Lights on mode isn't working.
Posted: Tue Mar 21, 2017 1:43 pm
I need help with a certain part of my code and the lights.
Since my LEDs dim to 0 when I use lights on it doesn't work with my current code. I can get the lights to come on but not go back to 0 after I use lights off.
Current Code
This works to turn them on but I can't figure out how to get them to go off after using lights off
Current Code
// Define Relay Ports by Name
#define Feeder Port6
ReefAngel.DCPump.DaylightChannel=AntiSync; // Now you're pump will be affected by the portal settings.
ReefAngel.DCPump.Threshold=30; //Jebao won't go over 30%
ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port5Bit;
ReefAngel.Relay.On( Port7 );
// seasonal temperatures
SeasonalTemps();
ReefAngel.StandardLights( Port1,14,25,1,5 );
ReefAngel.StandardLights( Port2,14,25,3,10 );
ReefAngel.StandardLights( Port3,22,55,2,30 );
ReefAngel.StandardLights( Port4,23,55,3,0 );
ReefAngel.PWM.Channel1PWMParabola(); //Front Whites 4:00pm-10:00pm
ReefAngel.PWM.Channel2PWMParabola(90); //Back Blues 2:30pm-11:30pm
ReefAngel.PWM.Channel3PWMParabola(-30,30); //Back Whites 4:30pm-10:30pm
ReefAngel.PWM.Channel4PWMParabola(120); //Back Blues 3:00pm-12:00AM
ReefAngel.StandardATO( Box1_Port6 );
ReefAngel.StandardLights( Box1_Port7,22,0,17,0 );
ReefAngel.DCPump.ExpansionChannel[0] = Sync;
//AutoFeeder
static unsigned long autofeeding = 0;
if (hour()==17 && minute()==0 && second() <= 2)//if it is 5 pm
ReefAngel.FeedingModeStart(); //START FEEDING MODE
if ( autofeeding == 0 ) {
autofeeding = now(); //set the time of the start of feeding to variable feeding
if ((now()-autofeeding>=60) && (now()-autofeeding<=61)) //if between 60 and 61 seconds has past
ReefAngel.Relay.On(Feeder); //TURN FEEDER RELAY ON
ReefAngel.Relay.Off(Feeder); //TURN FEEDER RELAY OFF
} else {
if ( autofeeding > 0 ) {
autofeeding = 0;
static int rmode;
byte modes[] = { ReefCrest, Gyre, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else, };
changeMode=false;
static unsigned long feeding;
if (now()-feeding<9000) {
// Continue NTM for the 2 hours 30 minutes
} else if (now()%SECS_PER_DAY<1800 || now()%SECS_PER_DAY>=52200) { // 12:30am / 2:30pm
// Night mode (go to 15%)
ReefAngel.DCPump.Mode=Lagoon;
ReefAngel.DCPump.Speed=15;
} else {
ReefAngel.Portal( "GugsJr" );
ReefAngel.DDNS( "Home" ); // Your DDNS is GugsJr-Home.myreefangel.com
//Custom Main, Graph & Menu
void DrawCustomMain() {
byte x = 6;
byte y = 2;
byte t;
char text[7];
ReefAngel.LCD.DrawLargeText(COLOR_WHITE, COLOR_BLACK, 6, 2, "GugsJr’s ReefAngel");
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 17, 132, 17);
ReefAngel.LCD.DrawLargeText(0,255,10,16," Jebao Mode:");
if (ReefAngel.DCPump.Mode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,27,"Constant");
else if(ReefAngel.DCPump.Mode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,26,"Lagoon");
else if (ReefAngel.DCPump.Mode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,26,"Reef Crest");
else if (ReefAngel.DCPump.Mode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,26,"Short Pulse");
else if (ReefAngel.DCPump.Mode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,26,"Long Pulse");
else if (ReefAngel.DCPump.Mode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,26,"Nutrient Trnsp.");
else if (ReefAngel.DCPump.Mode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,26,"Tidal Swell");
else if (ReefAngel.DCPump.Mode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,255,45,26,"Night");
ReefAngel.LCD.DrawLargeText(0,255,17,36,"Display");
ReefAngel.LCD.DrawLargeText(0,255,17,49,"Temp");
ReefAngel.LCD.DrawHugeText(COLOR_RED, 255, 12, 65, text, Num12x16);
ReefAngel.LCD.DrawLargeText(0,255,100,36,"pH");
ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 89, 55, text, Num8x8);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,16,80, "Jebao");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,16,89, "Left");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,16,100, ReefAngel.PWM.GetDaylightValue());
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,64,80, "Jebao");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,64,89, "Center");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,38,100, ReefAngel.PWM.GetActinicValue());
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,96,80, "Jebao");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,96,89, " Right");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,96,100, ReefAngel.PWM.GetDaylightValue());
void SeasonalTemps ()
static int heatArray[][2] = { {780,785},// default in case of error in month=0 (June)
{770,774},//January (winter) 77.2
{774,778},//February (winter) 77.6
{775,779},//March (early spring) 77.7
{779,783},//April (spring) 78.1
{785,789},//May (spring) 78.7
{792,796},//June (early summer) 79.4
{799,803},//July (summer) 80.1
{806,810},//August (summer) 80.8
{796,800},//September (early fall) 79.8
{787,791},//October (fall) 78.9
{780,784},//November (fall) 78.2
{775,779} };//December (early winter) 77.7
ReefAngel.StandardHeater(Port5,heatArray[month()][0],heatArray[month()][1]);
ReefAngel.StandardHeater(Box1_Port3,heatArray[month()][0],heatArray[month()][1]);
ReefAngel.StandardHeater(Box1_Port5,heatArray[month()][0],heatArray[month()][1]);
}//end seasonalTemps
// RA_STRING2=null
// RA_STRING3=null
// Lights turned on set Blues to 50% and whites to 35%
if (bitRead(ReefAngel.StatusFlags,LightsOnFlag))
ReefAngel.PWM.SetChannel( 1,(35) ); //Set Front Daylight 35%
ReefAngel.PWM.SetChannel( 2,(50) ); //Set Front Actinics 50%
ReefAngel.PWM.SetChannel( 3,(35) ); //Set Rear Daylight 35%
ReefAngel.PWM.SetChannel( 4,(50) ); //Set Rear Actinics 50%
