Virtual Ports quit working
Posted: Thu May 05, 2016 6:16 am
So I reduced my dose time on my pumps to 60s from 240s. Had them trigger a virtual port so I could get an email notice when they triggerred.
Now the Virtual ports are not triggerring and no email notices being sent. Part of code attached.
LMK if anything stands out:
//Code to make Vodka Dosing Work one time a day for 2 mins
//COmment our 05.02.16
//Turn on at 8:00 AM
/// ReefAngel.DosingPumpRepeat(Box1_Port6,480,1440,120);
///Code to make Vinegar Dosing Work 4 mins
///02.15.16 = Changed to dosing Amino Acid every 3 hrs for 2 mins, on top of hours
///02.2616 = Changed to dosing Amino Acid every 3 hrs for 4 mins, on 15 of hour
///05.02.16 = Changed to dosing Amino Acid every 3 hrs for 1 mins, on 15 of hour
///Start at 12:00AM
ReefAngel.DosingPumpRepeat(Box1_Port8,0,180,60);
///Do not turn on Vinegar if lights are off
///02-15-16 = Changed to Dosing AA throughout the day
/// if (hour()<=8 || hour()>21) {
/// ReefAngel.Relay.Off(Box1_Port8);
//Code to make Magnesium Dosing Work
///02.15.16 = Changed to dosing Amino Acid every 3 hrs for 2 mins, on 15 of hour
///05.02.16 = Changed to dosing Amino Acid every 3 hrs for 1 min, on 15 of hour
///Start at 12:15AM
ReefAngel.DosingPumpRepeat(Box1_Port4,15,180,60);
//Code to check that the dosing pumps are running
// ******************* Turn on imaginary relays for 5 minutes when dosing pumps activate so Portal can track them *******************
// Vinegar port
if (ReefAngel.Relay.Status(Box1_Port8) && LastUpdate1==0)
LastUpdate1 = now();
ReefAngel.Relay.On (Box2_Port1);
if (now() - LastUpdate1 >= 300 && LastUpdate1 != 0)
LastUpdate1 = 0;
ReefAngel.Relay.Off (Box2_Port1);
// Magnesium Port
if (ReefAngel.Relay.Status(Box1_Port4) && LastUpdate2==0)
LastUpdate2 = now();
ReefAngel.Relay.On (Box2_Port2);
if (now() - LastUpdate2 >= 300 && LastUpdate2 != 0)
LastUpdate2 = 0;
ReefAngel.Relay.Off (Box2_Port2);
// ATO Port
if (ReefAngel.Relay.Status(Box1_Port7) && LastUpdate3==0)
LastUpdate3 = now();
ReefAngel.Relay.On (Box2_Port3);
if (now() - LastUpdate3 >= 300 && LastUpdate3 != 0)
LastUpdate3 = 0;
ReefAngel.Relay.Off (Box2_Port3);
// Vodka Port
if (ReefAngel.Relay.Status(Box1_Port6) && LastUpdate4==0)
LastUpdate4 = now();
ReefAngel.Relay.On (Box2_Port4);
if (now() - LastUpdate4 >= 300 && LastUpdate4 != 0)
LastUpdate4 = 0;
ReefAngel.Relay.Off (Box2_Port4);
