Skimmer Code Help
Ask in here.
PostPosted: Fri Aug 25, 2017 3:59 pm
Can someone please help me combine these statements
ReefAngel.Relay.DelayedOn( Box1_Port3,0 ); //Skimmer
// if ( ReefAngel.HighATO.IsActive() == 0 ) ReefAngel.Relay.Off( Box1_Port3 );
if ( ReefAngel.Relay.Status( Port6 ) ) ReefAngel.Relay.Off( Box1_Port3 );
when this code is used... the skimmer never turns on.... (I've toggled between 1 and 0 on the isactive () command)
any help would be great. trying to setup a multi layered condition where if the return pump is off or ATO High is triggered (skim bucket) then skimmer is off else on. Also on all restarts it waits 2 mins to kick on (I have it set to 0 for testing)
PostPosted: Fri Sep 01, 2017 9:35 am
Bump
PostPosted: Fri Sep 01, 2017 9:53 am
Probably because port 6 is on and it is turning off box1_port.
If you do two statements, the last one will always overwrite any previous condition. You need to make it into one statement.
PostPosted: Fri Sep 01, 2017 1:50 pm
if ( ReefAngel.HighATO.IsActive() == 0 || !ReefAngel.Relay.Status(Port6) ) {
} else {
Return to How do I code ...
