pH control linked to water level and timed safety
PostPosted: Mon Sep 11, 2017 2:20 pm
If i wanted to only dose the kalk for 2.5 minutes every 30 minutes, i just change the code above from 1800<150?
PostPosted: Mon Sep 11, 2017 3:09 pm
Yeap
PostPosted: Mon Sep 11, 2017 3:26 pm
Thank you
PostPosted: Mon Sep 11, 2017 4:37 pm
Take out or comment the line that has the original PHControl statement so you dont get confused later :) You can comment it with a // in front.
PostPosted: Tue Sep 12, 2017 11:00 am
Like I keep saying, I am too stupid for this.
    ReefAngel.SetTemperatureUnit( Celsius );  // set to Celsius Temperature
    ReefAngel.AddWaterLevelExpansion();  // Water Level Expansion Module
    ReefAngel.FeedingModePorts = Port3Bit | Port8Bit;
    ReefAngel.FeedingModePortsE[0] = Port1Bit | Port2Bit | Port4Bit | Port5Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit;
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port4Bit | Port5Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit | Port8Bit;
    ReefAngel.PHControl( Port2,819,822 );
    ReefAngel.Relay.DelayedOn( Port3,2 );
    ReefAngel.StandardLights( Port4,9,0,19,0 );
    ReefAngel.Relay.DelayedOn( Port5,1 );
    ReefAngel.WaterLevelATO( Port6,225,44,46 );
    ReefAngel.StandardHeater( Port7,255,265 );
    ReefAngel.Relay.DelayedOn( Port8,1 );
    ReefAngel.Relay.DelayedOn( Box1_Port4,1 );
 if (now%3600<600) {ReefAngel.PHControl(...);} else {
  ReefAngel.Relay.Off(Port2);
    ReefAngel.Portal( "Irieivan" );
And when I try to upload, I get an error:
invalid operands of type time_t00'and'init' to binary'operator%'
PostPosted: Tue Sep 12, 2017 11:29 am
When I replace the (...) in the suggested code with my pH control values, I get the same error
PostPosted: Tue Sep 12, 2017 12:09 pm
I think there is a typo.
It should be now() and not just now
PostPosted: Tue Sep 12, 2017 1:05 pm
if (now(%3600<600) {
ReefAngel.PHControl(Port2,819,822);
} else {
Error again:
Expected primary expression before'%' token
PostPosted: Tue Sep 12, 2017 1:10 pm
It's now() and not now(
PostPosted: Tue Sep 12, 2017 1:11 pm
Ok got it figured out thanks
Previous
Return to How do I code ...
