Output Strings in CustomVar[]
PostPosted: Mon Jan 16, 2017 10:28 am
Hi all,
I was wondering if it's possible to output strings to the ReefAngel.CustomVar[] array?
I am using the Cloud() and SunLocation() functions and would like to use the CustomVar[] globals to output formatted times.
For example Cloud() has a line of code to store the next cloud hour and minute in ReefAngel.CustomVar[], which by default are stored as separate byte values. Would it be possible to convert and combine the "value of the hour" + ":" + "value of minute" to output something like "13:30" in a CustomVar[]?
Thank you!
Since I was intending on viewing this data on the RA app, I do not think it will be possible since the app field is probably expecting a byte value.
Return to How do I code ...
