- 1. Clarification that the Timeout (sec) option shuts down the pump after running that many seconds.
2. Assuming #1 is correct, how long does that timeout last by default?
Questions regarding Water Level ATO in the Wizard:
2. Assuming #1 is correct, how long does that timeout last by default? |
The ATO timeout is permanent until you clear it through the joystick or using any app.
Ok so my idea won't work... at least not the way I envisioned. I guess I can either try to program it as a dosing pump or just let it run with a long enough timeout to where if triggered, there has to be a problem. It shouldn't be an issue as the Spectrapure dosing pump I'm using is really designed for this application (at least it is marketed that way). |
You can always code it to reset the ATO timeout after a certain period of time
![]() Roberto.
