auto feed code not working.
Posted: Mon Mar 20, 2017 4:31 pm
by GugsJr
I'm sure I have a setting off some where in here but I can't figure it out.
I thought I had it set to go into feed mode at 5pm and then cycle port 6.
After feed mode to go in to Nutrient Transport Mode for 2.5 hours.
Looking at the relay graph it doesn't seem like it went into feed mode.
Any help would be appreciated
// Define Relay Ports by Name
#define Feeder             Port6
int DaylightPWMValue0=0;        // For cloud code, channel 0
int DaylightPWMValue2=0;        // For cloud code, chennel 2
    ReefAngel.DCPump.ActinicChannel=Sync; // Now you're pump will be affected by the portal settings.
    ReefAngel.DCPump.DaylightChannel=AntiSync; // Now you're pump will be affected by the portal settings.
    ReefAngel.DCPump.Threshold=30; //Jebao won't go over 30%
    ReefAngel.OverheatShutoffPorts = Port5Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port5Bit;
    ReefAngel.Relay.On( Port7 );
// seasonal temperatures
    SeasonalTemps();
    ReefAngel.StandardLights( Port1,14,25,1,5 );
    ReefAngel.StandardLights( Port2,14,25,3,10 );
    ReefAngel.StandardLights( Port3,22,55,2,30 );
    ReefAngel.StandardLights( Port4,23,55,3,0 );
    ReefAngel.StandardATO( Box1_Port6 );
    ReefAngel.MoonLights( Box1_Port7 );
   ReefAngel.PWM.SetChannel( 1, PWMSlopeHighRes(14,30,23,30,1,50,240,0) );  // Schedule for front blues 2:30pm-11:30pm
ReefAngel.PWM.SetChannel( 3, PWMSlopeHighRes(15,0,0,0,0,50,240,0) ); // Schedule for rear blues 3pm-Midnight
DaylightPWMValue0=PWMSlopeHighRes(16,00,22,0,0,35,240,0);    //  Schedule for front whites 4pm-10pm
DaylightPWMValue2=PWMSlopeHighRes(16,30,22,00,0,35,240,0); // Schedule for rear whites 4:30pm-10:30pm
CheckCloud();    //  Check for cloud and slow lightning.
ReefAngel.PWM.SetChannelRaw(0,DaylightPWMValue0);  //  Write values for either default or cloud/slow
ReefAngel.PWM.SetChannelRaw(2,DaylightPWMValue2);  //  lightning if it's time.
    ReefAngel.DCPump.ExpansionChannel[0] = Sync;
// Lights turned on set Blues to 50% and whites to 35%
if (bitRead(ReefAngel.StatusFlags,LightsOnFlag))
     ReefAngel.PWM.SetChannel( 1,(35) ); //Set Front Daylight 35%
     ReefAngel.PWM.SetChannel( 2,(50) ); //Set Front Actinics 50%
     ReefAngel.PWM.SetChannel( 3,(35) ); //Set Rear Daylight 35%
     ReefAngel.PWM.SetChannel( 4,(50) ); //Set Rear Actinics 50%
//AutoFeeder
static unsigned long autofeeding = 0;
if ((now()%SECS_PER_DAY==61200)) //if it is 5 pm
ReefAngel.FeedingModeStart(); //START FEEDING MODE
if ( autofeeding == 0 ) {
autofeeding = now(); //set the time of the start of feeding to variable feeding
if ((now()-autofeeding>=60) && (now()-autofeeding<=61)) //if between 60 and 61 seconds has past
ReefAngel.Relay.On(Feeder); //TURN FEEDER RELAY ON
ReefAngel.Relay.Off(Feeder); //TURN FEEDER RELAY OFF
} else {
if ( autofeeding > 0 ) {
autofeeding = 0;
// Add random mode if we set to Mode to Custom in portal
static int rmode;
byte modes[] = { ReefCrest, Gyre, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else, };
if (now()%SECS_PER_DAY==0 || changeMode==true) { // Change at midnight or if controller rebooted
rmode=random(100)%sizeof(modes); // Change the mode once per day to pick from our array
changeMode=false;
static unsigned long feeding;
if (now()-feeding<9000) {
  // Continue NTM for the 2 hours 30 minutes
  ReefAngel.DCPump.Mode=NutrientTransport;
} else if (now()%SECS_PER_DAY<1800 || now()%SECS_PER_DAY>=52200) { // 12:30am / 2:30pm
  // Night mode (go to 30%)
  ReefAngel.DCPump.Mode=Lagoon;
  ReefAngel.DCPump.Speed=15;
} else if (InternalMemory.DCPumpMode_read()==11) {
  ReefAngel.DCPump.Mode=modes[rmode];  // Put the mode to the random mode :)
} else {
    ReefAngel.Portal( "GugsJr" );
    ReefAngel.DDNS( "Home" ); // Your DDNS is GugsJr-Home.myreefangel.com
//Custom Main, Graph & Menu
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
 ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 6, 2, "GugsJr’s ReefAngel");
 ReefAngel.LCD.DrawDate(6, 118);
 ReefAngel.LCD.Clear(COLOR_BLACK, 1, 17, 132, 17);
  ReefAngel.LCD.DrawLargeText(0,255,10,16,"  Jebao Mode:");
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,27,"Constant");
  else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,26,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,26,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,26,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,26,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,26,"Nutrient Trnsp.");
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,26,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,255,45,26,"Night");
  ReefAngel.LCD.DrawLargeText(0,255,17,49,"Display Temp");
  ReefAngel.LCD.DrawHugeText(COLOR_RED, 255, 12, 65, text, Num12x16);
  ReefAngel.LCD.DrawLargeText(0,255,100,40,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 89, 55, text, Num8x8);
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,14,89, "Jebao Left");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,19,100, ReefAngel.PWM.GetDaylightValue());
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,37,89, "Jebao Center");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,38,100, ReefAngel.PWM.GetActinicValue());
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,88,89, "Jebao Right");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,95,100, ReefAngel.PWM.GetDaylightValue());
void SeasonalTemps ()
  static int heatArray[][2] = { {780,785},// default in case of error in month=0 (June)
                    {770,774},//January (winter) 77.2
                    {774,778},//February (winter) 77.6
                    {775,779},//March (early spring) 77.7
                    {779,783},//April (spring) 78.1
                    {785,789},//May (spring) 78.7
                    {792,796},//June (early summer) 79.4
                    {799,803},//July (summer) 80.1
                    {806,810},//August (summer) 80.8
                    {796,800},//September (early fall) 79.8
                    {787,791},//October (fall) 78.9
                    {780,784},//November (fall) 78.2
                    {775,779} };//December (early winter) 77.7
ReefAngel.StandardHeater(Port5,heatArray[month()][0],heatArray[month()][1]);
ReefAngel.StandardHeater(Box1_Port3,heatArray[month()][0],heatArray[month()][1]);
ReefAngel.StandardHeater(Box1_Port5,heatArray[month()][0],heatArray[month()][1]);
 }//end seasonalTemps
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 75
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 7
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 2
  // In this example, start cloud after 5pm
#define Start_Cloud_After NumMins(17,00)
#define End_Cloud_Before NumMins(21,00)
#define Lightning_Change_per_Cloud 0
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes
  // of effects or unforseen result could happen.
  // In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the
  // 250 minutes (or 500 minutes) can fit in that 510 minutes window.
  // Add Random Lightning modes
#define Calm 0    // No lightning
#define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4   // Like Mega, but with more lightning
  // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
  // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
  byte LightningModes[] = {Calm,};
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
  static byte lightningMode=0;
  static time_t DelayCounter=millis();    // Variable for lightning timing.
  static int DelayTime=random(1000);      // Variable for lightning timimg.
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      randomSeed(millis());    // Seed the random number generator
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue/40.95,0,180)*40.95;
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
        // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          // Send the trigger
          Strike();
          DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
          DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
        break;
      case Mega2:
        // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
        // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
          else lightningstatus=0;
          if (lightningstatus)
            DaylightPWMValue=4095;
            DaylightPWMValue=0;
          delay(1);
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
    /*ReefAngel.LCD.Clear(255,0,120,132,132);
     ReefAngel.LCD.DrawText(0,255,51,120,"00:00"); */
      int x=0;
      else x=17;
      //ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart/60));
      ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
      else x=35;
      //ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart%60));
      ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
    //ReefAngel.LCD.DrawText(0,255,90,120,cloudduration);
    ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/2))/60)>=10) x=51;
      else x=57;
      //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))/60));
      ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      if (((cloudstart+(cloudduration/2))%60)>=10) x=69;
      else x=75;
      //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
        ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
void Strike()
  int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
  for (int i=0; i<a; i++)
    // Flash on
    int newdata=4095;
    Wire.beginTransmission(0x40);      // Address of the dimming expansion module
    Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
    Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
    Wire.write(newdata>>8);            // This sends the MSB
    Wire.endTransmission();
    int randy=random(20,80);    // Random number for a delay
    if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
    delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
    // Flash off.  Return to baseline.
    newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
    Wire.beginTransmission(0x40);    // Same as above
    delay(random(30,50));                // Wait from 30 to 49 ms
    wdt_reset();    // Reset watchdog timer to avoid re-boots
  cstart*=60;
  cend*=60;
  if (n>cend) return (int) PWMStart;
// RA_STRING2=null
// RA_STRING3=null
Re: auto feed code not working.
Posted: Tue Mar 21, 2017 4:00 am
by cosmith71
Try changing this line:
to something like this.
if (hour()==17 && minute()==0 && second() <= 2)
Posted: Tue Mar 21, 2017 11:32 am
by GugsJr
Thank you
That worked great. Now a new problem arose.
I also feed the fish Mysis shrimp at 9pm. Is there a way to get port 6 to stay off at 9pm?
Posted: Tue Mar 21, 2017 3:11 pm
by GugsJr
Would this work?
I just change the code from between 60 secs and 61 secs passed to turn on. To if it's a set time?
//AutoFeeder
if (hour()==17 && minute()==0 && second() <= 2)//if it is 5 pm
iif (hour()==17 && minute()==1 && second() <= 1)//if it is 5:01.01 pm
} else {
autofeeding = 0;
