Please help me to add and edit my codes please
PostPosted: Fri Nov 25, 2016 7:43 pm
Yes Roberto I did
PostPosted: Fri Nov 25, 2016 7:56 pm
Roberto, I saw now why no response, we should only put Port1bit; because it's conflict on the port 2 while its ON on the timer configuration... Now its working. Now I wanted the Port 1 to be opposite with the sump light. For example when its Off during night time the sump light will turn ON.
PostPosted: Fri Nov 25, 2016 8:03 pm
Roberto I think I have no port available for the opposite light.... any suggestion or just put on a separate plug and just use a regular timer?
PostPosted: Fri Nov 25, 2016 9:14 pm
Get the relay expansion box.
PostPosted: Fri Nov 25, 2016 10:30 pm
ok thanks! I will buy also soon the wifi attachment and if I will have trouble I will contact you again. Thank you very much and thank you also for you time! Have a great weekend!
PostPosted: Tue Nov 29, 2016 5:30 am
You could make the menu item a toggle. Thats what I did for my refugium/stand light
Previous
Return to How do I code ...
