Power Expansion Module
PostPosted: Thu Oct 06, 2016 8:24 pm
Here is my code. i need to add a power expansion module to my reef angel. I dont see the module as an option on my menu. and i want to setup so i can run my dosers off of it... Any help will be appreciate ... especially from @lnevo and @rimai...
Thanks in advance
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.FeedingModePorts = Port1Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit;
    InternalMemory.OverheatTemp_write( 805 );
    ReefAngel.Relay.On( Port1 );   Return
    ReefAngel.SingleATO( true,Port2,90,0 );
    ReefAngel.StandardHeater( Port3,770,790 );
    ReefAngel.StandardHeater( Port4,770,790 );f
PostPosted: Fri Oct 07, 2016 6:55 am
It acts just like an expansion relay box. Just select expansion relay and program it as usual.
PostPosted: Fri Oct 07, 2016 12:08 pm
Okay... so if it acts like an expansion relay? how do i know what order is 1-8.... also i cant access the library to execute the code to introduce to the reef angel... Any sample code would be most helpful
PostPosted: Fri Oct 07, 2016 12:30 pm
I don't have one, but you should be able to use the Wizard to program it. Just select it as an expansion relay.
Looking at the schematics, it looks like if you hold it with the bus connection facing down, then 1-2 are on the right, 3-6 are on the top, and 7-8 are on the left.
Return to How do I code ...
