Why are my lights dropping to 0 at end of daily slope?
PostPosted: Fri Oct 28, 2016 12:19 pm
I am wanting them to stop at 1% for charting purposes. With my current code, which incorporated the cloud code from Colin, they are going all the way to 0.
Do I need to change the values here to 40.95 instead of 1?
    int ActinicPWMValue0=1;        // For cloud code, channel 0, left blue
    int ActinicPWMValue2=1;        // For cloud code, chennel 2, center blue
    int ActinicPWMValue4=1;        // For cloud code, chennel 4, right blue
    int DaylightPWMValue1=1;        // For cloud code, channel 1, left white
    int DaylightPWMValue3=1;        // For cloud code, chennel 3, center white
    int DaylightPWMValue5=1;        // For cloud code, chennel 5, right white
I would also like to know what the zero at the end of the string is for: PWMSlopeHighRes(9,30,21,30,1,65,230,0);
Here is my current full code:
#include <SunLocation.h>
#include <Tide.h>
#include <Moon.h>
#include <WiFiAlert.h>
  SunLocation sl;
  int avgph[10];
    unsigned long totalavgph=0;
    byte avgindex=0;
      byte x;
      byte y = 2;
      char text[7];
      // *********** CHANGE TEMP READOUT COLOR DEPENDENT ON FAN AND HEATER STATUS ***********
      int TempColor;                                    // Color for drawing temperature
      boolean HeatOn = ReefAngel.Relay.Status(Port6);   // Get the status of the heater relay
      if (HeatOn)
        TempColor = COLOR_NAVY;                         // Blue text, too cold, heater is on
      if (!HeatOn)
          TempColor = COLOR_GREEN;                      // Green text, no fan or heater on
             int pHColor;                                 // Color for drawing pH
      boolean LowpH = (ReefAngel.Params.PH < 780) ;     // Check for Low pH Value
      boolean HighpH = (ReefAngel.Params.PH > 850);     // Check for High pH Value
      if (LowpH)
        pHColor = COLOR_NAVY;                          // Blue text, Low pH value
      if (HighpH)
        pHColor = COLOR_RED;                           // Red text, High pH value
      if (!LowpH && !HighpH)
        pHColor = COLOR_GREEN;                         // Green text, pH acceptable
      ReefAngel.LCD.DrawLargeText(COLOR_DARKSLATEBLUE,DefaultBGColor, 6, 3, " Thunder Reef",Font8x8);   // Put a banner at the top
      ReefAngel.LCD.DrawDate(6, 119);        // Put the date and time at the bottom
      ReefAngel.LCD.Clear(COLOR_BLACK, 1, 12, 132, 12);                                                 // Draw a black line under the banner
      x = 6;
      y += MENU_START_ROW*1.4;        // MENU_START_ROW is 10, according to globals.h, so y=2+10+1=13
      ReefAngel.LCD.DrawLargeText(COLOR_BLUE, COLOR_WHITE, x, y+1, " Temp      pH");
      ConvertNumToString(text, ReefAngel.Params.Temp[T1_PROBE], 10);                                    // Get T1 temp and convert
      x = 2;
      y += MENU_START_ROW*1.6;
      ReefAngel.LCD.DrawHugeNumbers(COLOR_BLACK, TempColor, x, y, text);                                // Draw the temperature, white numbers on a colored background
      ConvertNumToString(text, ReefAngel.Params.PH, 100);                                               // Get pH reading and convert
      x = 2;
      y = MENU_START_ROW*2.6;
      ReefAngel.LCD.DrawHugeNumbers(COLOR_YELLOW, pHColor, x+65, y+6, text);                            // Put pH on the screen
      x += 6;
      y += MENU_START_ROW*3.3;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,25,y,"Sump Level",Font8x8);      // Draw the Sump Float switch status
  {ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_RED);
  ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_GREEN);
  x += 6;
  y += MENU_START_ROW*2.0;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,25,y,"Skimmer Cup",Font8x8);     // Draw the Skimmer Cup Float switch status
  if (ReefAngel.HighATO.IsActive()) {ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_GREEN);
      byte TempRelay = ReefAngel.Relay.RelayData;                                          // Code for drawing the relay box
      ReefAngel.LCD.DrawOutletBox(12, 100, TempRelay);
    ReefAngel.Init();        //Initialize controller
    ReefAngel.Use2014Screen();                                                               // Let's use 2014 Screen
    ReefAngel.Timer[FEEDING_TIMER].SetInterval(1800);                                        // Feeding timer at 30 minutes (in seconds)
    ReefAngel.FeedingModePorts = Port7Bit;                                                   // Ports toggled in Feeding Mode
    ReefAngel.WaterChangePorts = Port1Bit | Port6Bit | Port7Bit | Port8Bit;                  // Ports toggled in Water Change Mode
    ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit;                                // Ports toggled when Lights On / Off menu entry selected
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;   // Ports turned off when Overheat temperature exceeded
    ReefAngel.TempProbe = T1_PROBE;                                                          // Use T1 probe as temperature and overheat functions
    InternalMemory.OverheatTemp_write( 820 );                                                // Set the Overheat temperature setting
    CustomOverheatClear(T1_PROBE);
    // Virtual Ports that are always off
    ReefAngel.Relay.Off( Box1_Port1);
    ReefAngel.Relay.Off( Box1_Port2);
    ReefAngel.Relay.Off( Box1_Port3);
    ReefAngel.Relay.Off( Box1_Port4);
    ReefAngel.Relay.Off( Box1_Port5);
    ReefAngel.Relay.Off( Box1_Port6);
    ReefAngel.Relay.Off( Box1_Port7);
    ReefAngel.Relay.Off( Box1_Port8);
    // Delayed start for skimmer to allow sump level to return to normal after water change
    ReefAngel.Relay.DelayedOn( Port7,4 );
    sl.Init(28.5700, -81.6800);    // Lat/long for Clermont, FL
    sl.SetOffset(-2,0,-2,0);       // rise_hour, rise_seconds, set_hour, set_seconds (set 2 hrs later for better viewing time (-4 offset = actual time))
    randomSeed(now()%SECS_PER_DAY);
      //Custom Variable [0] =  Month/Season
    ReefAngel.CustomLabels[0]="Return";
    ReefAngel.CustomLabels[1]="BlueLED";
    ReefAngel.CustomLabels[2]="WhiteLED";
    ReefAngel.CustomLabels[3]="Refugium";
    ReefAngel.CustomLabels[4]="Moonlights";
    ReefAngel.CustomLabels[5]="Heater";
    ReefAngel.CustomLabels[6]="Skimmer";
    ReefAngel.CustomLabels[7]="ATO RoDi";
    // Virtual Ports reserved for custom lighting functions and effects
    ReefAngel.CustomLabels[8]="Lights:  B60/W40";
    ReefAngel.CustomLabels[9]="Lighta: Whites 40";
    ReefAngel.CustomLabels[10]="Lights: Blues 60";
    ReefAngel.CustomLabels[11]="Not Used";
    ReefAngel.CustomLabels[12]="Storm";
    ReefAngel.CustomLabels[13]="Weather";
    ReefAngel.CustomLabels[14]="Weather";
    ReefAngel.CustomLabels[15]="Weather";
    // seasonal temperatures
    SeasonalTemps();
// Lights on Dimming Expansion. (Left=East, Center=Center, Right=West)
//if (ReefAngel.Relay.Status( Box1_Port1 )); // Set Lights 60/40
//   ActinicPWMValue0=60;        // Virtual port, channel 0, left blue
//   ActinicPWMValue2=60;        // Virtual port, chennel 2, center blue
//   ActinicPWMValue4=60;        // Virtual port, chennel 4, right blue
//   DaylightPWMValue1=40;        // Virtual port, channel 1, left white
//   DaylightPWMValue3=40;        // Virtual port, chennel 3, center white
//   DaylightPWMValue5=40;        // Virtual port, chennel 5, right white
// Default lighting program
ActinicPWMValue0=PWMSlopeHighRes(9,30,21,30,1,65,230,0);  // Default for blues
ActinicPWMValue2=PWMSlopeHighRes(9,45,21,45,1,65,230,0);
ActinicPWMValue4=PWMSlopeHighRes(10,00,22,0,1,65,230,0);
DaylightPWMValue1=PWMSlopeHighRes(10,30,20,30,1,25,175,0);    //  Default for whites
DaylightPWMValue3=PWMSlopeHighRes(10,45,20,45,1,25,175,0);
DaylightPWMValue5=PWMSlopeHighRes(11,00,21,0,1,25,175,0);
CheckCloud();    //  Check for cloud and slow lightning.
ReefAngel.PWM.SetChannelRaw(0,ActinicPWMValue0);  //  Write values for either default or cloud/slow
ReefAngel.PWM.SetChannelRaw(2,ActinicPWMValue2);  //  lightning if it's time.
ReefAngel.PWM.SetChannelRaw(4,ActinicPWMValue4);  //  lightning if it's time.
ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue1);  //  Write values for either default or cloud/slow
ReefAngel.PWM.SetChannelRaw(3,DaylightPWMValue3);  //  lightning if it's time.
ReefAngel.PWM.SetChannelRaw(5,DaylightPWMValue5);  //  lightning if it's time.
// Turn Actinic outlet on if any % is >= 2
(ReefAngel.PWM.GetChannelValue(0)>=2 || ReefAngel.PWM.GetChannelValue(2)>=2 || ReefAngel.PWM.GetChannelValue(4)>=2) ?  ReefAngel.Relay.On( Port2 ) :  ReefAngel.Relay.Off( Port2 );
// Turn Daylight outlet on if any % is >=2
(ReefAngel.PWM.GetChannelValue(1)>=2 || ReefAngel.PWM.GetChannelValue(3)>=2 || ReefAngel.PWM.GetChannelValue(5)>=2) ?  ReefAngel.Relay.On( Port3 ) :  ReefAngel.Relay.Off( Port3 );
// Refugium Light: sPar38-Fuge
if (hour()<16 || hour() >=19)
 ReefAngel.Relay.On( Port4 );
 ReefAngel.Relay.Off( Port4 );
//  Moonlight Strip
if ((hour()>=21 && hour() <=23) || (hour()>=8 && hour()<10))
 ReefAngel.Relay.Off( Port5 );
// WP-25 powerheads schedule
if (hour()>=9 && hour()<13)
 ReefAngel.PWM.SetDaylight( ReefCrestMode(55,15,true) ); // reefcrest at 55% +/- 15% on sync mode       (Day Mode)
 ReefAngel.PWM.SetActinic( ReefCrestMode(55,15,false) ); // reefcrest at 55% +/- 15% on Anti-sync mode  (Day mode)
else if (hour()>=13 && hour()<19)
 byte random_speed=random(48,78);
 ReefAngel.PWM.SetDaylight( ShortPulseMode(1,random_speed,408,true) ); // Short pulse at 48%-78% with 408ms pulse on sync mode (surface wave)
 ReefAngel.PWM.SetActinic( ShortPulseMode(1,random_speed,408,false) ); // Short pulse at 48%-78%% with 408ms pulse on Anti-sync mode (surface wave)
else if (hour()>=19 && hour()<20)
 byte random_min=random(35,45);
 byte random_speed=random(65,80);
 byte random_duration=random(2,5);
 ReefAngel.PWM.SetDaylight( LongPulseMode(random_min,random_speed,random_duration,true) ); // Long Pulse 35% ramping up to 65%-80% for 2-5 seconds on sync mode (nutrient transport)
 ReefAngel.PWM.SetActinic( LongPulseMode(random_min,random_speed,random_duration,false) ); // Long Pulse 35% ramping up to 65%-80% for 2-5 seconds on Anti-sync mode  (nutrient transport)
else if (hour()>=20 && hour()<21)
 ReefAngel.PWM.SetDaylight( ReefCrestMode(50,10,true) ); // reefcrest at 50% +/- 10% on sync mode       (night Mode)
 ReefAngel.PWM.SetActinic( ReefCrestMode(50,10,false) ); // reefcrest at 50% +/- 10% on Anti-sync mode  (night mode)
if( ReefAngel.DisplayedMenu==FEEDING_MODE )
 ReefAngel.PWM.SetActinic(1);
 ReefAngel.PWM.SetDaylight(1);
if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE )
 ReefAngel.PWM.SetActinic(35);
 ReefAngel.PWM.SetDaylight(35);
// enter feeding mode at 5:30pm
if ( (hour()==17 && minute()==30 && second()==0))
 ReefAngel.FeedingModeStart(); // turn on feeding mode
if(ReefAngel.HighATO.IsActive())           //  Float switch in Skimmer Locker
 ReefAngel.Relay.Off(Port7);               //  Turn off Skimmer when locker full.
// ATO, Port 8 is ATO using Clear RoDi
 ReefAngel.SingleATO(true,Port8,400,0);   //  Sump switch.  If ATO/RoDi runs for 400 seconds, then shut off and send alert.
    sl.CheckAndUpdate();  // handle updating sunrise and sunset values
    ReefAngel.Portal( "DmnYnkee" );
 void SeasonalTemps ()
  static int heatArray[][2] = { {786,790},                  // default in case of error in month=0 (June)
                    {774,778},//January (winter)            // 77.6
                    {776,780},//February (winter)           // 77.8
                    {778,782},//March (early spring)        // 78.0
                    {780,784},//April (spring)              // 78.2
                    {782,786},//May (spring)                // 78.4
                    {786,790},//June (early summer)         // 78.8
                    {790,794},//July (summer)               // 79.2
                    {794,798},//August (summer)             // 79.6
                    {790,794},//September (early fall)      // 79.2
                    {786,790},//October (fall)              // 78.8
                    {782,786},//November (fall)             // 78.4
                    {778,782} };//December (early winter)   // 78.0
  ReefAngel.StandardHeater( Port6,heatArray[month()][0],heatArray[month()][1]);
 }//end seasonalTemps
// ------------------------------------ Auto overheat clear
void CustomOverheatClear(byte probe)
if((bitRead(ReefAngel.AlertFlags, OverheatFlag)) && (ReefAngel.Params.Temp[probe] <= InternalMemory.OverheatTemp_read()-30))
ReefAngel.OverheatClear();
// ------------------------------------------------------------  Weather section
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static byte lightningMode=0;
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 75
  // Minimum number of minutes for cloud duration.  Don't use min duration of less than 6
#define Min_Cloud_Duration 8
#define Max_Cloud_Duration 10
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 2
  // In this example, start cloud after 12:00pm
#define Start_Cloud_After NumMins(12,00)
#define End_Cloud_Before NumMins(21,00)
#define Lightning_Change_per_Cloud 70
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes
  // of effects or unforseen result could happen.
  // In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the
  // 250 minutes (or 500 minutes) can fit in that 510 minutes window.
  // Add Random Lightning modes
#define Calm 0    // No lightning
#define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4   // Like Mega, but with more lightning
  // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
  // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
  byte LightningModes[] = { Mega };        // <---- set Storm modes here
  static time_t DelayCounter=millis();    // Variable for lightning timing.
  static int DelayTime=random(1000);      // Variable for lightning timimg.
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      randomSeed(millis());    // Seed the random number generator
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    if (ReefAngel.Relay.isMaskOn(Box1_Port5))      // Change this to whatever port you want to use as a trigger.
      cloudstart = NumMins(hour(), minute());
      ReefAngel.Relay.Auto(Box1_Port5);    // Here, too.
    //is it time for cloud yet?
         // Increase Blue channel first, for better effect and to compensate for drop in Whites
      ActinicPWMValue0=ReversePWMSlope(cloudstart,cloudstart+cloudduration,ActinicPWMValue0,ActinicPWMValue0+DaylightPWMValue1*.85,120);
      ActinicPWMValue2=ReversePWMSlope(cloudstart,cloudstart+cloudduration,ActinicPWMValue2,ActinicPWMValue2+DaylightPWMValue3*.85,120);
      ActinicPWMValue4=ReversePWMSlope(cloudstart,cloudstart+cloudduration,ActinicPWMValue4,ActinicPWMValue4+DaylightPWMValue5*.85,120);
         // Daylight dimming from cloud
      DaylightPWMValue1=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue1/40.95,2,120)*40.95;
      DaylightPWMValue3=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue3/40.95,2,120)*40.95;
      DaylightPWMValue5=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue5/40.95,2,120)*40.95;
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
        // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
        if (lightningchance && random(ReversePWMSlope(cloudstart,cloudstart+cloudduration,100,0,120))<1 && (millis()-DelayCounter)>DelayTime)
          // Send the trigger
          int r=random(34);
          if (r<20) {
          Strike1();                // All 3 lights
        } else if (r<22) {
          Strike2();                // Left only
        } else if (r<24) {
          Strike3();                // Center only
        } else if (r<28) {
          Strike4();                // Right only
        } else if (r<30) {
          Strike5();                // Left & Center
        } else if (r<34)
          Strike6();                // Center & Right
          DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
          DelayTime=random(1800);   // of up to a second for dramatic effect before we do another round.
        break;
      case Mega2:
        // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          Strike();
        break;
      case Fast:
          Strike();
          DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
        break;
      case Slow:
        // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
          SlowStrike();
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
  // Cloud ON option - Clouds every minute
  if (ReefAngel.Relay.isMaskOff(Box1_Port5) && now()%60<10)
    SlowStrike();
    void SlowStrike()
    int r = random(80);
    if (r<20) lightningstatus=1;
    else lightningstatus=0;
    if (lightningstatus)
      // Let's separate left, center, right, or All.
      if (r<10  ) {               // All 3
        DaylightPWMValue1=4095;
        DaylightPWMValue3=4095;
        DaylightPWMValue5=4095;
      } else if (r<12) {          // Left only
        DaylightPWMValue3=100;
        DaylightPWMValue5=100;
      } else if (r<14) {          // Center only
        DaylightPWMValue1=100;
      } else if (r<16) {          // Right only
      } else if (r<18) {          // Left & Center only
      } else {                    // Center & Right only
        delay(1);
void DrawClouds(int x, int y)
    ReefAngel.LCD.DrawText(0,255,x,y,"C"); x+=6;
    ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x+=34;
    ReefAngel.LCD.DrawText(0,255,x,y,"L"); x+=6;
    ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x=5;
      int x=0;
      else x=17;
      ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart/60));
      //ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
      else x=35;
      ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart%60));
      //ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
    ReefAngel.LCD.DrawText(0,255,x+85,y,cloudduration);
    //ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/3))/60)>=10) x=51;
      else x=57;
      ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))/60));
      //ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      if (((cloudstart+(cloudduration/3))%60)>=10) x=69;
      else x=75;
        ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))%60)); // Write the minute of the next lightning to a custom variable for the Portal
        //ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
void Strike1()          //  All 3 lights
  int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
  for (int i=0; i<a; i++)
    // Flash on
    int newdata=4095;
    Wire.beginTransmission(0x40);      // Address of the dimming expansion module
    Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 1.
    Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
    Wire.write(newdata>>8);            // This sends the MSB
    Wire.endTransmission();
    Wire.write(0x8+(4*3));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 3.
    Wire.write(0x8+(4*5));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 5.
    int randy=random(20,80);    // Random number for a delay
    if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
    delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
    // Flash off.  Return to baseline.
    newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
    Wire.beginTransmission(0x40);    // Same as above
    newdata=ReefAngel.PWM.GetChannelValueRaw(3);   // Use the channel number you're flashing here
    newdata=ReefAngel.PWM.GetChannelValueRaw(5);   // Use the channel number you're flashing here
    delay(random(30,50));                // Wait from 30 to 49 ms
    wdt_reset();    // Reset watchdog timer to avoid re-boots
void Strike2()          // Left only
  int a=random(1,4);    // Pick a number of consecutive flashes from 1 to 3.
    // Flash on
    int newdata=4095;
void Strike3()          // Center only
    // Flash on
    int newdata=4095;
void Strike4()          // Right only
    // Flash on
    int newdata=4095;
void Strike5()          //  Left & Center
    // Flash on
    int newdata=4095;
void Strike6()          // Center & Right
    // Flash on
    int newdata=4095;
void Strike()
    // Flash on
    int newdata=4095;
  cstart*=60;
  cend*=60;
  if (n>cend) return (int) PWMStart;
int ReversePWMSlope(long cstart,long cend,int PWMStart,int PWMEnd, byte clength)
  cstart*=60;
  cend*=60;
PostPosted: Sat Oct 29, 2016 12:57 pm
That's for what you want to do.
It will output zero when not during slope. If you want one, change it from zero to one.
PostPosted: Mon Oct 31, 2016 5:38 am
That didn't fix it. All 6 channels still dropped to zero.
This is the portion I changed and added the 1's at the end.
ActinicPWMValue0=PWMSlopeHighRes(9,30,21,30,1,65,230,1);  // Default for blues
ActinicPWMValue2=PWMSlopeHighRes(9,45,21,45,1,65,230,1);
ActinicPWMValue4=PWMSlopeHighRes(10,00,22,0,1,65,230,1);
DaylightPWMValue1=PWMSlopeHighRes(10,30,20,30,1,25,175,1);    //  Default for whites
DaylightPWMValue3=PWMSlopeHighRes(10,45,20,45,1,25,175,1);
DaylightPWMValue5=PWMSlopeHighRes(11,00,21,0,1,25,175,1);
PostPosted: Mon Oct 31, 2016 9:18 am
You are using High res andit has resolution from 0-4095.
In order to have a one in a non high res, you need a value greater than 40.
Try using 41 instead.
PostPosted: Tue Nov 01, 2016 2:38 pm
That did the trick! I thought I needed to add 40+ somewhere due to the high res, but wasn't sure where the correct place was.
Thanks much, rimai!!!
Return to How do I code ...
