I have a pair of Jebaos (WP25 and a PP8) but dont have the module to control them or the cables yet. In the meantime, I'd like to have them come on at alternating intervals (every two minutes they switch or something similar). How would I go about doing this? Right now, they're on relay 8 and box 1 relay 2. Code is below:
ReefAngel.FeedingModePorts = Port1Bit | Port3Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port2Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port2,796,798 );
ReefAngel.StandardLights( Port4,18,0,12,0 );
ReefAngel.StandardLights( Port5,10,0,22,0 );
ReefAngel.StandardLights( Port6,9,30,22,30 );
ReefAngel.StandardATO( Box1_Port1,1200 );
ReefAngel.PWM.SetDaylight( PWMParabola(10,0,22,0,10,10,10) );
ReefAngel.PWM.SetActinic( PWMParabola(10,0,22,0,10,15,10) );
Alternating relays for wavemakers
Re: Alternating relays for wavemakers
Hmm, my confusion seems to stem from only certain ports being available for Wavemaker use; they're greyed out on everything but ports 5 and 6 on both relay boxes. How do I make them alternate (i.e. relay 5 on for 120s and then relay 6 on for 120s)?
Edit: got it figured out
