Email Alert
Ask in here.
PostPosted: Thu May 18, 2017 12:31 pm
Ive searched and couldnt find a direct answer, or im too dense to see it. I am going out of the country and would like to set up immediate email alerts for things like: ATO timeout, Temp above/below threshold. Those are really the only two im concerned with at this point. Any help would be much appreciated.
Thanks in advance.
SLM
PostPosted: Fri Jun 02, 2017 5:49 am
It's in the Portal, under Portal Settings. Hope that helps.
PostPosted: Fri Jun 02, 2017 10:15 am
i also created an android app that let's you modify your portal alerts from the app. it only let's you add/edit/delete them. it doesn't display them if they occur.
just sharing this info.
PostPosted: Tue Jun 06, 2017 3:05 pm
I've done them in the portal, while it says sent I have never actually received one. I thought there was a way in the code to do it.
Return to How do I code ...
