coding to memory for jebao pumps
Ask in here.
Civics14
Post by Civics14 »
How do I code to memory so I can test out different modes, but at the same time be able to revert back to my custom schedule?
    ReefAngel.PHMin=511;
    ReefAngel.PHMax=760;
    InternalMemory.DCPumpThreshold_write(15);
    ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port2Bit | Port3Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port7Bit | Port8Bit;
    // Use T3 probe as temperature and overheat functions
    InternalMemory.OverheatTemp_write( 835 );
    ReefAngel.DCPump.FeedingSpeed=16;
    ReefAngel.Relay.On( Port2 ); //Dimming Module
    ReefAngel.Relay.On( Port4 ); //Jebao DP4
    ReefAngel.Relay.On( Port5 );
    ReefAngel.StandardHeater( Port1,780,790 );
    ReefAngel.StandardLights( Port3,12,00,22,00 ); // Secondary Pump
    ReefAngel.StandardLights( Port7,0,30,10,30 ); // Fuge Lamp
    ////// Light Schedule Below
          //Set Channel 0 LED RED
          if (PWMSlope(13,15,22,45,5,85,120,5)<=6)
            ReefAngel.PWM.SetChannel( 0, 0);
            ReefAngel.PWM.SetChannel( 3, 0);
            ReefAngel.PWM.SetChannel( 0, PWMSlope(13,15,22,45,5,85,120,5) );
            ReefAngel.PWM.SetChannel( 3, PWMSlope(13,15,22,45,5,85,120,5) );
          //Set Channel 1 LED WHITE
          if (PWMSlope(13,30,22,30,5,80,120,5)<=6)
            ReefAngel.PWM.SetChannel( 1, 0);
            ReefAngel.PWM.SetChannel( 4, 0);
            ReefAngel.PWM.SetChannel( 1, PWMSlope(13,30,22,30,5,80,120,5) );
            ReefAngel.PWM.SetChannel( 4, PWMSlope(13,30,22,30,5,80,120,5) );
          //Set Channel 2 LED BLUE
          if (PWMSlope(13,0,23,0,5,100,120,5)<=6)
            ReefAngel.PWM.SetChannel( 2,0);
            ReefAngel.PWM.SetChannel( 5,0);
            ReefAngel.PWM.SetChannel( 2, PWMSlope(13,0,23,0,5,100,120,5) );
            ReefAngel.PWM.SetChannel( 5, PWMSlope(13,0,23,0,5,100,120,5) );
   ////// End of Light Schedule
  //Setting Jebao Pump Wave Patterns
  if (hour()>=12 && hour()<13 ) // Morning mode between 12pm and 1pm
    ReefAngel.DCPump.SetMode(ReefCrest,40,20 );
     else if (hour()>=13 && hour()<15) // Day mode between 1m and 3pm
    ReefAngel.DCPump.SetMode( ReefCrest,50,25 );
     else if (hour()>=15 && hour()<20) // Day mode between 3pm and 8pm
    ReefAngel.DCPump.SetMode( ReefCrest,75,25 );
     else if (hour()>=20 && hour()<21) // Evening mode between 8pm and 9pm
    ReefAngel.DCPump.SetMode( ReefCrest,60,15 );
     else if (hour()>=21 && hour()<23) //Calming beween 9pm and 11pm
    ReefAngel.DCPump.SetMode( ReefCrest,40,20 );
    ReefAngel.DCPump.SetMode( ReefCrest,40,10 );  // Night Mode between 11pm and l2pm
    ReefAngel.DCPump.ActinicChannel = AntiSync; //use None when inactivated
    ReefAngel.Portal( "civics14" );
Re: coding to memory for jebao pumps
Try this. Go to the portal and set it to "Custom" to run your schedule. Otherwise, it will run whatever mode you select.
  if (InternalMemory.DCPumpMode_read()==11)   // If custom mode on Portal
  else ReefAngel.DCPump.UseMemory = true;    //  If it's not custom mode on the portal, then do what mode the portal says.
Civics14
Post by Civics14 »
I'll try when I get home. Thanks as always.
Civics14
Post by Civics14 »
That didn't work, any other suggestions? It stayed on internal memory
Oops, forgot a line. I edited the post above. It should work now.
Here's the exact code I use, for future reference.
void PumpControl()
  // *******************  Pump Control *******************
    ReefAngel.DCPump.UseMemory = false;    // Turn off memory control
    ReefAngel.DCPump.SetMode(Else,60,30);  // If nothing changes it in the next few lines, this is what runs.
    ReefAngel.DCPump.Threshold=20;
    if (hour()>=22 || hour()<9) ReefAngel.DCPump.SetMode(Gyre,80,30,50);  // Gyre max, duration, minimum
    if (hour()>=9 && hour()<10) ReefAngel.DCPump.SetMode(Gyre,90,30,60);  // Gyre max, duration, minimum
    if (hour()>=10 && hour()<11)
      ReefAngel.DCPump.SetMode(Else,40,20);    // Else mode from 1000 to 1100.  Wake up!
Civics14
Post by Civics14 »
i think that did the trick. just to confirm, when i select custom, i'm assuming after it goes through the loop, it changes the selection based on the programming and it no longer is "custom" per say.
It will run whatever mode is selected on the portal. If you set it to "custom" on the portal then it will run what is programmed in your code. So, for everyday use, leave it on custom. If you want to try a different waveform, then set it to whatever wave you want.
Civics14
Post by Civics14 »
Thank you very much. Every thing works!!
You're welcome!
saf1
Post by saf1 »
Cosmith71 - Is that a standard feature of using ReefAngel.DCPump.UseMemory = true or your custom code block?
If that is a feature of setting use memory to true that is slick.
Yep, assuming you have your ports set to sync or antisync, then setting UseMemory to true will do what the portal (or the app) tells it to.
