Newbie questions
PostPosted: Sat Jan 14, 2017 8:43 am
Hi,
I have got a reef angel plus controller which does basic functionality . The code is pasted below .
I would like to get access to the pH graph to monitor my pH . Also , I would like to use 2 temperature probes instead of 1.
How to configure them ?
Requesting your help ..
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.FeedingModePorts = Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port7Bit;
    ReefAngel.Relay.On( Port5 );
    ReefAngel.StandardHeater( Port1,770,775 );
    ReefAngel.StandardHeater( Port2,771,776 );
    ReefAngel.StandardHeater( Port3,772,777 );
    ReefAngel.MHLights( Port4,17,0,21,0,10 );
    ReefAngel.Relay.DelayedOn( Port7,1 );
PostPosted: Sat Jan 14, 2017 9:50 am
Not sure about the pH graph. I think it was depreciated, unless you're using WiFi then you can see it on the portal.
As far as another temp probe, that's easy. Just plug it in. Reboot the RA and it will start working. The probe with the lowest serial number (hard coded into the probe) becomes T1_PROBE and the other one becomes T2_Probe. This may be opposite from what you expect, so be prepared to switch the probe positions in your tank or do some re-coding to accommodate. Reboot the RA and it will start working.
Return to How do I code ...
