Off set my Daylight and Actinics?
Posted: Mon Mar 13, 2017 8:50 am
by GugsJr
So I have my code in the memory but I want to offset my Actinics and Daylights.
***I want to Offset my LED fixtures by an hour of each other.
***I don't want my moonlights to be opposite of my daylights.
***Also I want my refugium to lights to stay on for 30 minutes after my Daylights come on and Go on 30 before my daylights go off.
I know I'd need an offset command but I'm not sure exactly what the command would be.
Here is my current code:
ReefAngel.FeedingModePortsE[0] = Port2Bit;
ReefAngel.WaterChangePorts = Port6Bit;
ReefAngel.OverheatShutoffPorts = Port5Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port5Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.ActinicLights( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.DayLights( Port4 );
ReefAngel.StandardHeater( Port5 );
ReefAngel.StandardHeater( Box1_Port3 );
ReefAngel.StandardHeater( Box1_Port5 );
ReefAngel.StandardATO( Box1_Port6 );
ReefAngel.MoonLights( Box1_Port7 );
ReefAngel.PWM.Channel1PWMParabola();
ReefAngel.PWM.Channel2PWMParabola();
ReefAngel.PWM.Channel3PWMParabola();
ReefAngel.PWM.Channel4PWMParabola();
ReefAngel.DCPump.ExpansionChannel[0] = Sync;
Re: Off set my Daylight and Actinics?
Posted: Mon Mar 13, 2017 5:14 pm
by GugsJr
Does this look right?
ReefAngel.ActinicLights( Port1, InternalMemory.ActinicLights_read(-10,70) ); // Off set 10 minutes before start time but an hour and 10 minutes after end time
ReefAngel.ActinicLights( Port2, InternalMemory.ActinicLights_read(0,240) ); // Offset 4 hours after end time
ReefAngel.DayLights( Port3, InternalMemory.DayLights_read(420,240) ); // Off set Daylight 7 Hours after start and 4 hours after end
ReefAngel.DayLights( Port4, InternalMemory.ActinicLights_read(480,300) ); // Off set Daylight 8 hours after start and 5 hours after end
ReefAngel.MoonLights( Box1_Port7, InternalMemory.Moonlights_read(-30,30) ); // Off set by 30 minutes after start and before end ( of Moonlight )
Posted: Mon Mar 13, 2017 7:36 pm
by GugsJr
Didn't work. I got this
sketch_mar13a.cpp: In function 'void loop()':
sketch_mar13a:80: error: 'class InternalEEPROMClass' has no member named 'ActinicLights_read'
sketch_mar13a:81: error: 'class InternalEEPROMClass' has no member named 'ActinicLights_read'
sketch_mar13a:82: error: 'class InternalEEPROMClass' has no member named 'DayLights_read'
sketch_mar13a:83: error: 'class InternalEEPROMClass' has no member named 'ActinicLights_read'
sketch_mar13a:88: error: 'class InternalEEPROMClass' has no member named 'Moonlights_read'
Posted: Tue Mar 14, 2017 8:05 am
Read just takes a memory location. Not sure why you have 2 arguments there?
Posted: Tue Mar 14, 2017 8:11 am
by GugsJr
lnevo wrote:Read just takes a memory location. Not sure why you have 2 arguments there?
I'm trying to offset the start time and end time
Posted: Mon Mar 20, 2017 3:31 pm
Offset is one argument that affects both start and end equally. If you want to do granular you'll need to pass every argument to the Lights() functions. But InternalMemory.read() only takes one argument which is the memory location that you want to read. Also your time for before and after is the same so you should just use the one arg for offset it already does +/- unless you want it to start early and end early (default is start early, end late) or vice-versa. Sorry if its confusing. I'll post some better sample code once I know what your trying to do better
Posted: Mon Mar 20, 2017 9:18 pm
by GugsJr
This is what I have currently. I'm trying to get it so when I change something in the portal or the app it changes the lights for all of them. That way if my work schedule changes I just can do it quickly without having to go back and upload the code.
I'm assuming this is starting from the daylight on off time of On at 4pm and off at 10pm
ReefAngel.PWM.Channel1PWMParabola(); //Front Whites 4:00pm-10:00pm
ReefAngel.PWM.Channel2PWMParabola(90); //Back Blues 2:30pm-11:30pm
ReefAngel.PWM.Channel3PWMParabola(30); //Back Whites 4:30pm-10:30pm
ReefAngel.PWM.Channel4PWMParabola(120); //Back Blues 3:00pm-12:00AM
Posted: Tue Mar 21, 2017 1:39 pm
by GugsJr
Actually it is working. I had a different part of my code that was conflicting with this one.
This is the code that is actually working. I think I'll post my conflicting code into its own thread. Than you for your help.
    ReefAngel.PWM.Channel3PWMParabola(-30,30); //Back Whites 4:30pm-10:30pm
