2 different size jebao pumps
Posted: Thu Dec 22, 2016 1:13 pm
by Reefology
I assume the following line of code is to offset water volume of different pumps but not exactly sure?
ReefAngel.DCPump.AntiSyncOffset=85;
how would I use this and where would I put it in my code?
thanks
    ReefAngel.DayLights( Port2 );
    ReefAngel.StandardLights( Port4, 19,0,7,0); //Skimmer, Reactor 7pm-7am
    ReefAngel.StandardLights( Port5 );
    ReefAngel.DosingPumpRepeat1( Port6 );
    ReefAngel.DosingPumpRepeat2( Port7 );
    ReefAngel.DosingPumpRepeat3( Port8 );
    ReefAngel.DCPump.LowATOChannel = Sync; // WP40
    ReefAngel.DCPump.HighATOChannel = AntiSync; // SW 8
    // DC pumps
    // To run this code must choose Custom in portal
    static int rmode;
    byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
    if (now()%600==0 || changeMode==true) { // Change every 10 mins (600seconds) or controller reboot
    rmode=random(100)%sizeof(modes); // Change the mode by picking from our array
    changeMode=false;
    static unsigned long feeding;
    // Continue NutrientTranspot Mode for 30 minutes after feeding
    if (now()-feeding<1800) {
    // Night mode (go to 30%)
    } else if (now()%SECS_PER_DAY<39600 || now()%SECS_PER_DAY>=82800) { // 11am / 11pm
    ReefAngel.DCPump.Mode=Gyre;
    ReefAngel.DCPump.Speed=30;
    } else {
Re: 2 different size jebao pumps
Posted: Thu Dec 22, 2016 1:56 pm
You can run it in loop or in setup and it will set the percentage for the pump you set as AntiSync. So that one will go at 85% of the speed of the primary.
Posted: Thu Dec 22, 2016 3:31 pm
by Reefology
thanks for the reply Lee. can I change it to
ReefAngel.DCPump.SyncOffset=85;
if the primary is the bigger pump? Or
ReefAngel.DCPump.AntiSyncOffset=115; ?
Posted: Thu Dec 22, 2016 8:25 pm
by Reefology
thanks Lee, found the thread
http://forum.reefangel.com/viewtopic.ph ... SyncOffset
will link it here for others.
thanks
Posted: Sat Dec 24, 2016 6:43 pm
Reefology wrote:thanks for the reply Lee. can I change it to
I think you can do that as well. It just makes that a percentage and multiplies it against the sync pump's speed.
