ATO and Multi-Level Water Sensor
PostPosted: Mon May 09, 2016 5:51 am
Was messing around with ATO code as I noticed something funny.
It is not firing like I expected. The ATO fires between 28%- 30%. Not sure if it is mechanical or in the code.
Any ideas?
         if (ReefAngel.WaterLevel.GetLevel(4)<=25)
        }else if (ReefAngel.WaterLevel.GetLevel(4)>30){
          ReefAngel.Relay.Off(Box1_Port7);
Tried this too:
        if (ReefAngel.WaterLevel.GetLevel(4)<=25)  ReefAngel.Relay.On(Box1_Port7);
        if (ReefAngel.WaterLevel.GetLevel(4)>30)  ReefAngel.Relay.Off(Box1_Port7);        }
Same result.
HELP! The relay is firing like every 15 minutes.
PostPosted: Mon May 09, 2016 5:54 am
Tried to lower the threshold to < 22% and it still fired at 28%. This is why I think it may not be a mechanical problem.
PostPosted: Mon May 09, 2016 8:34 am
There's gotta be something else in the code.
Can you post everything?
PostPosted: Mon May 09, 2016 9:06 am
Thanks Roberto. This has been killing me this weekend
    unsigned long LastUpdate1=0;    // For virtual Vinegar dosing pumps
    unsigned long LastUpdate2=0;    // For virtual Magnesium dosing pumps
    unsigned long LastUpdate3=0;    // For virtual ATO dosing pump
    unsigned long LastUpdate4=0;    // For virtual VODKA dosing pump
        ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
        ReefAngel.AddWaterLevelExpansion();  // Water Level Expansion Module
        ReefAngel.FeedingModePortsE[0] = Port1Bit;
        ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port7Bit | Port8Bit;
        ReefAngel.WaterChangePortsE[0] = Port1Bit | Port3Bit | Port5Bit | Port7Bit;
        ReefAngel.Relay.On( Port2 );
        ReefAngel.Relay.On( Port3 );
        ReefAngel.Relay.On( Port4 );
        ReefAngel.StandardHeater( Port7,750,755 );
        ReefAngel.StandardFan( Port8,760,800 );
        ReefAngel.Relay.DelayedOn( Box1_Port1,15);
        ReefAngel.StandardLights( Box1_Port3,20,0,8,0 );
        //ReefAngel.WaterLevelATO( Box1_Port7,60,48,50 );
        ReefAngel.RF.SetMode(Constant,75,1);
        //Use salinity compensation
        ReefAngel.Salinity.SetCompensation(0);
        //Only use the ATO when no one is in house and there is water in reservior - taken out so runs 24/7
        //Use Channel 4&2 as Redundant Controls.
        // Take out ATO tank check 05.02.16
        //if (ReefAngel.WaterLevel.GetLevel(4)<= 25 && ReefAngel.WaterLevel.GetLevel(1)>0) ReefAngel.Relay.On(Box1_Port7);
    //Turn-off Skimmer whhen skimmer tank is full
        if (ReefAngel.WaterLevel.GetLevel(3)>=90)
          ReefAngel.Relay.Off(Box1_Port1);
        }else{
    //How about some WaveMotion with the Vortech
        static time_t feeding;
    // Time schedule first
    //Wave PatternslseDuration, boolean PulseSync);
    //byte GyreMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync);
    //byte SineMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync);
    //byte ReefCrestMode(byte WaveSpeed, byte WaveOffset, boolean PulseSync);
    //byte NutrientTransportMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync);
    //byte TidalSwellMode(byte WaveMaxSpeed, boolean PulseSync);
    //byte TideMode(byte WaveSpeed, byte minOffset, byte maxOffset);
    //byte ElseMode(byte midPoint, byte offset, boolean waveSync);
        if (hour()>=6 && hour()<7) {
          ReefAngel.PWM.SetDaylight( LongPulseMode(35,100,5,true) ); // Long pulse hi/low 50%20% 10s pulse on sync mode
          ReefAngel.PWM.SetActinic( LongPulseMode(35,100,5,false) ); // Long pulse hi/low 50%20% 10s pulse on anti-sync mode
        } else if (hour()>=7 && hour()<8) {
          ReefAngel.PWM.SetDaylight ( ElseMode(80,20, true) ); // Short pulse at 60% with 200m
          ReefAngel.PWM.SetActinic( ElseMode(80,20,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
        } else if (hour()>=8 && hour()<9) {
          ReefAngel.PWM.SetDaylight( SineMode(35,100,180,true)); //Ramp up to 100% in 3mins in sync mode
          ReefAngel.PWM.SetActinic( SineMode(35,100,180,true)); //Ramp up to 100% in 3mins in sync mode
        } else if (hour()>=9 && hour()<10) {
          ReefAngel.PWM.SetDaylight( TidalSwellMode(100,true)); //Ramp up to 100% in 3mins in sync mode
          ReefAngel.PWM.SetActinic( TidalSwellMode(100,false)); //Ramp up to 100% in 3mins in sync mode
        } else if (hour()>=10 && hour()<11) {
          ReefAngel.PWM.SetDaylight( ShortPulseMode(35,100,2000,true) ); // Short pulse at 30% - 100% with 2000ms pulse on sync mode
          ReefAngel.PWM.SetActinic( ShortPulseMode(35,100,2000,false) ); // Short pulse at 30% - 100% with 2000ms pulse on anti-sync mode
        } else if ( (hour()>=11 && hour()<12) && (now()-feeding > SECS_PER_DAY) ) { // We haven't fed today
          ReefAngel.PWM.SetDaylight( NutrientTransportMode(35,100,5000,true) );
          ReefAngel.PWM.SetActinic( NutrientTransportMode(35,100,5000,false) );
        } else if (hour()>=11 && hour()<12) {
          ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 70% +/- 20% on sync mode
          ReefAngel.PWM.SetActinic( ReefCrestMode(80,20,false) ); // ReefCrest at 70% +/- 20% on anti-sync mode
        } else if (hour()>=12 && hour ()<13) {
          ReefAngel.PWM.SetDaylight( ShortPulseMode(35,100,500,true) ); // Short pulse at 60% with 200ms pulse on sync mode
          ReefAngel.PWM.SetActinic( ShortPulseMode(35,90,500,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
        } else if (hour()>=13 && hour ()<14) {
        } else if (hour()>=14 && hour()<15) {
          //ReefAngel.PWM.SetDaylight ( ElseMode( 80,20, true) ); // Short pulse at 60% with 200m
          //ReefAngel.PWM.SetActinic( ElseMode(80,20,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
          ReefAngel.PWM.SetDaylight ( GyreMode( 35, 100, 10, true) ); // Short pulse at 60% with 200m
          ReefAngel.PWM.SetActinic( GyreMode(35,100, 10, true) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
        } else if (hour()>=15 && hour()<16) {
          ReefAngel.PWM.SetDaylight( SineMode(35,100,30,true)); //Ramp up to 70% in 10mins in sync mode
          ReefAngel.PWM.SetActinic( SineMode(35,100,30,true)); //Ramp up to 70% in 10mins in sync mode
        } else if (hour()>=16 && hour()<17) {
          ReefAngel.PWM.SetDaylight( NutrientTransportMode(30,100,250,true) );
          ReefAngel.PWM.SetActinic( NutrientTransportMode(30,100,250,false) );
        } else if (hour()>=17 && hour ()<18) {
          ReefAngel.PWM.SetDaylight( SineMode(35,100,20, true)); //Ramp up to 70% in 10mins in sync mode
          ReefAngel.PWM.SetActinic( SineMode(35,100,20, false)); //Ramp up to 70% in 10mins in sync mode
        } else if (hour()>=18 && hour ()<19) {
        } else if (hour()>=19 && hour ()<20) {
          ReefAngel.PWM.SetDaylight( GyreMode(35,100, 10, true)); //Ramp up to 70% in 10mins in sync mode
          ReefAngel.PWM.SetActinic( GyreMode(35,100, 10, false)); //Ramp up to 70% in 10mins in sync mode
        } else if (hour()>=20 && hour ()<21) {
          ReefAngel.PWM.SetDaylight( GyreMode(35,100, 120, true)); //Ramp up to 70% in 10mins in sync mode
          ReefAngel.PWM.SetActinic( GyreMode(35,100, 120, false)); //Ramp up to 70% in 10mins in sync mode
        } else {
          ReefAngel.PWM.SetDaylight( SineMode(35,100,5,true)); //Ramp up to 70% in 10mins in sync mode
          ReefAngel.PWM.SetActinic( SineMode(35,100,5,true)); //Ramp up to 70% in 10mins in sync mode
    // If we are feeding override the schedule
          ReefAngel.PWM.SetDaylight(35);
          ReefAngel.PWM.SetActinic(35);
          //Vortech
          ReefAngel.RF.SetMode( Constant,50,100 );
          feeding=now();
    // If we have finished feeding, start NTM for 3 hours
        if (now()-feeding < 3*SECS_PER_HOUR)
          ReefAngel.PWM.SetDaylight( NutrientTransportMode(35,100,500,true) );
          ReefAngel.PWM.SetActinic( NutrientTransportMode(35,100,500,false) );
          //vortech
          ReefAngel.RF.SetMode(Smart_NTM,100,10);
    //Do not use the memory bits inside the Vortech
    //Time based Vortech Schedule
    /*Used by the RF Expansion Module
          Vortech Modes
          Constant      0
          Lagoon   1
          ReefCrest   2
          ShortPulse   3
          LongPulse   4
          mart_NTM     5 // Nutrient Transport Mode
          Smart_TSM     6 // Tidal Swell Mode
          Storm         10
          Custom        11
          The function is SetMode(Mode,Speed,Duration) and the parameter are:
          Mode can be one of the following modes:
          * Constant
          * Random1 (Lagoonal)
          * Random2 (Reef Crest)
          * ShortWave (Short Pulse)
          * LongWave (Long Pulse)
          * Smart_NTM (Nutrient Transport Mode)
          * Smart_TSM (Tidal Swell Mode)
          * Storm (will only be available on the upcoming Dev libraries update or by using 10 instead of Storm)
          * Custom (will only be available on the upcoming Dev libraries update or by using 11 instead of Custom)
          Speed is a number from 0 through 100
          Duration is only applicable to ShortWave, LongWave and Smart_NTM and represent the following:
          ShortWave - tenths of a second
          LongWave - seconds
          Smart_NTM - tenths of a second
          The function for Custom mode is SetMode(Mode,Speed,Channel) and the parameter are:
          Mode: Custom
          Channel:
          0 - Sync
          1- Anti-Sync
          2- Back of Tank
          ReefAngel.RF.SetMode(ReefCrest,100,10);
          ReefAngel.RF.SetMode(Smart_TSM,100,0);
          ReefAngel.RF.SetMode(ShortWave,100,100);
        } else if (hour()>=12 && hour()<13) {
          ReefAngel.RF.SetMode(Smart_NTM,100,100);
        } else if (hour()>=13 && hour()<14) {
          ReefAngel.RF.SetMode(Storm,100,1);;
        } else if (hour()>=14 && hour()<15){
          ReefAngel.RF.SetMode(LongWave,100,5);
          ReefAngel.RF.SetMode(Smart_TSM,100,10);
        } else if (hour()>=17 && hour()<18) {
          ReefAngel.RF.SetMode(ShortWave,100,10);
        } else if (hour()>=18 && hour()<19) {
        } else if (hour()>=19 && hour()<20) {
          ReefAngel.RF.SetMode(Storm,100,10);;
        } else if (hour()>=20 && hour()<21){
          ReefAngel.RF.SetMode(LongWave,100,7);
        } else {
          ReefAngel.RF.SetMode(Lagoon,75,10);
          //ReefAngel.RF.SetMode(Storm,100,1);
    //Code to make Vodka Dosing Work one time a day for 2 mins
    //COmment our 05.02.16
    //Turn on at 8:00 AM
    ///    ReefAngel.DosingPumpRepeat(Box1_Port6,480,1440,120);
    ///Code to make Vinegar Dosing Work 4 mins
    ///02.15.16 = Changed to dosing Amino Acid every 3 hrs for 2 mins, on top of hours
    ///02.2616 = Changed to dosing Amino Acid every 3 hrs for 4 mins, on 15 of hour
    ///05.02.16 = Changed to dosing Amino Acid every 3 hrs for 4 mins, on 15 of hour
    ///Start at 12:00AM
    ReefAngel.DosingPumpRepeat(Box1_Port8,0,180,60);
    ///Do not turn on Vinegar if lights are off
    ///02-15-16 = Changed to Dosing AA throughout the day
    ///    if (hour()<=8 || hour()>21) {
    ///      ReefAngel.Relay.Off(Box1_Port8);
    //Code to make Magnesium Dosing Work
    ///02.15.16 = Changed to dosing Amino Acid every 3 hrs for 2 mins, on 15 of hour
    ///05.02.16 = Changed to dosing Amino Acid every 3 hrs for 1 min, on 15 of hour
    ///Start at 12:15AM
    ReefAngel.DosingPumpRepeat(Box1_Port4,15,180,60);
    //Code to check that the dosing pumps are running
    // *******************  Turn on imaginary relays for 5 minutes when dosing pumps activate so Portal can track them  *******************
    // Vinegar port
        if (ReefAngel.Relay.Status(Box1_Port8) && LastUpdate1==0)
          LastUpdate1 = now();
          ReefAngel.Relay.On (Box2_Port1);
        if (now() - LastUpdate1 >= 600 && LastUpdate1 != 0)
          LastUpdate1 = 0;
          ReefAngel.Relay.Off (Box2_Port1);
    // Magnesium Port
        if (ReefAngel.Relay.Status(Box1_Port4) && LastUpdate2==0)
          LastUpdate2 = now();
          ReefAngel.Relay.On (Box2_Port2);
        if (now() - LastUpdate2 >= 600 && LastUpdate2 != 0)
          LastUpdate2 = 0;
          ReefAngel.Relay.Off (Box2_Port2);
    // ATO Port
        if (ReefAngel.Relay.Status(Box1_Port7) && LastUpdate3==0)
          LastUpdate3 = now();
          ReefAngel.Relay.On (Box2_Port3);
        if (now() - LastUpdate3 >= 600 && LastUpdate3 != 0)
          LastUpdate3 = 0;
          ReefAngel.Relay.Off (Box2_Port3);
     // Vodka Port
        if (ReefAngel.Relay.Status(Box1_Port6) && LastUpdate4==0)
          LastUpdate4 = now();
          ReefAngel.Relay.On (Box2_Port4);
        if (now() - LastUpdate4 >= 600 && LastUpdate4 != 0)
          LastUpdate4 = 0;
          ReefAngel.Relay.Off (Box2_Port4);
    // This should always be the last line1
        ReefAngel.Portal("Paul_Velasco");
PostPosted: Mon May 09, 2016 10:02 am
I don't see anything wrong.
Just in case, try changing this:
To this:
        if (ReefAngel.WaterLevel.GetLevel(4)<=25 && ReefAngel.WaterLevel.GetLevel(4)>0)
I see you had that at some point, because there is a commented line similar in your code.
PostPosted: Mon May 09, 2016 5:40 pm
Trying now Roberto. I assume you meant to say 30 not 0 on the code
PostPosted: Mon May 09, 2016 5:41 pm
Just remembered something. This started happening when I updated the library? Been running code for a year and it worked. The only thing I took out was the check on the ATO tank >0
PostPosted: Mon May 09, 2016 6:28 pm
rimai wrote:I don't see anything wrong.
To this:
Hey Roberto the second piece of code is working with the 0. I am at 27% and no ATO doser trigger. I am waiting for it to cycle below 25
PostPosted: Tue May 10, 2016 5:44 am
Just to help other out this worked:
if (ReefAngel.WaterLevel.GetLevel(4)<=25 && ReefAngel.WaterLevel.GetLevel(4)>0)ReefAngel.Relay.On(Box1_Port7);
if (ReefAngel.WaterLevel.GetLevel(4)>30)ReefAngel.Relay.Off(Box1_Port7);
Had to add the last piece >0 for it to fire at <=25.
Confirmed working as the Water Level is going from 30% - 26% every 3 hrs.
Previosly the ATO pump was firing every 15 minutes. The level was only fluctuating from 30% - 28%.
Problem is solved. Thanks Roberto!!!
Return to How do I code ...
Users browsing this forum: Google [Bot] and 2 guests
