shorten feeding mode
PostPosted: Thu Oct 27, 2016 6:50 pm
How do I shorten feeding mode? It's too long with the code generated from the wizard for me. Sorry if this is obvious, but not for me..
thanks
    ReefAngel.AddHumidityExpansion();  // Humidity Expanion Module
    ReefAngel.FeedingModePorts = Port1Bit;
    ReefAngel.WaterChangePorts = Port1Bit;
    ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
    ReefAngel.ActinicLights( Port2 );
    ReefAngel.DayLights( Port3 );
    ReefAngel.DayLights( Port4 );
    ReefAngel.SingleATOLow( Port5 );
    ReefAngel.StandardFan( Port8 );
    ReefAngel.Portal( "psyrob" );
    ReefAngel.DDNS( "99.90.0.55" ); // Your DDNS is psyrob-99.90.0.55.myreefangel.com
PostPosted: Thu Oct 27, 2016 10:55 pm
Do you use the android app?
If so, you can change it in the internal memory section.
If not, add this after ReefAngel.Init();
ReefAngel.Timer[FEEDING_TIMER].SetInterval(60);
60 is the number of seconds you want.
PostPosted: Thu Nov 03, 2016 8:17 pm
I use the UApp. thanks I will enter that into my code
Return to How do I code ...
