Skimmer coding
PostPosted: Thu Aug 04, 2016 6:41 pm
i have the following code
ReefAngel.Relay.Set(Box1_Port3,ReefAngel.Relay.Status(Port6)); // 11 Skimmer
i want to add a 5 min delay in this while keeping it connected to my return pump status. how would i do that ?
PostPosted: Sun Aug 07, 2016 9:29 pm
if (ReefAngel.Relay.Status(Port6)) {
ReefAngel.Relay.DelayedOn(Box1_Port3, 5);
ReefAngel.Relay.Off(Box1_Port3);
PostPosted: Tue Sep 06, 2016 2:23 pm
lnevo wrote:if (ReefAngel.Relay.Status(Port6)) {
Is there a way to delay this after a power failure as well? Something with ReefAngel.Init(); ?
PostPosted: Tue Sep 06, 2016 7:15 pm
Take a look at the function in my code, DelayedModeSkimmer I think its called, that does exactly what you want just change the float switch to be your relay status.
PostPosted: Wed Sep 07, 2016 3:56 pm
lnevo wrote:Take a look at the function in my code, DelayedModeSkimmer I think its called, that does exactly what you want just change the float switch to be your relay status.
Duh, never thought about doing it that way. Thanks.
Return to How do I code ...
Users browsing this forum: Google [Bot] and 2 guests
