CO2Control - Relay on and Off all the time
PostPosted: Thu Jun 22, 2017 10:40 am
Hi there
I use the code ReefAngel.CO2Control(Port1,620,650); to control a solenoid valve attached to a CO2 cilinder.
The problem is that the PH reading fluctuat a little bit, so the Port1 relay keep's getting On and Off in matter of seconds. I am afraid it can damage the solenoid valve.
Is there a way to prevent that from happening? I dont know.. maybe after X seconds above 650 just then get relay On.
Best regards
Rafa
PostPosted: Fri Jun 23, 2017 11:06 am
You would have to create your own code.
Maybe something like this:
static unsigned long lastmillis=millis();
static enablesolenoid=false;
if (ReefAngel.Params.PH>650 && !enablesolenoid)
  enablesolenoid=true;
if (ReefAngel.Params.PH<620) enablesolenoid=false;
ReefAngel.Relay.Set(Port1,enablesolenoid);
if (millis()-lastmillis<5000) ReefAngel.Relay.Off(Port1);
PostPosted: Fri Jun 23, 2017 6:47 pm
Obrigado Roberto!
That's what I was thinking.
Best regards
Rafa
Return to How do I code ...
