New computer
Posted: Mon Jul 03, 2017 7:26 pm
by palmer
Got a new laptop how do I get the coding off my Reef angel plus to be saved on my new laptop
Re: New computer
Posted: Mon Jul 03, 2017 7:40 pm
by binder
You are unable to extract code from the controller to be saved. Once it's on the controller, it cannot come off of it.
You will need to pull the INO files off of the old laptop and then migrate over to the new one or re-create your INO file.
Re: New computer
Posted: Tue Jul 04, 2017 7:27 am
by palmer
I guess I am out of luck - Old computer crashed and hard drive had to be reformatted-
Re: New computer
Posted: Tue Jul 04, 2017 7:48 am
by palmer
Trying to write in the sketch box and I am just hearing beeps. What is the issue?
Re: New computer
Posted: Tue Jul 04, 2017 11:18 am
by binder
palmer wrote:Trying to write in the sketch box and I am just hearing beeps. What is the issue?
You could have the Preference set to "Use external editor". If that's set, then the sketch screen is grayed out and you cannot type in it.
Re: New computer
Posted: Sat Jul 08, 2017 3:47 pm
by palmer
I am getting nothing trying to connect to my controller with new computer for days .
this is what i am getting
java.io.FileNotFoundException: /Users/palmer/Documents/Arduino/update/feature.txt (No such file or directory)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:120)
at java.io.FileInputStream.<init>(FileInputStream.java:79)
at java.io.FileReader.<init>(FileReader.java:41)
at processing.app.Sketch.ProcessFeature(Sketch.java:1373)
at processing.app.Sketch.build(Sketch.java:1766)
at processing.app.Sketch.build(Sketch.java:1750)
at processing.app.Editor$DefaultRunHandler.run(Editor.java:1867)
at java.lang.Thread.run(Thread.java:695)
Standard Menu
java.io.IOException: No such file or directory
at java.io.UnixFileSystem.createFileExclusively(Native Method)
at java.io.File.checkAndCreate(File.java:1705)
at java.io.File.createTempFile0(File.java:1726)
at java.io.File.createTempFile(File.java:1803)
at processing.app.Base.saveFile(Base.java:2189)
at processing.app.Sketch.ProcessFeature(Sketch.java:1456)
sketch_jul08a:2: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:3: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:4: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:6: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:8: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:10: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:12: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:14: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:15: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:17: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:20: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:21: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:22: error: expected constructor, destructor, or type conversion before '.' token
sketch_jul08a:28: error: expected declaration before '}' token
Re: New computer
Posted: Sat Jul 08, 2017 3:57 pm
You don't have the correct files in the proper place.
Make sure to install the Reef Angel Installer from the download page.
Is it a windows machine?
What do you have inside /Users/palmer/Documents/Arduino?
Re: New computer
Posted: Sat Jul 08, 2017 7:04 pm
by palmer
its a macbook pro with Sierra- I downloaded the reef angel installer from the download page
Re: New computer
Posted: Sat Jul 08, 2017 7:07 pm
by palmer
in that folder i have a sketch named sketch_jul04.ino which is what i cut and pasted above
Re: New computer
Posted: Sat Jul 08, 2017 7:09 pm
Did you move the Arduino folder to your Documents folder?
Please check the manual for instructions on how to install it on the Mac.
Re: New computer
Posted: Sun Jul 09, 2017 6:05 am
by palmer
ok did as suggested now it looks connected and I ran the restart example code to test and it did restart-
when I tried another example code CustomMainScreen I got this
avrdude: stk500_recv(): programmer is not responding
and a reference of problem uploading to board
Re: New computer
Posted: Sun Jul 09, 2017 6:40 am
by palmer
SUCCESS! FInally thanks -
Since I code is now erased I have to go back and find the code to label the ports on the screen
