Custom Menu data screens
jsclownfish
Post by jsclownfish »
I've been trying to squeeze more info on my main screen and I may have found a solution that works for me. I moved a bunch of detail info (peaks, graphs) on temp and pH to the menu screens and that frees up a bunch of space on the main screen. I noticed though that the current temp/pH doesn't update on the menu selected screen as it does on the main. Is there something I need to change in the code? Also, it would be cool to generate the same graph for the flow. Maybe that will be possible with some of the changes you are thinking about with user defined variables other than temp or pH?
Jon
Here's the working pde...
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <ReefAngel_Colors.h>
//Actinic and Daylight PMW are on the LED moonlights
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
int maxTemp=0;
int minTemp=2000;
int maxPH=0;
int minPH=1000;
int flow =0;
int maxflow=0;
int minflow=1000;
time_t tsmax=now();
time_t tsmin=now();
time_t PHmax=now();
time_t PHmin=now();
time_t flowmax=now();
time_t flowmin=now();
byte wmport=Port5;
boolean wmdelay=false;
byte wmpulse=0;
#include <avr/pgmspace.h>
//Menu Items
prog_char menu3_label[] PROGMEM = "Temp Detail";
prog_char menu4_label[] PROGMEM = "pH Detail";
prog_char menu5_label[] PROGMEM = "Flow Detail";
PROGMEM const char *menu_items[] = {menu1_label, menu2_label, menu3_label,menu4_label,menu5_label};
// Labels for the web banner
prog_char id_label[] PROGMEM = "jsclownfish";
prog_char probe1_label[] PROGMEM = "Tank";
prog_char probe3_label[] PROGMEM = "Sump";
prog_char relay1_label[] PROGMEM = "Heater1";
prog_char relay2_label[] PROGMEM = "Heater2";
prog_char relay3_label[] PROGMEM = "MHalide";
prog_char relay4_label[] PROGMEM = "Actinic";
prog_char relay5_label[] PROGMEM = "WM1";
prog_char relay6_label[] PROGMEM = "WM2";
prog_char relay7_label[] PROGMEM = "Main";
prog_char relay8_label[] PROGMEM = "Fan";
   relay3_label, relay4_label, relay5_label, relay6_label, relay7_label, relay8_label};
void DrawTime(byte x, byte y, byte FGcolor, byte BGcolor, time_t ts)
//byte iTimeHourOffset=0;
    char text[13];
    char temp[]="  ";
    strcpy(text,"");
    //if (iTimeHour>12) iTimeHourOffset=12;
    itoa(hourFormat12(ts),temp,10);
    if (temp[1]==0) strcat(text,"0");
    strcat(text,temp);
    strcat(text,":");
    itoa(minute(ts),temp,10);
    strcat(text,temp);
    strcat(text,":");
    itoa(second(ts),temp,10);
    strcat(text,temp);
    if (isAM(ts))
        strcat(text," AM");
        strcat(text," PM");
    ReefAngel.LCD.DrawText(FGcolor, BGcolor, x, y, text);
// update the min and max temps
if (now()%86400==0)
  minTemp=ReefAngel.Params.Temp1;
  maxTemp=ReefAngel.Params.Temp1;
if (ReefAngel.Params.Temp1<minTemp)
  tsmin=now();
//  DrawTime(60,33);
if (ReefAngel.Params.Temp1>maxTemp)
  tsmax=now();
//  DrawTime(60,23);
//DrawTime(60,23,0, COLOR_WHITE,tsmax);
//DrawTime(60,33,0,COLOR_WHITE, tsmin);
// update the min and max pH
if (now()%86400==0)
  minPH=ReefAngel.Params.PH;
  maxPH=ReefAngel.Params.PH;
if (ReefAngel.Params.PH<minPH)
  PHmin=now();
//  DrawTime(60,33);
if (ReefAngel.Params.PH>maxPH)
  PHmax=now();
//  DrawTime(60,23);
// update the min and max flow
if (now()%86400==0)
  minflow=flow;
  maxflow=flow;
if (flow<minflow)
  minflow=flow;
  flowmin=now();
//  DrawTime(60,33);
if (flow>maxflow)
  maxflow=flow;
  flowmax=now();
//  DrawTime(60,23);
// Display the Tank temperature with color sensors
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,13,"TANK:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp1, COLOR_BLACK, 36, 13, 10);
//Display the pH
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 5, 44,"PH:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, 0, 23, 44, 100);
//Display the flo
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 5, 75,"FLOW:");
ReefAngel.LCD.DrawSingleMonitor(flow, 0,36,75, 1);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 66, 75,"gal/hr");
ReefAngel.LCD.DrawOutletBox(12, 110, TempRelay);
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.Clear(0, 1, 11, 132, 11);
void MenuEntry1()
  ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
//Temperature detail screen with sump and room temp, 24 hr. max/min, time stamps, and graph
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,23,"HI:");
ReefAngel.LCD.DrawSingleMonitor(maxTemp, 0, 23, 23, 10);
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,48,23,"at");
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,33,"LO:");
ReefAngel.LCD.DrawSingleMonitor(minTemp, 0, 23, 33, 10);
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,48,33,"at");
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor, 5 ,43,"R00M:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, COLOR_BLACK, 36, 43, 10);
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor, 5, 53,"SUMP:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, COLOR_BLACK, 36, 53, 10);
    ReefAngel.LCD.Clear(DefaultBGColor,0,75,131,125);
    ReefAngel.LCD.Clear(DefaultFGColor,1,75,1,125);
    for (byte i=6; i<=131; i+=3)
        ReefAngel.LCD.PutPixel(GraphDotLineColor, i, 100);
ReefAngel.LCD.DrawSingleGraph(T1TempColor,1,75,InternalMemory.T1Pointer_read());
ReefAngel.LCD.DrawSingleGraph(T2TempColor,1,75,InternalMemory.T1Pointer_read()+120);
ReefAngel.LCD.DrawSingleGraph(T3TempColor,1,75,InternalMemory.T1Pointer_read()+240);
bool bDone = false;
do
// wait indefinitely for a button press
delay(200);
if ( ReefAngel.Joystick.IsButtonPressed() )
bDone = true;
} while ( ! bDone );
void MenuEntry4()
//pH detail screen with 24 hr. max/min, time stamps, and graph
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 5, 13,"PH:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, 0, 36, 13, 100);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,5, 23,"HI:");
ReefAngel.LCD.DrawSingleMonitor(maxPH, 0, 23, 23, 100);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 48, 23,"at");
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 5, 33,"LO:");
ReefAngel.LCD.DrawSingleMonitor(minPH, 0, 23, 33, 100);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 48, 33,"at");
DrawTime(60,23,0, COLOR_WHITE,PHmax);
DrawTime(60,33,0,COLOR_WHITE, PHmin);
ReefAngel.LCD.DrawSingleGraph(PHColor,1,75,InternalMemory.T1Pointer_read()+360);
bool bDone = false;
do
delay(200);
bDone = true;
void MenuEntry5()
//Flow detail screen with 24 hr. max/min, & time stamps
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 5, 13,"FLOW:");
ReefAngel.LCD.DrawSingleMonitor(flow, 0,36,13, 1);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 66, 13,"gal/hr");
ReefAngel.LCD.DrawSingleMonitor(maxflow, 0, 23, 23, 1);
ReefAngel.LCD.DrawSingleMonitor(minflow, 0, 23, 33, 1);
DrawTime(60,23,0, COLOR_WHITE,flowmax);
DrawTime(60,33,0,COLOR_WHITE, flowmin);
bool bDone = false;
do
delay(200);
bDone = true;
  ReefAngel.Init();  //Initialize controller and start web banner timer
  ReefAngel.Timer[4].SetInterval(180);  // set interval to 180 seconds
  ReefAngel.Timer[4].Start();
  ReefAngel.FeedingModePorts = B00110000;
  ReefAngel.WaterChangePorts = B10110000;
//  ReefAngel.OverheatShutoffPorts = B00000111;
//  ReefAngel.LightsOnPorts = B00001100;
  ReefAngel.Relay.On(Port5);
  ReefAngel.Timer[1].SetInterval(InternalMemory.WM1Timer_read());
  ReefAngel.Timer[1].Start();
  ReefAngel.Relay.On(Port7);
  // Specific functions
  //1st Heater at 78.8, 2nd Heater at 77.0, MH on at 10AM off at 8PM, Actinics on at 9AM off at 9PM, Fan kicks on at 82.0
  ReefAngel.StandardHeater(Port1,788,792);
  ReefAngel.StandardHeater(Port2,770,792);
  ReefAngel.MHLights(Port3,10,0,20,0,5);
  ReefAngel.StandardLights(Port4,9,0,21,0);
  ReefAngel.StandardFan(Port8,792,820);
  // Wavemaker Code with night option
  if (ReefAngel.Timer[1].IsTriggered() )
    if ((hour() >= 21) || (hour() <= 8)) //from 9p-Midnight
    {  //PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM,
       // byte endPWM, byte Duration, byte oldValue)
      wmpulse=PWMSlope(21,0,8,0,5,30,179,30);
      if (wmdelay)
        ReefAngel.Timer[1].SetInterval(wmpulse);  // WM delay function from 30-170 sec.
        ReefAngel.Relay.Off(Port5);
        ReefAngel.Relay.Off(Port6);
        if (wmport==Port5) wmport=Port6; else wmport=Port5;
        wmdelay=false;
        ReefAngel.Timer[1].SetInterval(200-wmpulse);  // WM bursts timing from 170-30 sec.
        ReefAngel.Relay.On(wmport);
        wmdelay=true;
      //8a-10p normal wave settings
      ReefAngel.Relay.Toggle(Port6);
  //Using Daylight ATO high signal piezo buzzer when temp exceeds 83F
  //other options are lowATOpin or the LED pins as ReefAngel.PWM.SetDaylight(100); else ReefAngel.PWM.SetDaylight(0);
if (ReefAngel.Params.Temp1>830)
  pinMode(highATOPin,OUTPUT);
  digitalWrite(highATOPin,HIGH);
  {pinMode(highATOPin,OUTPUT);
  digitalWrite(highATOPin,LOW);
    //Moonlight=byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
   ActinicPWMValue=PWMSlope(7,00,22,0,0,100,60,ActinicPWMValue);
   DaylightPWMValue=PWMSlope(7,00,22,0,0,100,60,DaylightPWMValue);
// Web Banner stuff
        ReefAngel.WebBanner();
      //receive Light readout
    Wire.requestFrom(9,1);
    if (Wire.available())
      flow=Wire.receive();
