if and coding on RA
PostPosted: Fri Jul 14, 2017 7:59 pm
Im trying to code my skimmer as follows: How to combine this statement
Essentially, I want the skimmer to turn off whenever ATO low trips. I also want the skimmer to turn off when my return pump is off. I want to put a 3 min delay on both sides. Thanks for the help
ReefAngel.Relay.Set(Box1_Port3,ReefAngel.Relay.Status(Port6)); // 11 Skimmer
ReefAngel.SingleATOLow(true,Port5,900,0 ); // 5 ATO - RODI
PostPosted: Sat Jul 15, 2017 9:12 am
Try this:
if (ReefAngel.LowATO.IsActive()) ReefAnel.Relay.Off(Box1_Port3);
PostPosted: Sat Jul 15, 2017 10:19 am
So I will execute this as 3 separate statements right.
Didn't know that could work. Figured one would override the other
PostPosted: Sat Jul 15, 2017 12:08 pm
Yeap. That what you want to do.
You want to override the skimmer function if low ato is triggered.
PostPosted: Sat Jul 15, 2017 12:17 pm
Last question. So my main ato is fumctionjng with
The reefangel.singleAto function (plugged into low ato )
This one will operate skimmer and use high ato. For trigger.
Do you see any concerns ? Also wanted to put a 3 min delay on skimmer when return pump is turned back on
PostPosted: Sat Jul 15, 2017 4:53 pm
So the code works and turns of the skimmer. But it doesn't turn it back on. How can I make that happen after the high ato is cleared
PostPosted: Sat Jul 15, 2017 5:28 pm
Are you sure Port6 was on?
Return to How do I code ...
