IO Expansion methods
Posted: Sat Jan 07, 2017 5:34 pm
by Diverjoe
I just got my Water Level and IO Expansion and Expansion hub yesterday. Got the WL all calibrated and it is working GREAT! Should have done this long ago. I do daily water changes and by using the high and low ATO memvars I can dial in EXACTLY how much water to drain before turning the ATO back on. Also, I noticed it had come on alot over night and realized that i had the upper limit set above may overflow drain and so the RO was running ever 30-45 min. i was able to keep dialing it down while i was out to running errands this morning until I got it below the overflow mark. This was all done on my phone!!!! Its freakin cool!!!!
This evening I have turned my attention to start using the IO and have run into a bit of a snafu.....
I have scoured the forum, the code (even stepping through every instance of "IO" in ReefAngle.ccp) and google for info on how to use the IO Expansion. The only thing i have found is this rather old reference which appears to be from when it was in its infancy.
http://forum.reefangel.com/viewtopic.ph ... 7&start=10
The IO class itself only has one method - GetChannel which appears to only do a read. That would be the "Output" part of IO, but how do you write to it? Also, how do you address each individual pin on the device?
A couple of code snippets should be able to get me on my way.
#define Mem_B_MoonOffset      100
#define Mem_B_Vacation        101
#define Mem_B_AutoFeed        102
#define Mem_B_AutoFeedPress   103
#define Mem_B_AutoFeedRepeat  104
#define Mem_B_AutoFeedOffset  105
#define Mem_I_WCFillTime      106
byte wc_status = 0;
time_t ato_endfill;
byte ato_topping = 0;
void init_memory() {
    InternalMemory.write(Mem_B_Vacation,false);
    InternalMemory.write(Mem_B_AutoFeed,true);
    InternalMemory.write(Mem_B_AutoFeedPress,2);
    InternalMemory.write(Mem_B_AutoFeedRepeat,4);
    InternalMemory.write(Mem_B_AutoFeedOffset,3);
    InternalMemory.write_int(Mem_I_WCFillTime,1200  );  //How long topoff is allowed to run
// Define Relay Ports by Name
#define T5Light            1
#define LEDLights          2
#define ATODrain           3
#define Feeder             4
#define Mixer              5
#define Topoff             6
#define Ferts              7
#define Filter             8
    ReefAngel.Relay.Auto(Filter);
    init_memory();
    // Ports that default off
    ReefAngel.Relay.Off(ATODrain);
    ReefAngel.Relay.Off(Feeder);
    ReefAngel.Relay.Off(Mixer);
    ReefAngel.Relay.Off(Ferts);
    ReefAngel.CustomLabels[0]="T5 Light";
    ReefAngel.CustomLabels[1]="LED";
    ReefAngel.CustomLabels[2]="Drain";
    ReefAngel.CustomLabels[3]="Feeder";
    ReefAngel.CustomLabels[4]="Mixer";
    ReefAngel.CustomLabels[5]="Topoff";
    ReefAngel.CustomLabels[6]="Ferts";
    ReefAngel.CustomLabels[7]="Filter";
    ReefAngel.Relay.On(Filter);
    ReefAngel.StandardLights( LEDLights);
    ReefAngel.StandardLights( T5Light);
    ReefAngel.PWM.SetActinic( PWMSlope(9,0,20,0,15,100,60,15) );
    //Automation
    //RunFeeder();
    //Water Change
    if (hour() == InternalMemory.DP1Timer_read() && minute() == InternalMemory.DP1RepeatInterval_read()) {
        wc_status = 1;
    if (wc_status > 0 ) {
        AutoWaterChange();
    //Keep Water topped off
    AutoTopOff();
    ReefAngel.Portal( "diverjoe" );
    ReefAngel.DDNS("75");
void AutoTopOff() {
//run for 30 sec any time float valve is turned on and WC drain is not active
    if (ato_endfill > now() && wc_status != 1 && ato_topping) {
        ReefAngel.Relay.On(Topoff);
    else {
        ReefAngel.Relay.Off(Topoff);
        ato_topping = 0;
        if ( ReefAngel.WaterLevel.GetLevel() < InternalMemory.WaterLevelLow_read  () && !ato_topping) {
            ato_endfill = now() + InternalMemory.ATOExtendedTimeout_read();
            ato_topping = 1;
}f
void RunFeeder() {
    boolean autoFeed;
    static time_t t;
    int press, repeat, offset;
    autoFeed=InternalMemory.read(Mem_B_AutoFeed);
    press=InternalMemory.read(Mem_B_AutoFeedPress);
    repeat=InternalMemory.read(Mem_B_AutoFeedRepeat)*SECS_PER_HOUR;
    offset=InternalMemory.read(Mem_B_AutoFeedOffset)*SECS_PER_HOUR;
    ReefAngel.Relay.Set(Feeder, autoFeed);
    if (ReefAngel.Relay.Status(Feeder)!=autoFeed) {
        autoFeed=ReefAngel.Relay.Status(Feeder);
        InternalMemory.write(Mem_B_AutoFeed, autoFeed);
        ReefAngel.Relay.Auto(Feeder);
    if (autoFeed) {
        if (((hour() > 9 && hour() < 20)) && (now()+offset)%repeat==0) {
            t=now();
    if (ReefAngel.Relay.isMaskOn(Feeder)) {
        t=now()-now()%20; // One feeding has already happened.
    // Press the button once every 20 seconds
    if (now()-t < press*20) {
        ReefAngel.Relay.Set(Feeder,now()%20==0);
    } else {
void AutoWaterChange() {
    int NowMins;
    static time_t t;
    if (wc_status == 1) {
        ReefAngel.Relay.Override(Topoff,0);
        ReefAngel.Relay.Off(Filter);
        ReefAngel.Relay.Auto(ATODrain);
        ReefAngel.Relay.On(ATODrain);
    if(ReefAngel.WaterLevel.GetLevel() < InternalMemory.WaterLevelHigh_read() && wc_status == 1)
        wc_status = 2;   //Enter Mix mode
        ReefAngel.Relay.On(Mixer);
        ReefAngel.Relay.Auto(Topoff);
        t = now();
    //Ferts Mode
    if ( wc_status == 2) {
        if (now() - t > SECS_PER_MIN  * InternalMemory.DP2Timer_read()) {
            wc_status = 3;   //enter Ferts mode
            ReefAngel.Relay.On(Ferts);
            t = now();
    //ferts Mode
    if ( wc_status == 3) {
        if (now() - t > InternalMemory.DP2RepeatInterval_read()) {
            wc_status = 0;
// Disable masks for things that should not be turned on by mistake
void LockPorts() {
    ReefAngel.AddPortOverrides();
Re: IO Expansion methods
Posted: Sat Jan 07, 2017 7:24 pm
Are you trying to use it as output or input?
Posted: Sat Jan 07, 2017 7:39 pm
by Diverjoe
I will use some as input only and some as outputs
Posted: Sat Jan 07, 2017 10:57 pm
As input, it is easy.
if (ReefAngel.IO.GetChannel(0))
As output, we don't have a library for it.
The reason is that it is not recommended unless you really know what you doing and understand a little of electronics.
Each channel is only capable of driving 25mA. So, you can't really drive anything more than a small LED.
So, you are better off using one of the relays for output rather than the I/O.
Posted: Sun Jan 08, 2017 8:41 am
by Diverjoe
i am not an expert, but i do know the basics about electronics. I will mostly be driving a relay for my 5v/12v stuff.
Posted: Sun Jan 08, 2017 10:38 am
Ok. good.
So, just make sure you do not drive the relay directly from the pin of the I/O module.
You need a relay driver with a feedback diode.
Something like this:
http://www.learningaboutelectronics.com ... ircuit.php
Posted: Sun Jan 08, 2017 12:16 pm
by Diverjoe
yea, i have an opto isolated relay like the sainsmart i had from a netduino project.
Posted: Sun Jan 08, 2017 2:08 pm
Ok, so you are good.
You can update the I/O module just like the relay box, except you change the address to the I/O expansion module.
It uses the same chipset PCF8574.
    Wire.beginTransmission(I2CIO_PCF8574);
    Wire.write(data);
    Wire.endTransmission();
Where data is what you want to output.
Posted: Sun Jan 08, 2017 2:40 pm
by Diverjoe
Wow that is plenty easy enough. But one question. Which of the 6 will that data be sent to?
Posted: Sun Jan 08, 2017 8:45 pm
by Diverjoe
[quote="rimai"]As input, it is easy.
After learning how I2C works and seeing how it is
used then reviewing the schematic I have come to
Understand that the is a I2C slave based off the 328p.
With that in mind I looked back at all the code libraries
Especially the expansion libraries. I am not seeing how
I can get more that a bit from the IO expansion. Will it
Return more than 1 byte as in the io library? I can only
assume that there is some code running on the 328p that
"Packages" the data from the 6 pins into 1 byte.
Please help me understand how to talk to this thing.
Posted: Sun Jan 08, 2017 9:04 pm
You got the wrong version.
The new I/O modules are version 2.2.
I updated the download page with the v2.2 eagle files.
They no longer use 328p. They use PCF8574 as I mentioned above.
Posted: Mon Jan 09, 2017 9:23 am
by Diverjoe
I read about the PCF8574 chip on TI's site. Seems straight forward - less complex than using the 328P. But the question remains. How do I get more than just an on/off value from it?
BTW - I cannot seem to locate the 2.2 eagle files for IO on the download page. :-(
Posted: Mon Jan 09, 2017 10:48 am
What do you mean as more than on/off?
Try refreshing the browser.
Posted: Thu Jan 19, 2017 3:30 pm
by Diverjoe
Like
X = analogRead( i2cio-pin1)
Also didn't find newer Eagle files
And how do you send data to pin 1 vs pin3? I get the example above except for this.
Posted: Thu Jan 19, 2017 6:07 pm
No. For reading, just use the code I posted before:
http://forum.reefangel.com/viewtopic.php?p=54240#p54240
Posted: Thu Jan 19, 2017 7:05 pm
by Diverjoe
rimai wrote:No. For reading, just use the code I posted before:
Not sure how I missed the 0 in channel.
