Multi tank temp control
I just set up a biocube next to my 210 and want to run a temp probe to it and be able to control the temps of both tanks with my reefangel. Can I program one heater to one temp probe and another heater to a second temp probe? If I do this I will need another Relay box.
Re: Multi tank temp control
I do the same thing with a small freshwater tank. Here's the code I use. Replace the labels with your own ports.
// Freshwater tank heater control
if (ReefAngel.Params.Temp[T2_PROBE] <= 770 && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(BettaHeater); // If sensor 2 temperature <= LowTemp - turn on heater
if (ReefAngel.Params.Temp[T2_PROBE] >= 780) ReefAngel.Relay.Off(BettaHeater); // If sensor 2 temperature >= HighTemp - turn off heater
I have my codes programmed so I can change it through internal memory.
Can I program it to run 2 different tanks with the coding for internal memory?
If you use a custom memory location, then yes. But not with the preset memory locations.
How would I go about doing that?
You would need something like this up in the globals area (where all the #includes live).
Then change the heater code to this:
Then, in the RA Status app (not sure if you can use the U-App or not, haven't tried it), pull up the menu, go to Memory, hit the down arrow, and scroll up to Custom location. Put your low temperature in location 100 (be sure to select Int) and your high temperature in location 102. VERY IMPORTANT! Make sure you enter in the temperature as 3 digits. I.e., 800 for 80 degrees, 790 for 79 degrees, 789 for 78.9 degrees, etc.
// Define memory locations for temp values
// Integers take two locations each. Locations 100-199 are available.
#define Mem_I_LowTemp 100 // Low temperature stored in memory locations 100 and 101
#define Mem_I_HighTemp 102 // High temperature stored in locations 102 and 103
if (ReefAngel.Params.Temp[T2_PROBE] <= Mem_I_LowTemp && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(BettaHeater); // If sensor 2 temperature <= LowTemp - turn on heater
if (ReefAngel.Params.Temp[T2_PROBE] >= Mem_I_HighTemp) ReefAngel.Relay.Off(BettaHeater); // If sensor 2 temperature >= HighTemp - turn off heater
