Cosmith71 - Is that a standard feature of using ReefAngel.DCPump.UseMemory = true or your custom code block?
If that is a feature of setting use memory to true that is slick.
coding to memory for jebao pumps
Re: coding to memory for jebao pumps
Yep, assuming you have your ports set to sync or antisync, then setting UseMemory to true will do what the portal (or the app) tells it to.
