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"Rise:"); x+=31;
      ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,buf);
      sprintf(buf, "%02d:%02d", sun.GetSetHour(), sun.GetSetMinute()); x+=36;
      ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"Set:"); x+=25;
      y+=15; x=t;
    void DrawRelays(int x, int y) {
      // Draw Relays
    void DelayedOnModes(byte relay) {
      static unsigned long startTime=now();
      if ( (startTime==LastStart) && ReefAngel.HighATO.IsActive()) {
        ReefAngel.Relay.On(relay);
        ReefAngel.Relay.DelayedOn(relay);
     void CheckCloud()
        #define Clouds_Every_X_Days 1
        #define Min_Cloud_Duration 6
        #define Max_Cloud_Duration 15
        #define Min_Clouds_per_Day 5
        #define Max_Clouds_per_Day 25
        #define Start_Cloud_After NumMins(9,00)
        #define End_Cloud_Before NumMins(18,00)
        #define Lightning_Change_per_Cloud 50
          // Add Random Lightning modes
          // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
          byte LightningModes[] = { Slow };
          static byte cloudchance=255;
          static byte cloudduration=0;
          static int cloudstart=0;
          static byte numclouds=0;
          static byte cloudindex=0;
          static int LastNumMins=0;
          static byte lightningMode=0;
        #ifdef forcecloudcalculation
          if (cloudchance==255)
        #else
        #endif
              cloudchance=random(100);
              // If we have cloud today
              if (cloudchance)
                lightningchance=random(100);
          if (cloudchance)
            //is it time for cloud yet?
              if (chooseLightning)
                chooseLightning=false;
              switch (lightningMode)
              case Calm:
                break;
              case Mega:
                  // Send the trigger
                  Strike();
                break;
              case Mega2:
                  Strike();
                break;
              case Fast:
                  Strike();
                break;
              case Slow:
                  else lightningstatus=0;
                  if (lightningstatus)
                    DaylightPWMValue=4095;
                    DaylightPWMValue=0;
                  delay(1);
                break;
              default:
                break;
              cloudindex++;
              if (cloudindex < numclouds)
              int x=0;
              else x=17;
              else x=35;
            ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
            if (lightningchance)
              int x=0;
              else x=57;
              ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
              else x=75;
        void Strike()
          int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
          for (int i=0; i<a; i++)
            // Flash on
            int newdata=4095;
            Wire.beginTransmission(0x40);      // Address of the dimming expansion module
            Wire.write(0x8+(4*0));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
            Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
            Wire.write(newdata>>8);            // This sends the MSB
            Wire.endTransmission();
            Wire.write(0x8+(4*2));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
            // Flash off.  Return to baseline.
            newdata=ReefAngel.PWM.GetChannelValueRaw(0);   // Use the channel number you're flashing here
            Wire.beginTransmission(0x40);    // Same as above
            wdt_reset();    // Reset watchdog timer to avoid re-boots
          cstart*=60;
          cend*=60;
Re: power head and moon ?
That's the Tide and the Moon class.
// This goes up top with the rest.
#include <Moon.h>
// Put this stuff in loop in custom section
moon_init(21,-73);
ReefAngel.PWM.SetDaylightRaw(PWMParabolaHighRes(Moon.riseH,Moon.riseM,Moon.setH,Moon.setM,0,MoonPhase(),0));
ReefAngel.PWM.SetActinicRaw(PWMParabolaHighRes(actRiseH,actRiseM,actSetH,actSetM,0,MoonPhase(),0));
troylong45
Ok and that will give me the tidal dc pump setting as well to simulat tide coming in and out high and low tide and ect.
troylong45
wait i was wrong i need to have alot of stuff changed dc pumps will stay same channels( dimming expasion channel 4 and 5).
i need the moons to be on dimming expanson channels 2 (will be left) AND 3 (will be right)
and need all the atitnic channels moved from dimming expasion channel 1 and 3 to move to daylight and atitic relay box channels
and the dimming expasion channel 2 for day light to move to dimming expasion channel 1
so i will have relay box left and right blue channels 0-10v anolog
dimming expasion channel 0 and 1 for left and right daylights 0-10v anolog
dimming expasion channel 2 and 3 5v pwm for left and right moons(and will need to add update led relays 7 and 8 i belive which is currently my ato and skim and move the ato and skim to a 2nd relay box )
dimming expasion channel 4 and 5 5v anolog for the jebaos
and of course need all the storm / light off sets/ skim and ato floats edited if needed and any thing im missing
I didnt do the pumps its more complicated for the moment.
For the rest you've got me swimming...it doesnt matter what dimming. Just use my example for the other channels. The key is running moon_init it loop and then it will set the rise and set times
troylong45
The pumps are fine but I need to swap light channels for the moons cus I can't run pwm on the relay box right? I'll try to move everything around after tomorrow. And then see if you can proof Read it. Or when I get a 2nd relay box can't I get one that's pwm or is it the head unit that does that? That would make things way easyer
Gotcha.
Are you using the RA moonlights. I believe those can be used with either signal. Either way there's jumpers in your relay box to switch them. Yes you can wait till you get a second relay box and have that be pwm. You would just need to swap that relay box to the primary as the dimming channels on additional boxes are not able to be used.
troylong45
O I can change my current relay box to pwm with a jumper I'll do that then.
No on the ra moons I'm swapping out my sb boards with the 3ch models and getting pwm dimmable drivers for each one. Mike can't find me a anolog one so pmw it has to be lol. But this will make life easyer then swapping code around.
The tidal swell that makes the pumps follow the moon cycles and tides right?
Tide class not Tidal Swell mode. You need to declare a new Tide and set the parameters for it, then you can set your DCPump speed accordinly.
troylong45
got a error did i past in right area
  • sketch_apr24a.cpp: In function 'void loop()':
    sketch_apr24a:155: error: 'actRiseH' was not declared in this scope
    sketch_apr24a:155: error: 'actRiseM' was not declared in this scope
    sketch_apr24a:155: error: 'actSetH' was not declared in this scope
    sketch_apr24a:155: error: 'actSetM' was not declared in this scope
        #include <Tide.h>
        #include <Moon.h>
        // Custom menus
        #define Return             1
        #define Heater             2
        #define WhiteLeft          3
        #define BlueLeft           4
        #define BlueRight          6
        #define Skimmer            8
        // Custom classes
        SunLocation sun;
        Tide tide;
        int ScreenID=1;
            init_memory();
          LEDPresets();
          UpdateLED();
          moon_init(21,-73);
        void SetSun() {
            acclDay--;
          // End acclimation
            case 0: {
              // Daylights
              // Actinics
              break;
            case 1: {
              // Daylights
              // Actinics
              break;
          case 2: {
              // Daylights
              // Actinics
              break;
          case 3: {
              // Daylights
              // Actinics
              break;
              // Daylights
              // Actinics
              break;
          if (acclDay > 0) {
            float endPerc;
        void LEDPresets() {
            lastPreset=1;
            lastPreset=2;
            lastPreset=3;
            lastPreset=4;
            lastPreset=5;
            lastPreset=6;
            lastPreset=7;
            lastPreset=8;
            lastPreset=9;
            ActinicPWMValue1=0;
            ActinicPWMValue3=0;
            lastPreset=10;
            ActinicPWMValue1=0;
            ActinicPWMValue3=0;
            lastPreset=11;
            lastPreset=12;
        void UpdateLED() {
        // Menu Code
        void MenuEntry1() {
        void MenuEntry2() {
        void MenuEntry3() {
        void MenuEntry4() {
        void MenuEntry5() {
        void MenuEntry6() {
          // Main Header
          // Param Header
          DrawParams(5,14);
          switch (ScreenID) {
            case 0:
              break;
          // Draw Relays
          DrawRelays(12,94);
          // Date+Time
          if (ScreenID==0)
          char buf[16];
          // Temp and PH
          y+=2;
          y+=6;
          y+=5;
          int t=x;
          y+=12;
          if (acclDay > 0) {
          char buf[16];
          int t=x;
          y+=2;
          y+=15; x=t;
          // Draw Relays
         void CheckCloud()
            #else
            #endif
                  if (cloudchance)
              if (cloudchance)
                  case Calm:
                    break;
                  case Mega:
                      // Send the trigger
                      Strike();
                    break;
                  case Mega2:
                      Strike();
                    break;
                  case Fast:
                      Strike();
                    break;
                  case Slow:
                        DaylightPWMValue=0;
                      delay(1);
                    break;
                  default:
                    break;
                  cloudindex++;
                  int x=0;
                  else x=17;
                  else x=35;
                  int x=0;
                  else x=57;
                  else x=75;
            void Strike()
                // Flash on
                int newdata=4095;
              cstart*=60;
              cend*=60;
Sorry change the actRiseH to Moon.riseH etc
troylong45
Ok lol I thought so. I was looking at your code and was thinking tanking out parts like I did last time I really like the way u have a lot of stuff in memory. But I think I gotta look more and edit it a bit
troylong45
here is a remake of code for mine edited from yours but i keep getting errors
sketch_apr24a_with_error.cpp: In function 'void SetTide()':
sketch_apr24a_with_error:546: error: 'vtSpeed' was not declared in this scope
sketch_apr24a_with_error:549: error: 'Var_Tide' was not declared in this scope
sketch_apr24a_with_error.cpp: At global scope:
sketch_apr24a_with_error:566: error: expected declaration before '}' token
not sure how to fix i fixed some that seemed easy to me but i must be missing something
    #include <Tide.h>
    #include <Moon.h>
        // Custom menus
        #define Mem_B_MoonOffset      100
#define Mem_B_TideMin         117
#define Mem_B_TideMax         118
        #define Mem_B_NightSpeed      122
#define Mem_B_TideMode        143
#define Mem_B_MoonMode        170
        #define Mem_B_EnableStorm     178
          InternalMemory.write(Mem_B_MoonOffset,30);
InternalMemory.write(Mem_B_TideMin,10);
InternalMemory.write(Mem_B_TideMax,20);
          InternalMemory.write(Mem_B_NightSpeed,35);
InternalMemory.write(Mem_B_TideMode,0);
InternalMemory.write(Mem_B_MoonMode,1);
          InternalMemory.write(Mem_B_EnableStorm,true);
        #define Return             1
        #define Heater             2
        #define WhiteLeft          3
        #define BlueLeft           4
        #define BlueRight          6
        #define Skimmer            8
        // Custom classes
        SunLocation sun;
Tide tide;
        int ScreenID=1;
            init_memory();
  SetMoon();              // Setup Moon rise/set lighting
  FillInMoon();           // Fill in 5% to 0% gap in main LEDs
  LEDPresets();
  UpdateLED();
  SetTide();              // Set High/Low tide properties
        void SetSun() {
            acclDay--;
          // End acclimation
            case 0: {
              // Daylights
              // Actinics
              break;
            case 1: {
              // Daylights
              // Actinics
              break;
          case 2: {
              // Daylights
              // Actinics
              break;
          case 3: {
              // Daylights
              // Actinics
              break;
          // Daylights
          // Actinics
          break;
    void SetMoon() {
      byte offset=InternalMemory.read(Mem_B_MoonOffset);
      byte startD=InternalMemory.read(Mem_B_PWMSlopeStartD);
      byte endD=InternalMemory.read(Mem_B_PWMSlopeEndD);
      byte timeD=InternalMemory.read(Mem_B_PWMSlopeDurationD);
      byte startA=InternalMemory.read(Mem_B_PWMSlopeStartA);
      byte endA=InternalMemory.read(Mem_B_PWMSlopeEndA);
      byte timeA=InternalMemory.read(Mem_B_PWMSlopeDurationA);
      time_t onTime=ScheduleTime(Moon.riseH, Moon.riseM,0);
      time_t offTime=ScheduleTime(Moon.setH, Moon.setM,0);
      time_t offsetOnTime=ScheduleTime(Moon.riseH, Moon.riseM,0)-(offset*60);
      time_t offsetOffTime=ScheduleTime(Moon.setH, Moon.setM,0)-(offset*60);
      byte actRiseH=(offsetOnTime%SECS_PER_DAY)/SECS_PER_HOUR;
      byte actRiseM=((offsetOnTime%SECS_PER_DAY)%SECS_PER_HOUR)/60;
      byte actSetH=(offsetOffTime%SECS_PER_DAY)/SECS_PER_HOUR;
      byte actSetM=((offsetOffTime%SECS_PER_DAY)%SECS_PER_HOUR)/60;
      static byte mp=MoonPhase();
      if (mp!=MoonPhase()) {
        InternalMemory.write(Mem_B_PWMSlopeEndD,mp);
        InternalMemory.write(Mem_B_PWMSlopeEndA,mp);
        mp=MoonPhase();
      moon_init(InternalMemory.read_int(Mem_I_Latitude), InternalMemory.read_int(Mem_I_Longitude));
      ReefAngel.PWM.SetDaylight(0);
      ReefAngel.PWM.SetActinic(0);
      switch(InternalMemory.read(Mem_B_MoonMode)) {
        case 0: {
          // Daylights
          ReefAngel.PWM.SetDaylightRaw(PWMSlopeHighRes(Moon.riseH,Moon.riseM,Moon.setH,Moon.setM,startA,endA,timeA,0));
          ReefAngel.PWM.SetActinicRaw(PWMSlopeHighRes(actRiseH,actRiseM,actSetH,actSetM,startD,endD,timeD,0));
          break;
        case 1: {
          ReefAngel.PWM.SetDaylightRaw(PWMParabolaHighRes(Moon.riseH,Moon.riseM,Moon.setH,Moon.setM, startA,endA,0));
          ReefAngel.PWM.SetActinicRaw(PWMParabolaHighRes(actRiseH,actRiseM,actSetH,actSetM, startD,endD,0));
          break;
      case 2: {
          ReefAngel.PWM.SetDaylightRaw(PWMSmoothRampHighRes(Moon.riseH,Moon.riseM,Moon.setH,Moon.setM,startA,endA,timeA,0));
          ReefAngel.PWM.SetActinicRaw(PWMSmoothRampHighRes(actRiseH,actRiseM,actSetH,actSetM,startD,endD,timeD,0));
          break;
      case 3: {
          ReefAngel.PWM.SetDaylightRaw(PWMSigmoidHighRes(Moon.riseH,Moon.riseM,Moon.setH,Moon.setM,startA,endA,0));
          ReefAngel.PWM.SetActinicRaw(PWMSigmoidHighRes(actRiseH,actRiseM,actSetH,actSetM,startD,endD,0));
          break;
    void FillInMoon() {
      // Extend the sunrise/sunset to fill in gaps when fixtures shut off.
      int LightsOffPerc=40.95*InternalMemory.read(Mem_B_LightsOffPerc);
      int onTime=NumMins(InternalMemory.StdLightsOnHour_read(),InternalMemory.StdLightsOnMinute_read())-(actinicOffset+(2*lightOffset));
      int offTime=NumMins(InternalMemory.StdLightsOffHour_read(),InternalMemory.StdLightsOffMinute_read())+(actinicOffset+(2*lightOffset));
      int moonVal=ReefAngel.PWM.GetDaylightValueRaw();
      int channelVal=PWMSlopeHighRes(onTime/60,onTime%60,offTime/60,offTime%60,0,100,lightOffset,0);
      if (ReefAngel.PWM.GetChannelValueRaw(1)<=LightsOffPerc && channelVal>ReefAngel.PWM.GetDaylightValueRaw())
        ReefAngel.PWM.SetDaylightRaw(channelVal);
      if (ReefAngel.PWM.GetChannelValueRaw(3)<=LightsOffPerc && channelVal>ReefAngel.PWM.GetActinicValueRaw())
        ReefAngel.PWM.SetActinicRaw(channelVal);
          if (acclDay > 0) {
            float endPerc;
        #define LED_1to1  Box2_Port1
#define LED_2to1  Box2_Port2
#define LED_3to1  Box2_Port3
#define LED_4to1  Box2_Port4
#define LED_BLUE  Box2_Port5
#define LED_WHITE Box2_Port6
#define LED_MOON  Box2_Port7
#define LED_STORM Box2_Port8
  for (int i=Box3_Port1;i<=Box3_Port4;i++) {
void LEDPresets() {
    lastPreset=1;
    lastPreset=2;
    lastPreset=3;
    lastPreset=4;
    lastPreset=5;
    lastPreset=6;
    lastPreset=7;
    lastPreset=8;
    lastPreset=9;
    ActinicPWMValue1=0;
    ActinicPWMValue3=0;
    lastPreset=10;
    ActinicPWMValue1=0;
    ActinicPWMValue3=0;
    lastPreset=11;
    lastPreset=12;
  if (ReefAngel.Relay.isMaskOn(LED_MOON)) {
    if (lastPreset!=13) resetRelayBox(LED_MOON);
    ActinicPWMValue=4095;
    lastPreset=13;
  if (ReefAngel.Relay.isMaskOff(LED_MOON)) {
    if (lastPreset!=14) resetRelayBox(LED_MOON);
    DaylightPWMValue=0;
    ActinicPWMValue=0;
    lastPreset=14;
void UpdateLED() {
void SetTide() {
  byte nightSpeed=InternalMemory.read(Mem_B_NightSpeed);
  byte tideMin=InternalMemory.read(Mem_B_TideMin);
  byte tideMax=InternalMemory.read(Mem_B_TideMax);
  // Set tide offsets
  tide.SetOffset(tideMin, tideMax);
  // Set tide speed. Slope in/out of Night Mode
  tide.SetSpeed(PWMSlope(sun.GetRiseHour()-1,sun.GetRiseMinute(),
    sun.GetSetHour(),sun.GetSetMinute(),nightSpeed+tideMin,vtSpeed,120,nightSpeed+tideMin));
  // Show tide info on portal
  ReefAngel.CustomVar[Var_Tide]=tide.CalcTide();
        // Menu Code
void MenuEntry1() {
void MenuEntry2() {
void MenuEntry3() {
void MenuEntry4() {
void MenuEntry5() {
void MenuEntry6() {
  // Main Header
  // Param Header
  DrawParams(5,14);
  switch (ScreenID) {
    case 0:
      break;
    case 3: { DrawClouds(5,50); break; }
  // Draw Relays
  DrawRelays(12,94);
  // Date+Time
  if (ScreenID==0)
  char buf[16];
  // Temp and PH
  y+=2;
  y+=6;
  y+=5;
  int t=x;
  y+=12;
  if (acclDay > 0) {
  char buf[16];
  int t=x;
  y+=2;
  y+=15; x=t;
  /// Display Moonrise / Moonset
  sprintf(buf, "%02d:%02d", Moon.riseH, Moon.riseM);
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MR:"); x+=21;
  sprintf(buf, "%02d:%02d", Moon.setH, Moon.setM); x+=36;
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MS:"); x+=21;
  ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,buf); x+=36;
  if (Moon.isUp) ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,"@");
    else ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,"_");
  y+=10; x=t;
  // MoonPhase
  ReefAngel.LCD.DrawText(0,255,x,y,"Moon:");
  ReefAngel.LCD.Clear(DefaultBGColor,x+32,y,128,y+8);
  ReefAngel.LCD.DrawText(COLOR_MAGENTA,255,x+32,y,MoonPhaseLabel());
  y+=10; x=t;
  // MoonLight %
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MoonLights:"); x+=68;
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(),DPColor,x,y,1);
  x+=5*(intlength(ReefAngel.PWM.GetDaylightValue())+1);
  ReefAngel.LCD.DrawText(DPColor, DefaultBGColor, x, y, "%");
  // Draw Relays
  y+=12;
  y+=12;
  TempRelay = ReefAngel.Relay.RelayDataE[1];
  TempRelay &= ReefAngel.Relay.RelayMaskOffE[1];
  TempRelay |= ReefAngel.Relay.RelayMaskOnE[1];
// Minimum number of minutes for cloud duration.  Don't use min duration of less than 6
#define Max_Cloud_Duration 10
#define Min_Clouds_per_Day 2
#define Max_Clouds_per_Day 8
#define Start_Cloud_After NumMins(10,00)
#define End_Cloud_Before NumMins(22,00)
#define Lightning_Chance_per_Cloud 65
void CheckCloud()
  byte LightningModes[] = {Slow};
#else
#endif
      // Commenting out to see if it's interfering with our other seed.
      // randomSeed(millis());    // Seed the random number generator
      if (cloudchance)
        // if picked number is greater than Lightning_Chance_per_Cloud, we will not have lightning today
        if (lightningchance>Lightning_Chance_per_Cloud) lightningchance=0;
  if (InternalMemory.read(Mem_B_EnableStorm)) return;
  if (cloudchance)
    if (ReefAngel.Relay.isMaskOff(LED_STORM))      // Change this to whatever port you want to use as a trigger.
      cloudstart = NumMins(hour(), minute());
      ReefAngel.Relay.Auto(LED_STORM);    // Here, too.
      // Increase Blue channel first for better effect and to compensate for drop in Whites
      ActinicPWMValue1=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,ActinicPWMValue1,ActinicPWMValue1+DaylightPWMValue0,180);
      ActinicPWMValue3=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,ActinicPWMValue3,ActinicPWMValue3+DaylightPWMValue2,180);
      DaylightPWMValue0=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,DaylightPWMValue0,0,180);
      DaylightPWMValue2=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,DaylightPWMValue2,0,180);
      case Calm:
        break;
      case Mega:
          // Send the trigger
          Strike();
        break;
      case Mega2:
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
        if (lightningchance && second()%40<8)
          SlowStrike();
        break;
      default:
        break;
      cloudindex++;
  // Cloud ON option - Clouds every minute
  if (ReefAngel.Relay.isMaskOn(LED_STORM) && now()%60<10)
    SlowStrike();
void SlowStrike()
    int r = random(100);
    if (r<20) lightningstatus=1;
      // Let's separate left and right both.
      if (r<14) {
        DaylightPWMValue0=4095;
        DaylightPWMValue2=4095;
        ActinicPWMValue1=4095;
        ActinicPWMValue3=4095;
      } else if (r<17) {
        DaylightPWMValue0=100;
        DaylightPWMValue2=100;
    delay(1);
void DrawClouds(int x, int y)
    ReefAngel.LCD.DrawText(0,255,x,y,"C"); x+=6;
    ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x+=34;
    ReefAngel.LCD.DrawText(0,255,x,y,"L"); x+=6;
    ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x=5;
      int x=0;
      else x=17;
      ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart/60));
      //ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
      else x=35;
      ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart%60));
      //ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
    ReefAngel.LCD.DrawText(0,255,x+85,y,cloudduration);
    //ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
      int x=0;
      if (((cloudstart+(cloudduration/3))/60)>=10) x=51;
      else x=57;
      ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))/60));
      //ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      if (((cloudstart+(cloudduration/3))%60)>=10) x=69;
      else x=75;
        ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))%60)); // Write the minute of the next lightning to a custom variable for the Portal
        //ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
void Strike()
    // Flash on
    int newdata=4095;
    Wire.write(0x8+(4*0));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 0.
    Wire.write(0x8+(4*2));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 2.
    newdata=ReefAngel.PWM.GetChannelValueRaw(2);   // Use the channel number you're flashing here
  cstart*=60;
  cend*=60;
int ReversePWMSlopeHighRes(long cstart,long cend,int PWMStart,int PWMEnd, byte clength)
  cstart*=60;
  cend*=60;
You copied my SetTide function but I have those variables (vtSpeed and Var_Tide) set in global. You have to either declare them or replace that with what you want.
You missed a } somewhere.
troylong45
are these vortech settings ? isthat what they are
troylong45
ok i added the
// Vortech Variables
byte vtMode, vtSpeed, vtDuration; from yours but what is that? can i set up dc pump in its place .
if you have time does the code look like moon/tide/ and the pumps will run in sync ,and produce more natural effects of the ocean,(like tides and flow throughout the day and night) and lunar cycle like this?
    #include <Tide.h>
    #include <Moon.h>
        // Custom menus
        #define Return             1
        #define Heater             2
        #define WhiteLeft          3
        #define BlueLeft           4
        #define BlueRight          6
        #define Skimmer            8
        // Custom classes
        SunLocation sun;
Tide tide;
        int ScreenID=1;
            init_memory();
  LEDPresets();
  UpdateLED();
        void SetSun() {
            acclDay--;
          // End acclimation
            case 0: {
              // Daylights
              // Actinics
              break;
            case 1: {
              // Daylights
              // Actinics
              break;
          case 2: {
              // Daylights
              // Actinics
              break;
          case 3: {
              // Daylights
              // Actinics
              break;
          // Daylights
          // Actinics
          break;
    void SetMoon() {
        mp=MoonPhase();
        case 0: {
          // Daylights
          break;
        case 1: {
          break;
      case 2: {
          break;
      case 3: {
          break;
    void FillInMoon() {
          if (acclDay > 0) {
            float endPerc;
void LEDPresets() {
    lastPreset=1;
    lastPreset=2;
    lastPreset=3;
    lastPreset=4;
    lastPreset=5;
    lastPreset=6;
    lastPreset=7;
    lastPreset=8;
    lastPreset=9;
    ActinicPWMValue1=0;
    ActinicPWMValue3=0;
    lastPreset=10;
    ActinicPWMValue1=0;
    ActinicPWMValue3=0;
    lastPreset=11;
    lastPreset=12;
    lastPreset=13;
    DaylightPWMValue=0;
    ActinicPWMValue=0;
    lastPreset=14;
void UpdateLED() {
void SetTide() {
  // Set tide offsets
        // Menu Code
void MenuEntry1() {
void MenuEntry2() {
void MenuEntry3() {
void MenuEntry4() {
void MenuEntry5() {
void MenuEntry6() {
  // Main Header
  // Param Header
  DrawParams(5,14);
  switch (ScreenID) {
    case 0:
      break;
  // Draw Relays
  DrawRelays(12,94);
  // Date+Time
  if (ScreenID==0)
  char buf[16];
  // Temp and PH
  y+=2;
  y+=6;
  y+=5;
  int t=x;
  y+=12;
  if (acclDay > 0) {
  char buf[16];
  int t=x;
  y+=2;
  y+=15; x=t;
  y+=10; x=t;
  // MoonPhase
  y+=10; x=t;
  // MoonLight %
  // Draw Relays
  y+=12;
  y+=12;
void CheckCloud()
#else
#endif
      if (cloudchance)
  if (cloudchance)
      case Calm:
        break;
      case Mega:
          // Send the trigger
          Strike();
        break;
      case Mega2:
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
          SlowStrike();
        break;
      default:
        break;
      cloudindex++;
    SlowStrike();
void SlowStrike()
      if (r<14) {
      } else if (r<17) {
    delay(1);
      int x=0;
      else x=17;
      else x=35;
      int x=0;
      else x=57;
      else x=75;
void Strike()
    // Flash on
    int newdata=4095;
  cstart*=60;
  cend*=60;
  cstart*=60;
  cend*=60;
troylong45
ok i got moon working ok looks like but the tide was not working i copied you vortec and tide code and i went in and changed everything from rf to dcpump will that work and every thing
I have one jabeo on dimming expansion channel 4 and one on channel 5
    #include <Tide.h>
    #include <Moon.h>
        // Custom menus
        #define Mem_B_RandomMode      168
        #define Mem_B_PumpOffset      119
        #define Mem_B_FeedingDCPump       120
        #define Mem_B_NightDCPump         121
        #define Mem_B_NightDuration   123
        #define Mem_B_NTMSpeed        124
        #define Mem_B_NTMDuration     125
        #define Mem_B_NTMDelay        126
        #define Mem_B_NTMTime         127
        #define Mem_B_GyreOffset      169
        #define Mem_B_FeedingSpeed    172
        #define Mem_B_WCSpeed         173
        #define Mem_B_ForceRandomTide 179
          InternalMemory.write(Mem_B_PumpOffset,80);
          InternalMemory.write(Mem_B_FeedingDCPump,true);
          InternalMemory.write(Mem_B_NightDCPump,false);
          InternalMemory.write(Mem_B_NightDuration,16);
          InternalMemory.write(Mem_B_NTMSpeed,60);
          InternalMemory.write(Mem_B_NTMDuration,5);
          InternalMemory.write(Mem_B_NTMDelay,15);
          InternalMemory.write(Mem_B_NTMTime,150);
          InternalMemory.write(Mem_B_FeedingSpeed,3);
          InternalMemory.write(Mem_B_RandomMode,false);
          InternalMemory.write(Mem_B_GyreOffset,10);
          InternalMemory.write(Mem_B_WCSpeed,25);
        #define Var_Tide         4
        #define Var_TideMode     5
        #define Return             1
        #define Heater             2
        #define WhiteLeft          3
        #define BlueLeft           4
        #define BlueRight          6
        #define Skimmer            8
        // Custom classes
        SunLocation sun;
        Tide tide;
        // Jebao Variables
        byte DCPumpMode, DCPumpSpeed, DCPumpDuration;
        int ScreenID=1;
       randomSeed(now()/SECS_PER_DAY);
            init_memory();
        ReefAngel.DCPump.ExpansionChannel[4] = AntiSync; // Left Jebao RW4
          LEDPresets();
          UpdateLED();
          SetDCPump();                // Set Vortech modes
        void SetSun() {
            acclDay--;
          // End acclimation
            case 0: {
              // Daylights
              // Actinics
              break;
            case 1: {
              // Daylights
              // Actinics
              break;
          case 2: {
              // Daylights
              // Actinics
              break;
          case 3: {
              // Daylights
              // Actinics
              break;
          // Daylights
          // Actinics
          break;
    void SetMoon() {
        mp=MoonPhase();
        case 0: {
          // Daylights
          break;
        case 1: {
          break;
      case 2: {
          break;
      case 3: {
          break;
    void FillInMoon() {
          if (acclDay > 0) {
            float endPerc;
  for (int i=Box2_Port1;i<=Box2_Port4;i++) {
void LEDPresets() {
    lastPreset=1;
    lastPreset=2;
    lastPreset=3;
    lastPreset=4;
    lastPreset=5;
    lastPreset=6;
    lastPreset=7;
    lastPreset=8;
    lastPreset=9;
    ActinicPWMValue1=0;
    ActinicPWMValue3=0;
    lastPreset=10;
    ActinicPWMValue1=0;
    ActinicPWMValue3=0;
    lastPreset=11;
    lastPreset=12;
    lastPreset=13;
    DaylightPWMValue=0;
    ActinicPWMValue=0;
    lastPreset=14;
void UpdateLED() {
void SetTide() {
  // Set tide offsets
    sun.GetSetHour(),sun.GetSetMinute(),nightSpeed+tideMin,DCPumpSpeed,120,nightSpeed+tideMin));
void SetDCPump() {
  int ntmDelay=InternalMemory.read(Mem_B_NTMDelay)*60;
  int ntmTime=InternalMemory.read(Mem_B_NTMTime)*60;
  boolean nightDCPump=InternalMemory.read(Mem_B_NightDCPump);
  boolean feedingDCPump=InternalMemory.read(Mem_B_FeedingDCPump);
  static time_t t;
  ReefAngel.DCPump.FeedingSpeed=InternalMemory.read(Mem_B_FeedingSpeed);
  ReefAngel.DCPump.WaterChangeSpeed=InternalMemory.read(Mem_B_WCSpeed);
  DCPumpMode=InternalMemory.DCPumpMode_read();
  DCPumpSpeed=InternalMemory.DCPumpSpeed_read();
  DCPumpDuration=InternalMemory.DCPumpDuration_read();
  if ((now()-t > ntmDelay && now()-t < ntmTime+ntmDelay) && feedingDCPump) {
    // Post feeding mode
    DCPumpMode=Smart_NTM;
    DCPumpSpeed=InternalMemory.read(Mem_B_NTMSpeed);
    DCPumpDuration=InternalMemory.read(Mem_B_NTMDuration);
  } else if (!sun.IsDaytime() && nightDCPump) {
    DCPumpMode=Night;
    DCPumpSpeed=InternalMemory.read(Mem_B_NightSpeed);
    DCPumpDuration=InternalMemory.read(Mem_B_NightDuration);
    if (DCPumpMode!=Night && ReefAngel.DCPump.Mode==Night)
      ReefAngel.DCPump.SetMode(Night_Stop,0,0);
  if (ReefAngel.DisplayedMenu==FEEDING_MODE) {
    t=now(); // Run post feeding mode when this counter stops
  } else if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) {
    // Not needed anymore.
    // ReefAngel.DCPump.SetMode(Constant,25,0);
    if ((DCPumpMode==Smart_NTM) || (DCPumpMode==ShortPulse)) DCPumpDuration=InternalMemory.read(Mem_B_NTMDuration);
    (DCPumpMode==Custom) ? DCPumpCustom() : ReefAngel.DCPump.SetMode(DCPumpMode,DCPumpSpeed,DCPumpDuration);
void DCPumpCustom() {
  static boolean changeMode;
  byte rcSpeed, rcSpeedAS;
  // Define new modes
  const int BHazard=15;
  const int RA_ReefCrest=16;
  const int RA_Lagoon=17;
  const int RA_TidalSwell=18;
  const int RA_Smart_NTM=19;
  const int RA_ShortPulse=20;
  const int RA_LongPulse=21;
  byte tideSpeed=tide.CalcTide();
  byte tideMode=InternalMemory.read(Mem_B_TideMode);
  float pumpOffset=(float) InternalMemory.read(Mem_B_PumpOffset)/100;
  byte RandomModes[]={ ReefCrest, TidalSwell, Smart_NTM, Lagoon, ShortPulse, LongPulse, BHazard, Else, Sine, Constant };
//  if (now()%SECS_PER_DAY!=0 && InternalMemory.read(Mem_B_RandomMode)) changeMode=true;
//  if (now()%SECS_PER_DAY==0 && changeMode) {
  if (now()%(6*SECS_PER_HOUR)!=10 && InternalMemory.read(Mem_B_RandomMode)) changeMode=true;
  if (now()%(6*SECS_PER_HOUR)==10 && changeMode) {
    tideMode=random(100)%sizeof(RandomModes);
    InternalMemory.write(Mem_B_TideMode,tideMode);
    changeMode=false;
  // Choose another random mode if triggered
  if (InternalMemory.read(Mem_B_ForceRandomTide)) {
    InternalMemory.write(Mem_B_ForceRandomTide,false);
  ReefAngel.CustomVar[Var_TideMode]=tideMode+1;
  switch (RandomModes[tideMode]) {
    case ReefCrest: {
      ReefAngel.DCPump.SetMode(ReefCrest,tideSpeed,DCPumpDuration);
      return;
      break;
    case Lagoon: {
      ReefAngel.DCPump.SetMode(Lagoon,tideSpeed,DCPumpDuration);
      return;
      break;
    case TidalSwell: {
      ReefAngel.DCPump.SetMode(TidalSwell,tideSpeed,DCPumpDuration);
      return;
      break;
    case Smart_NTM: {
      ReefAngel.DCPump.SetMode(Smart_NTM,tideSpeed,DCPumpDuration);
      return;
      break;
    case ShortPulse: {
      ReefAngel.DCPump.SetMode(ShortPulse,tideSpeed,DCPumpDuration);
      return;
      break;
    case LongPulse: {
      ReefAngel.DCPump.SetMode(LongPulse,tideSpeed,DCPumpDuration);
      return;
      break;
    case RA_ReefCrest: {
      rcSpeed=ReefCrestMode(tideSpeed,DCPumpDuration*2,true);
      rcSpeedAS=ReefCrestMode(tideSpeed,DCPumpDuration*2,false);
      break;
    case RA_Lagoon: {
      rcSpeed=ReefCrestMode(tideSpeed,DCPumpDuration,true);
      rcSpeedAS=ReefCrestMode(tideSpeed,DCPumpDuration,false);
      break;
    case RA_TidalSwell: {
      rcSpeed=TidalSwellMode(tideSpeed,true);
      rcSpeedAS=TidalSwellMode(tideSpeed,false);
      break;
    case RA_Smart_NTM: {
      rcSpeed=NutrientTransportMode(0,tideSpeed,DCPumpDuration*50,true);
      rcSpeedAS=NutrientTransportMode(0,tideSpeed,DCPumpDuration*50,false);
      break;
    case RA_ShortPulse: {
      rcSpeed=ShortPulseMode(0,tideSpeed,DCPumpDuration*50,true);
      rcSpeedAS=ShortPulseMode(0,tideSpeed,DCPumpDuration*50,false);
      break;
    case RA_LongPulse: {
      rcSpeed=LongPulseMode(0,tideSpeed,DCPumpDuration,true);
      rcSpeedAS=LongPulseMode(0,tideSpeed,DCPumpDuration,false);
      break;
    case Else: {
      rcSpeed=ElseMode(tideSpeed,DCPumpDuration*2,true);
      rcSpeedAS=ElseMode(tideSpeed,DCPumpDuration*2,false);
      break;
    case BHazard: {
      rcSpeed=millis()%1200>800?tideSpeed:0;
      rcSpeedAS=millis()%1200<400?0:tideSpeed;
      break;
    case Sine: {
      rcSpeed=SineMode(tideSpeed-tideMin,tideSpeed+tideMin,DCPumpDuration*100,true);
      rcSpeedAS=SineMode(tideSpeed-tideMin,tideSpeed+tideMin,DCPumpDuration*100,false);
      break;
    default: {
      rcSpeed=tideSpeed;
      rcSpeedAS=tideSpeed;
      pumpOffset=(float) InternalMemory.read(Mem_B_GyreOffset)/100;
  ReefAngel.DCPump.SetMode(Custom,rcSpeedAS*pumpOffset,tide.isOutgoing());
  ReefAngel.DCPump.SetMode(Custom,rcSpeed,tide.isIncoming());
void NextDCPumpMode() {
      DCPumpMode++;
      if (DCPumpMode > 12) {
        DCPumpMode=0;
        DCPumpSpeed=50; // Constant
      } else if (DCPumpMode == 1) {
        DCPumpSpeed=40; // Lagoon
      } else if (DCPumpMode == 2) {
        DCPumpSpeed=45; // Reef Crest
      } else if (DCPumpMode == 3) {
        DCPumpSpeed=55; DCPumpDuration=10; // Short Pulse
      } else if (DCPumpMode == 4) {
        DCPumpSpeed=55; DCPumpDuration=20; // Long Pulse
      } else if (DCPumpMode == 5) {
        DCPumpDuration=InternalMemory.read(Mem_B_NTMDuration); // Smart_NTM
      } else if (DCPumpMode == 6) {
        DCPumpSpeed=50; DCPumpDuration=10; // Smart_TSM
      } else if (DCPumpMode == 7) {
        DCPumpMode=9; // Night
      } else if (DCPumpMode == 10) {
        DCPumpSpeed=65; DCPumpDuration=5; // Storm
      } else if (DCPumpMode == 11) {
        DCPumpSpeed=45; DCPumpDuration=10; // Custom
      if (DCPumpMode!=InternalMemory.DCPumpMode_read())
        InternalMemory.DCPumpMode_write(DCPumpMode);
      if (DCPumpSpeed!=InternalMemory.DCPumpSpeed_read())
        InternalMemory.DCPumpSpeed_write(DCPumpSpeed);
      if (DCPumpDuration!=InternalMemory.DCPumpDuration_read())
        InternalMemory.DCPumpDuration_write(DCPumpDuration);
        // Menu Code
void MenuEntry1() {
void MenuEntry2() {
void MenuEntry3() {
    void MenuEntry4() {
      NextDCPumpMode();
void MenuEntry5() {
void MenuEntry6() {
void MenuEntry7() {
  // Main Header
  // Param Header
  DrawParams(5,14);
  switch (ScreenID) {
    case 0:
      break;
  // Draw Relays
  DrawRelays(12,94);
  // Date+Time
  if (ScreenID==0)
  char buf[16];
  // Temp and PH
  y+=2;
  y+=6;
  y+=5;
  int t=x;
  y+=12;
  if (acclDay > 0) {
  char buf[16];
  int t=x;
  y+=2;
  y+=15; x=t;
  y+=10; x=t;
  // MoonPhase
  y+=10; x=t;
  // MoonLight %
  // Draw Relays
  y+=12;
  y+=12;
void CheckCloud()
#else
#endif
      if (cloudchance)
  if (cloudchance)
      case Calm:
        break;
      case Mega:
          // Send the trigger
          Strike();
        break;
      case Mega2:
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
          SlowStrike();
        break;
      default:
        break;
      cloudindex++;
    SlowStrike();
void SlowStrike()
      if (r<14) {
      } else if (r<17) {
    delay(1);
      int x=0;
      else x=17;
      else x=35;
      int x=0;
      else x=57;
      else x=75;
void Strike()
    // Flash on
    int newdata=4095;
  cstart*=60;
  cend*=60;
  cstart*=60;
  cend*=60;
