Internal Mem Coding on and off help
Posted: Mon Apr 10, 2017 2:18 pm
by skehole
Hi all....first off, here's my code
ReefAngel.WaterChangePorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1 );
ReefAngel.Portal( "skehole" );
ReefAngel.DDNS( "fish tank" ); // Your DDNS is skehole-fish tank.myreefangel.com
On my currently unused relay 4 I would like to program my reefbrite to come on at 11am and off at 9pm. No ramping or nothing. Simply on and then off. Can someone assist me? TIA!
Re: Internal Mem Coding on and off help
Posted: Mon Apr 10, 2017 3:29 pm
Have you tried using the wizard?
Also, don't use a space on your DDNS.
It will mess up the communication with the portal.
Spaces are not part of the HTTP protocol.
Posted: Mon Apr 10, 2017 4:09 pm
by skehole
rimai wrote:Have you tried using the wizard?
I have not used the wizard, I was already running this and was wondering if there was a way to add in a line or whatever of code.
Yeah, I fixed that on my actual code. That was cut and pasted from the thread where we came to the same conclusion about the Ddns.
