3 black box (SB Basics) on Dimming Expansion
PostPosted: Sun Jul 17, 2016 3:17 pm
So I finished my wiring, got everything hung, loaded the code, and fired them up. To my delight, they are working, which means I didn't screw anything up, haha. Now, keeping in mind I just got them going about an hour ago, around 5 pm est, I am finding the parabolas are way off from where they should be. Could that be because I need to give it a day to reset overnight and correct itself?
Also, right now, the lefts are higher % than the rights. I know the wiring is correct, so will that correct itself overnight, or is the issue in the code?
Pretty happy so far though! Thank you Lee!!! I set the lights at 12", but I think I may need to lower them 3-4 inches. The tank is euro braced, and I believe I am getting some shadowing around the sides being up that high.
PostPosted: Mon Jul 18, 2016 11:34 am
Ok, I figured out the issue. Adjust the code you supplied a bit. First, I changed my offsets from 30 minutes down to 15 minutes, so ignore the changes in values in that respect, but, I needed to make some of the values negative.
Here is the modified section.
ReefAngel.PWM.Channel0PWMParabola(0,-30);     // Actinic Left
ReefAngel.PWM.Channel2PWMParabola(15,-15);    // Actinic Center
ReefAngel.PWM.Channel4PWMParabola(30,0);     // Actinic Right
ReefAngel.PWM.Channel1PWMParabola(150,-180);  // Daylight Left
ReefAngel.PWM.Channel3PWMParabola(165,-165);  // Daylight Center
ReefAngel.PWM.Channel5PWMParabola(180,-150);  // Daylight Right
I think this is now working as I intended. The other question that has me baffled is that overnight, the actinics set themselves all to 100%. Is this a function of the moonlights somehow? Where would that value have come from?
PostPosted: Mon Jul 18, 2016 5:24 pm
Set them to 0 before your logic. Its taking a default somewhere. Sorry about the negatives.
PostPosted: Mon Jul 18, 2016 5:35 pm
Not sure how/where to do this.
No worries on the negatives. I am still far ahead of where I would be without your assistance.
PostPosted: Mon Jul 18, 2016 10:29 pm
ReefAngel.PWM.SetChannel(0,0);
First arg is channel. Do that for each before the calls to parabola.
PostPosted: Fri Aug 05, 2016 5:17 am
Bump, someone else was looking for the same code
PostPosted: Tue Sep 27, 2016 10:19 am
I am ready to work on my weather modes, but need a lot of help. I am currently using sunrise/sunset, and have not found where clouds and lightning have been incorporated with this, yet.
I also had 1 attempt at using a virtual port to perform a temporary override of the normal light schedule. But it did not work. I have that function commented out in my current code.
Here is my current code:
#include <SunLocation.h>
#include <Tide.h>
#include <Moon.h>
#include <WiFiAlert.h>
  SunLocation sl;
  int avgph[10];
    unsigned long totalavgph=0;
    byte avgindex=0;
      byte x;
      byte y = 2;
      char text[7];
      // *********** CHANGE TEMP READOUT COLOR DEPENDENT ON FAN AND HEATER STATUS ***********
      int TempColor;                                    // Color for drawing temperature
      boolean HeatOn = ReefAngel.Relay.Status(Port6);   // Get the status of the heater relay
      if (HeatOn)
        TempColor = COLOR_NAVY;                         // Blue text, too cold, heater is on
      if (!HeatOn)
          TempColor = COLOR_GREEN;                      // Green text, no fan or heater on
             int pHColor;                                 // Color for drawing pH
      boolean LowpH = (ReefAngel.Params.PH < 780) ;     // Check for Low pH Value
      boolean HighpH = (ReefAngel.Params.PH > 850);     // Check for High pH Value
      if (LowpH)
        pHColor = COLOR_NAVY;                          // Blue text, Low pH value
      if (HighpH)
        pHColor = COLOR_RED;                           // Red text, High pH value
      if (!LowpH && !HighpH)
        pHColor = COLOR_GREEN;                         // Green text, pH acceptable
      ReefAngel.LCD.DrawLargeText(COLOR_DARKSLATEBLUE,DefaultBGColor, 6, 3, " Thunder Reef",Font8x8);   // Put a banner at the top
      ReefAngel.LCD.DrawDate(6, 119);        // Put the date and time at the bottom
      ReefAngel.LCD.Clear(COLOR_BLACK, 1, 12, 132, 12);                                                 // Draw a black line under the banner
      x = 6;
      y += MENU_START_ROW*1.4;        // MENU_START_ROW is 10, according to globals.h, so y=2+10+1=13
      ReefAngel.LCD.DrawLargeText(COLOR_BLUE, COLOR_WHITE, x, y+1, " Temp      pH");
      ConvertNumToString(text, ReefAngel.Params.Temp[T1_PROBE], 10);                                    // Get T1 temp and convert
      x = 2;
      y += MENU_START_ROW*1.6;
      ReefAngel.LCD.DrawHugeNumbers(COLOR_BLACK, TempColor, x, y, text);                                // Draw the temperature, white numbers on a colored background
      ConvertNumToString(text, ReefAngel.Params.PH, 100);                                               // Get pH reading and convert
      x = 2;
      y = MENU_START_ROW*2.6;
      ReefAngel.LCD.DrawHugeNumbers(COLOR_YELLOW, pHColor, x+65, y+6, text);                            // Put pH on the screen
      x += 6;
      y += MENU_START_ROW*3.3;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,25,y,"Sump Level",Font8x8);      // Draw the Sump Float switch status
  {ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_RED);
  ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_GREEN);
  x += 6;
  y += MENU_START_ROW*2.0;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,25,y,"Skimmer Cup",Font8x8);     // Draw the Skimmer Cup Float switch status
  if (ReefAngel.HighATO.IsActive()) {ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_GREEN);
      byte TempRelay = ReefAngel.Relay.RelayData;                                          // Code for drawing the relay box
      ReefAngel.LCD.DrawOutletBox(12, 100, TempRelay);
    ReefAngel.Init();        //Initialize controller
    ReefAngel.Use2014Screen();                                                               // Let's use 2014 Screen
    ReefAngel.FeedingModePorts = Port7Bit;                                                   // Ports toggled in Feeding Mode
    ReefAngel.WaterChangePorts = Port1Bit | Port6Bit | Port7Bit | Port8Bit;                  // Ports toggled in Water Change Mode
    ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit;                                // Ports toggled when Lights On / Off menu entry selected
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port7Bit;   // Ports turned off when Overheat temperature exceeded
    ReefAngel.TempProbe = T1_PROBE;                                                          // Use T1 probe as temperature and overheat functions
    InternalMemory.OverheatTemp_write( 820 );                                                // Set the Overheat temperature setting
    ReefAngel.Relay.On( Port5 );
    // Virtual Ports that are always off
    ReefAngel.Relay.Off( Box1_Port1);
    ReefAngel.Relay.Off( Box1_Port2);
    ReefAngel.Relay.Off( Box1_Port3);
    ReefAngel.Relay.Off( Box1_Port4);
    ReefAngel.Relay.Off( Box1_Port5);
    ReefAngel.Relay.Off( Box1_Port6);
    ReefAngel.Relay.Off( Box1_Port7);
    ReefAngel.Relay.Off( Box1_Port8);
    // Delayed start for skimmer to allow sump level to return to normal after water change
    ReefAngel.Relay.DelayedOn( Port7,4 );
    sl.Init(28.5700, -81.6800);    // Lat/long for Clermont, FL
    sl.SetOffset(-2,0,-2,0);       // rise_hour, rise_seconds, set_hour, set_seconds (set 2 hrs later for better viewing time (-4 offset = actual time))
    randomSeed(now()%SECS_PER_DAY);
      //Custom Variable [0] =  Month/Season
    ReefAngel.CustomLabels[0]="Return";
    ReefAngel.CustomLabels[1]="Daylights";
    ReefAngel.CustomLabels[2]="Actinics";
    ReefAngel.CustomLabels[3]="Fuge Light";
    ReefAngel.CustomLabels[4]="Dosing Pumps";
    ReefAngel.CustomLabels[5]="Heater";
    ReefAngel.CustomLabels[6]="Skimmer";
    ReefAngel.CustomLabels[7]="ATO RoDi";
    // Virtual Ports reserved for custom lighting functions and effects
    ReefAngel.CustomLabels[8]="Lights 60/40";
    ReefAngel.CustomLabels[9]="Not Used";
    ReefAngel.CustomLabels[10]="Not Used";
    ReefAngel.CustomLabels[11]="Not Used";
    ReefAngel.CustomLabels[12]="Weather";
    ReefAngel.CustomLabels[13]="Weather";
    ReefAngel.CustomLabels[14]="Weather";
    ReefAngel.CustomLabels[15]="Weather";
    // seasonal temperatures
    SeasonalTemps();
// Lights on Dimming Expansion. (Left=East, Right=West)
ReefAngel.PWM.Channel0PWMParabola(0,-30);     // Actinic Left     - Starts at Sunrise, ends 30 minutes before Sunset
ReefAngel.PWM.Channel2PWMParabola(-15,-15);   // Actinic Center   - Starts 15 minute after Sunrise,  ends 15 minutes before Sunset
ReefAngel.PWM.Channel4PWMParabola(-30,0);     // Actinic Right    - Starts 30 minutes after Sunrise, ends at Sunset
ReefAngel.PWM.Channel1PWMParabola(-90,-120);  // Daylight Left   - Starts 90 minutes after Sunrise, ends 120 minutes before Sunset
ReefAngel.PWM.Channel3PWMParabola(-105,-105);  // Daylight Center - Starts 105 minutes after Sunrise, ends 105 minutes before Sunset
ReefAngel.PWM.Channel5PWMParabola(-120,-90);  // Daylight Right  - Starts 120 minutes after Sunrise, ends 90 minutes before Sunset
// Turn Actinic outlet on if any % is >= 2
(ReefAngel.PWM.GetChannelValue(0)>=2 || ReefAngel.PWM.GetChannelValue(2)>=2 || ReefAngel.PWM.GetChannelValue(4)>=2) ?  ReefAngel.Relay.On( Port3 ) :  ReefAngel.Relay.Off( Port3 );
// Turn Daylight outlet on if any % is >=2
(ReefAngel.PWM.GetChannelValue(1)>=2 || ReefAngel.PWM.GetChannelValue(3)>=2 || ReefAngel.PWM.GetChannelValue(5)>=2) ?  ReefAngel.Relay.On( Port2 ) : ReefAngel.Relay.Off( Port2 );
ReefAngel.Relay.Set(Port4, !ReefAngel.Relay.Status(Port2));  // Refugium light.  Opposite Whites.
// Virtual Port Functions
//if (ReefAngel.Relay.Status( Box1_Port1 )); // Set Lights 60/40
//ReefAngel.PWM.SetChannel(0,60);  // Actinic Left
//ReefAngel.PWM.SetChannel(2,60);  // Actinic Center
//ReefAngel.PWM.SetChannel(4,60);  // Actinic Right
//ReefAngel.PWM.SetChannel(1,40);  // Daylight Left
//ReefAngel.PWM.SetChannel(3,40);  // Daylight Center
//ReefAngel.PWM.SetChannel(5,40);  // Daylight Right
// WP-25 powerheads schedule
if (hour()>=9 && hour()<13)
 ReefAngel.PWM.SetDaylight( ReefCrestMode(55,15,true) ); // reefcrest at 55% +/- 15% on sync mode       (Day Mode)
 ReefAngel.PWM.SetActinic( ReefCrestMode(55,15,false) ); // reefcrest at 55% +/- 15% on Anti-sync mode  (Day mode)
else if (hour()>=13 && hour()<18)
 ReefAngel.PWM.SetDaylight( ShortPulseMode(1,75,408,true) ); // Short pulse at 75% with 408ms pulse on sync mode (3/4" surface wave)
 ReefAngel.PWM.SetActinic( ShortPulseMode(1,75,408,false) ); // Short pulse at 75% with 408ms pulse on Anti-sync mode (3/4" surface wave)
else if (hour()>=18 && hour()<19)
 ReefAngel.PWM.SetDaylight( LongPulseMode(35,80,2,true) ); // Long Pulse 35% ramping up to 80% for 2 seconds on sync mode (nutrient transport)
 ReefAngel.PWM.SetActinic( LongPulseMode(35,80,2,false) ); // Long Pulse 35% ramping up to 80% for 2 seconds on Anti-sync mode  (nutrient transport)
else if (hour()>=19 && hour()<20)
 ReefAngel.PWM.SetDaylight( ReefCrestMode(50,10,true) ); // reefcrest at 50% +/- 10% on sync mode       (night Mode)
 ReefAngel.PWM.SetActinic( ReefCrestMode(50,10,false) ); // reefcrest at 50% +/- 10% on Anti-sync mode  (night mode)
if( ReefAngel.DisplayedMenu==FEEDING_MODE )
 ReefAngel.PWM.SetActinic( LongPulseMode(1,40,1,true) );
 ReefAngel.PWM.SetDaylight( LongPulseMode(1,40,1,true) );
if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE )
 ReefAngel.PWM.SetActinic(35);
 ReefAngel.PWM.SetDaylight(35);
// enter feeding mode at 11am & 5pm
 if ( (hour()==11 && minute()==0 && second()==0))
 ReefAngel.FeedingModeStart(); // turn on feeding mode
  if ( (hour()==17 && minute()==0 && second()==0))
if(ReefAngel.HighATO.IsActive())           //  Float switch in Skimmer Locker
 ReefAngel.Relay.Off(Port7);               //  Turn off Skimmer when locker full.
// ATO, Port 8 is ATO using Clear RoDi
 ReefAngel.SingleATO(true,Port8,400,0);   //  Sump switch.  If ATO/RoDi runs for 400 seconds, then shut off and send alert.
    sl.CheckAndUpdate();  // handle updating sunrise and sunset values
    ReefAngel.Portal( "DmnYnkee" );
 void SeasonalTemps ()
  static int heatArray[][2] = { {786,790},                  // default in case of error in month=0 (June)
                    {774,778},//January (winter)            // 77.6
                    {776,780},//February (winter)           // 77.8
                    {778,782},//March (early spring)        // 78.0
                    {780,784},//April (spring)              // 78.2
                    {782,786},//May (spring)                // 78.4
                    {786,790},//June (early summer)         // 78.8
                    {790,794},//July (summer)               // 79.2
                    {794,798},//August (summer)             // 79.6
                    {790,794},//September (early fall)      // 79.2
                    {786,790},//October (fall)              // 78.8
                    {782,786},//November (fall)             // 78.4
                    {778,782} };//December (early winter)   // 78.0
  ReefAngel.StandardHeater( Port6,heatArray[month()][0],heatArray[month()][1]);
 }//end seasonalTemps
PostPosted: Sun Oct 16, 2016 2:13 pm
Lee, and Colin, or anyone else that may want to chime in.
I have this breathing now, and have it close to where I want it.
I no longer have my lights working with sunset/sunrise, but would like to incorporate this back in at some point. I also no longer can adjust light percentages through the portal, and I really liked having that ability.
Issues that I would like to fix at this point are:
1.) I want to raise my actinics up about 20% as a cloud starts dimming the whites. (I think Lee did some work on this)
2.) I need the whites to go no lower than 2% for the duration of the cloud and/or lightning. I have tried several different ways to accomplish this, and none of them have worked, as they still went to 0.
3.) I would like the clouds to dim from left to right (maybe a 10-20 second delay to each channel), and right now, all 3 dim at the same time.
4.) Break the 3 channels out during "Mega", similar to how I have "Slow" set up now. (borrowed this from Lee to get to this point)
5.) I would like to add a basic "storm mode" for my wave makers. Just a higher than normal % short pulse mode that reverts back at end of cloud. These are on my standard actinic/daylight dimming channels.
Here is where my code is now:
#include <Tide.h>
#include <Moon.h>
  SunLocation sl;
  int avgph[10];
    byte avgindex=0;
      byte x;
      byte y = 2;
      char text[7];
      if (HeatOn)
      if (!HeatOn)
      if (LowpH)
      if (HighpH)
      x = 6;
      x = 2;
      x = 2;
      x += 6;
  x += 6;
int DaylightPWMValue1=0;        // For cloud code, channel 1
int DaylightPWMValue3=0;        // For cloud code, chennel 3
int DaylightPWMValue5=0;        // For cloud code, chennel 5
    ReefAngel.CustomLabels[8]="Lights:  B60/W40";
    ReefAngel.CustomLabels[9]="Lighta: Whites 40";
    ReefAngel.CustomLabels[10]="Lights: Blues 60";
    ReefAngel.CustomLabels[12]="Storm";
    SeasonalTemps();
// Lights on Dimming Expansion. (Left=East, Center=Center, Right=West)
// Default lighting program
ReefAngel.PWM.SetChannelRaw( 0, PWMSlopeHighRes(9,30,21,30,1,65,120,0) );  // Schedule for blues
ReefAngel.PWM.SetChannelRaw( 2, PWMSlopeHighRes(9,45,21,45,1,65,120,0) );
ReefAngel.PWM.SetChannelRaw( 4, PWMSlopeHighRes(10,00,22,0,1,65,120,0) );
DaylightPWMValue1=PWMSlopeHighRes(10,30,20,30,1,25,90,0);    //  Default for whites
DaylightPWMValue3=PWMSlopeHighRes(10,45,20,45,1,25,90,0);
DaylightPWMValue5=PWMSlopeHighRes(11,00,21,0,1,25,90,0);
CheckCloud();    //  Check for cloud and slow lightning.
ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue1);  //  Write values for either default or cloud/slow
ReefAngel.PWM.SetChannelRaw(3,DaylightPWMValue3);  //  lightning if it's time.
ReefAngel.PWM.SetChannelRaw(5,DaylightPWMValue5);  //  lightning if it's time.
 byte random_speed=60;
 if (now()%5==1) random_speed=random(58,78);
 ReefAngel.PWM.SetDaylight( ShortPulseMode(1,random_speed,408,true) ); // Short pulse at 58%-78% with 408ms pulse on sync mode (surface wave)
 ReefAngel.PWM.SetActinic( ShortPulseMode(1,random_speed,408,false) ); // Short pulse at 58%-78%% with 408ms pulse on Anti-sync mode (surface wave)
 byte random_speed=65;
 if (now()%5==1) random_speed=random(65,80);
 byte random_duration=2;
 if (now()%5==1) random_duration=random(2,5);
 ReefAngel.PWM.SetDaylight( LongPulseMode(35,random_speed,random_duration,true) ); // Long Pulse 35% ramping up to 65%-80% for 2-5 seconds on sync mode (nutrient transport)
 ReefAngel.PWM.SetActinic( LongPulseMode(35,random_speed,random_duration,false) ); // Long Pulse 35% ramping up to 65%-80% for 2-5 seconds on Anti-sync mode  (nutrient transport)
 ReefAngel.PWM.SetActinic(1);
 ReefAngel.PWM.SetDaylight(1);
// enter feeding mode at 5:30pm
if ( (hour()==17 && minute()==30 && second()==0))
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static byte lightningMode=0;
void CheckCloud()
#define Clouds_Every_X_Days 1
  // Minimum number of minutes for cloud duration.  Don't use min duration of less than 6
#define Min_Cloud_Duration 6
#define Max_Cloud_Duration 12
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 4
#define Start_Cloud_After NumMins(12,00)
  // Add Random Lightning modes
#define Calm 0    // No lightning
#define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4   // Like Mega, but with more lightning
  // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
  // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
  byte LightningModes[] = { Calm, Slow, Mega, Mega };
  static time_t DelayCounter=millis();    // Variable for lightning timing.
  static int DelayTime=random(1000);      // Variable for lightning timimg.
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      randomSeed(millis());    // Seed the random number generator
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    if (ReefAngel.Relay.isMaskOn(Box1_Port5))      // Change this to whatever port you want to use as a trigger.
      cloudstart = NumMins(hour(), minute());
      ReefAngel.Relay.Auto(Box1_Port5);    // Here, too.
    //is it time for cloud yet?
      // Increase Blue channel first for better effect and to compensate for drop in Whites
      //ActinicPWMValue1=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,ActinicPWMValue1,ActinicPWMValue1+DaylightPWMValue0,180);
      //ActinicPWMValue3=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,ActinicPWMValue3,ActinicPWMValue3+DaylightPWMValue2,180);
      //ActinicPWMValue3=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,ActinicPWMValue3,ActinicPWMValue3+DaylightPWMValue4,180);
      DaylightPWMValue1=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue1,2,150);
      DaylightPWMValue3=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue3,2,150);
      DaylightPWMValue5=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue5,2,150);
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
        // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
        if (lightningchance && random(ReversePWMSlope(cloudstart,cloudstart+cloudduration,100,2,150))<1 && (millis()-DelayCounter)>DelayTime)
          // Send the trigger
          Strike();
          DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
          DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
        break;
      case Mega2:
        // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
        if (lightningchance && random(ReversePWMSlope(cloudstart,cloudstart+cloudduration,100,2,150))<2)
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
        // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
        if (lightningchance && (NumMins(hour(),minute())>=(cloudstart+(cloudduration/3))) && second()<10)
          SlowStrike();
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
  // Cloud ON option - Clouds every minute
  if (ReefAngel.Relay.isMaskOff(Box1_Port5) && now()%60<10)
    SlowStrike();
void SlowStrike()
    int r = random(80);
    if (r<20) lightningstatus=1;
    else lightningstatus=0;
    if (lightningstatus)
      // Let's separate left, center, right, or All.
      if (r<10  ) {               // All 3
        DaylightPWMValue1=4095;
        DaylightPWMValue3=4095;
        DaylightPWMValue5=4095;
      } else if (r<12) {          // Left only
        DaylightPWMValue3=100;
        DaylightPWMValue5=100;
      } else if (r<14) {          // Center only
        DaylightPWMValue1=100;
      } else if (r<16) {          // Right only
      } else if (r<18) {          // Left & Center only
      } else {                    // Center & Right only
    delay(1);
void DrawClouds(int x, int y)
    ReefAngel.LCD.DrawText(0,255,x,y,"C"); x+=6;
    ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x+=34;
    ReefAngel.LCD.DrawText(0,255,x,y,"L"); x+=6;
    ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x=5;
      int x=0;
      else x=17;
      ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart/60));
      //ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
      else x=35;
      ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart%60));
      //ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
    ReefAngel.LCD.DrawText(0,255,x+85,y,cloudduration);
    //ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/3))/60)>=10) x=51;
      else x=57;
      ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))/60));
      //ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      if (((cloudstart+(cloudduration/3))%60)>=10) x=69;
      else x=75;
        ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))%60)); // Write the minute of the next lightning to a custom variable for the Portal
        //ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
void Strike()
  int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
  for (int i=0; i<a; i++)
    // Flash on
    int newdata=4095;
    Wire.beginTransmission(0x40);      // Address of the dimming expansion module
    Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 1.
    Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
    Wire.write(newdata>>8);            // This sends the MSB
    Wire.endTransmission();
    Wire.write(0x8+(4*3));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 3.
    Wire.write(0x8+(4*5));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 5.
    int randy=random(20,80);    // Random number for a delay
    if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
    delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
    // Flash off.  Return to baseline.
    newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
    Wire.beginTransmission(0x40);    // Same as above
    newdata=ReefAngel.PWM.GetChannelValueRaw(3);   // Use the channel number you're flashing here
    newdata=ReefAngel.PWM.GetChannelValueRaw(5);   // Use the channel number you're flashing here
    delay(random(30,50));                // Wait from 30 to 49 ms
    wdt_reset();    // Reset watchdog timer to avoid re-boots
  cstart*=60;
  cend*=60;
int ReversePWMSlope(long cstart,long cend,int PWMStart,int PWMEnd, byte clength)
  cstart*=60;
  cend*=60;
Previous
Return to How do I code ...
