skimmer on time schedule
Ask in here.
PostPosted: Tue Nov 29, 2016 2:55 pm
You are using standard lights. That is the one.
PostPosted: Tue Nov 29, 2016 3:05 pm
I need that for my lights. what if I want to have a schedule for my skimmer? would the code in my first post work?
PostPosted: Tue Nov 29, 2016 3:08 pm
Are you using internal memory code for your lights too?
Can you post your entire code?
The code in the first post works, but you won't be able to change on the portal.
PostPosted: Tue Nov 29, 2016 3:19 pm
so like this in port 4 and 5?
    ReefAngel.DayLights( Port2 );
    ReefAngel.StandardLights( Port4,23,0,13,0 );//Protein skimmer on 11pm, off 1pm
    ReefAngel.StandardLights( Port5,2,0,19,0 );//Moomlights 2am-7pm
    ReefAngel.DosingPumpRepeat1( Port6 );
    ReefAngel.DosingPumpRepeat2( Port7 );
    ReefAngel.DosingPumpRepeat3( Port8 );
    ReefAngel.DCPump.DaylightChannel = None;//no pump=None, pump=AntiSync
PostPosted: Tue Nov 29, 2016 3:22 pm
Ahh. now it makes sense.
So, there is no way to use the portal to adjust a second schedule.
You can do it with the android app or issuing web commands though.
For web commands, check here:
viewtopic.php?f=7&t=1541
Previous
Return to How do I code ...
