Blank Screen RAStar
PostPosted: Fri Jan 06, 2017 5:33 am
Hello Rimai,
Uapp is not working for me :-( : uapp/
Cloud setting : xender and my forum password
I reseted my forum password as you ask
here is my code :
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
    //InternalMemory.LCDID_write(255);
    ReefAngel.Star();
    ReefAngel.AddPHExpansion();  // pH Expansion Module
    ReefAngel.SetTemperatureUnit( Celsius );  // set to Celsius Temperature
    ReefAngel.FeedingModePorts = Box1_Port8;
    ReefAngel.WaterChangePorts = Box1_Port8;
    //ReefAngel.OverheatShutoffPorts = Box1_Port1 | Box1_Port2;
    // Ports turned off when Leak is detected
    ReefAngel.LeakShutoffPorts = Box1_Port1 | Box1_Port2;
    //ReefAngel.LightsOnPorts = Box1_Port1 | Box1_Port2;
    InternalMemory.OverheatTemp_write( 300 );
    //ReefAngel.Relay.On( Box1_Port5 );
    //ReefAngel.Relay.On( Box1_Port8 );
    ReefAngel.Portal("Xender","xxxx");
    //ReefAngel.Network.WifiAuthentication("xxxx:xxxxx");
    //ReefAngel.StandardLights( Box1_Port1,8,0,23,0 );
    //ReefAngel.StandardLights( Box1_Port2,8,0,23,0 );
    //ReefAngel.PWM.SetDaylight( PWMSlope( 9,0,23,0,15,70,60,0 ) );
    //ReefAngel.PWM.SetActinic( PWMSlope( 9,0,23,0,15,70,60,0 ) );
    //ReefAngel.PWM.SetDaylight2( PWMSlope( 9,0,23,0,15,70,60,0 ) );
    //ReefAngel.PWM.SetActinic2( PWMSlope( 9,0,23,0,15,70,60,0 ) );
    ReefAngel.PWM.SetChannel( 0,PWMSlope( 8,0,23,0,15,70,60,0 ) );
    ReefAngel.PWM.SetChannel( 1,PWMSlope( 8,0,23,0,15,70,60,0 ) );
    ReefAngel.PWM.SetChannel( 2,PWMSlope( 8,0,23,0,15,70,60,0 ) );
    ReefAngel.PWM.SetChannel( 3,PWMSlope( 8,0,23,0,15,70,60,0 ) );
    ReefAngel.PWM.SetChannel( 4,PWMSlope( 8,0,23,0,15,70,60,0 ) );
    boolean buzzer=false;
    if ( ReefAngel.IsLeakDetected() )
        buzzer=true;
      } else
        buzzer=false;
     if ( ReefAngel.isOverheat() )
        buzzer=true;
      } else
        buzzer=false;
    if ( buzzer ) ReefAngel.BuzzerOn(2); else ReefAngel.BuzzerOff();
    //CO2
    ReefAngel.CO2Control( Box1_Port5,720,710 );
   if ( (weekday() == 1) || (weekday() == 7) ) // Sunday or Saturday
   // 0 - on hour, 1 - on minute, 2 - off hour, 3 - off minute
   // 4 - on hour, 5 - on minute, 6 - off hour, 7 - off minute
      ReefAngel.StandardLights(Box1_Port1, 8,0,23,0 );  // Weekend schedule
      ReefAngel.StandardLights(Box1_Port2, 8,0,23,0 );  // Weekend schedule
     } else
      ReefAngel.StandardLights(Box1_Port1,8,0,23,0 );  // Weekday schedule  (use standard internal memory values)
      ReefAngel.StandardLights(Box1_Port2,8,0,23,0 );  // Weekday schedule  (use standard internal memory values)
    ReefAngel.Network.Cloud();
    ReefAngel.ShowTouchInterface();
// RA_STRING1=xxxx
// RA_STRING2=null
// RA_STRING3=null
Salt Water Aquarium 60*60*60
PostPosted: Fri Jan 06, 2017 10:42 am
Just to be sure, your code does have the RA_STRING1 in it and you just erased, right?
RA_STRING1 is the password that RA will use to connect to the cloud server.
If you reset it after you encrypted the password, you will have to generate the code again to encrypt the password again.
Previous
Return to How do I code ...
Users browsing this forum: Bing [Bot] and 4 guests
