skimmer on time schedule
Posted: Mon Nov 28, 2016 4:52 pm
by Reefology
Hi, I'd like to experiment with having my skimmer on a reverse daylight schedule and think I have to add the line below to void loop section.
ReefAngel.StandardLights( Port5,23,0,13,0 );//Protein skimmer on 11pm, off 1pm
my question is, can I control schedule from the portal? And if so, what code do I need?
thanks
Re: skimmer on time schedule
Posted: Mon Nov 28, 2016 7:27 pm
Use this:
ReefAngel.StandardLights( Port5 );
Posted: Mon Nov 28, 2016 7:41 pm
by Reefology
can I then control that port via the portal?
Posted: Mon Nov 28, 2016 7:56 pm
Yeap
Posted: Mon Nov 28, 2016 8:23 pm
by Reefology
Awesome thanks
Posted: Mon Nov 28, 2016 9:09 pm
by Reefology
actually changed port 4 and 5 but I can't find them in the portal?
Posted: Mon Nov 28, 2016 9:49 pm
You need to change the internal memory settings.
Posted: Tue Nov 29, 2016 7:21 am
by Reefology
how do I do that?
Posted: Tue Nov 29, 2016 10:43 am
Go to the portal and click internal memory
Posted: Tue Nov 29, 2016 2:40 pm
by Reefology
only gives me an option to adjust daylight schedule which I don't want to change. looking to adjust skimmer schedule.
thanks
Posted: Tue Nov 29, 2016 2:55 pm
You are using standard lights. That is the one.
Posted: Tue Nov 29, 2016 3:05 pm
by Reefology
I need that for my lights. what if I want to have a schedule for my skimmer? would the code in my first post work?
Posted: Tue Nov 29, 2016 3:08 pm
Are you using internal memory code for your lights too?
Can you post your entire code?
The code in the first post works, but you won't be able to change on the portal.
Posted: Tue Nov 29, 2016 3:19 pm
by Reefology
so like this in port 4 and 5?
ReefAngel.DayLights( Port2 );
ReefAngel.StandardLights( Port4,23,0,13,0 );//Protein skimmer on 11pm, off 1pm
ReefAngel.StandardLights( Port5,2,0,19,0 );//Moomlights 2am-7pm
ReefAngel.DosingPumpRepeat1( Port6 );
ReefAngel.DosingPumpRepeat2( Port7 );
ReefAngel.DosingPumpRepeat3( Port8 );
ReefAngel.DCPump.DaylightChannel = None;//no pump=None, pump=AntiSync
Posted: Tue Nov 29, 2016 3:22 pm
Ahh. now it makes sense.
So, there is no way to use the portal to adjust a second schedule.
You can do it with the android app or issuing web commands though.
For web commands, check here:
http://forum.reefangel.com/viewtopic.php?f=7&t=1541
