New computer
PostPosted: Mon Jul 03, 2017 7:26 pm
Got a new laptop how do I get the coding off my Reef angel plus to be saved on my new laptop
PostPosted: Mon Jul 03, 2017 7:40 pm
You are unable to extract code from the controller to be saved. Once it's on the controller, it cannot come off of it.
You will need to pull the INO files off of the old laptop and then migrate over to the new one or re-create your INO file.
PostPosted: Tue Jul 04, 2017 7:27 am
I guess I am out of luck - Old computer crashed and hard drive had to be reformatted-
PostPosted: Tue Jul 04, 2017 7:48 am
Trying to write in the sketch box and I am just hearing beeps. What is the issue?
PostPosted: Tue Jul 04, 2017 11:18 am
palmer wrote:Trying to write in the sketch box and I am just hearing beeps. What is the issue?
You could have the Preference set to "Use external editor". If that's set, then the sketch screen is grayed out and you cannot type in it.
PostPosted: Sat Jul 08, 2017 3:47 pm
I am getting nothing trying to connect to my controller with new computer for days .
this is what i am getting
java.io.FileNotFoundException: /Users/palmer/Documents/Arduino/update/feature.txt (No such file or directory)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:120)
at java.io.FileInputStream.<init>(FileInputStream.java:79)
at java.io.FileReader.<init>(FileReader.java:41)
at processing.app.Sketch.ProcessFeature(Sketch.java:1373)
at processing.app.Sketch.build(Sketch.java:1766)
at processing.app.Sketch.build(Sketch.java:1750)
at processing.app.Editor$DefaultRunHandler.run(Editor.java:1867)
at java.lang.Thread.run(Thread.java:695)
Standard Menu
java.io.IOException: No such file or directory
at java.io.UnixFileSystem.createFileExclusively(Native Method)
at java.io.File.checkAndCreate(File.java:1705)
at java.io.File.createTempFile0(File.java:1726)
at java.io.File.createTempFile(File.java:1803)
at processing.app.Base.saveFile(Base.java:2189)
at processing.app.Sketch.ProcessFeature(Sketch.java:1456)
sketch_jul08a:2: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:3: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:4: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:6: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:8: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:10: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:12: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:14: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:15: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:17: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:20: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:21: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:22: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:28: error: expected declaration before '}' token
PostPosted: Sat Jul 08, 2017 3:57 pm
You don't have the correct files in the proper place.
Make sure to install the Reef Angel Installer from the download page.
Is it a windows machine?
What do you have inside /Users/palmer/Documents/Arduino?
PostPosted: Sat Jul 08, 2017 7:04 pm
its a macbook pro with Sierra- I downloaded the reef angel installer from the download page
PostPosted: Sat Jul 08, 2017 7:07 pm
in that folder i have a sketch named sketch_jul04.ino which is what i cut and pasted above
PostPosted: Sat Jul 08, 2017 7:09 pm
Did you move the Arduino folder to your Documents folder?
Please check the manual for instructions on how to install it on the Mac.
Next
Return to How do I code ...
