Seasonal Temperatures
PostPosted: Sat Oct 14, 2017 11:13 am
Reefology wrote:I have one set of lights. I use pwm channels for the same lights because they dim down low but won't shut down completely unless they are plugged into the relay box. I would like to use those ports for something else, is there a way to shut them down with the pwm alone?
Often times if you set the PWM value to 0, it will shut the lights off. My old set of LED's would only dim down to like 20% and then I had to set them to 0 to get them to shut off.
I would suggest testing out setting the pwm value to 0 for the channels to see if that shuts the light off completely. If it does, then your problem is solved and we can just set the value to 0 to shut off the lights completely and you will be able to plug the power supplies into a regular outlet and not one of the RA outlets. If it does not shut off the lights completely, then you will need to toggle the port to shut off the lights like you are currently doing.
PostPosted: Sat Oct 14, 2017 11:23 am
I think I've been doing that all along, the portal indicates 0%, but the lights stay very low when plugged into regular outlet.
PostPosted: Sat Oct 14, 2017 11:25 am
btw, thanks for helping me with this Curt, really appreciate it!
PostPosted: Sat Oct 14, 2017 11:54 am
Ok. With that being said, you will probably need to continue doing the relay toggling. Here's some code for you to test out. I have it toggling the relay port and put a comment in about removing the line if you didn't need to toggle the port. Also, I have the outlets turn on at the specified times in the arrays and the lights start to slope up/down appropriately. The slope values / percentages are based off of the internal memory values BUT could be changed and handled in the code if you wanted to (it would be pretty simple actually).
Just so you know, I just copied the code for the PWM slope function and tweaked it so it could be controlled manually outside of the libraries.
Anyways, here's the code. I know it compiles against the libraries version 1.1.3. I just tested the compile but I have not uploaded it to a controller to test out everything fully. The only thing that I changed was the code for the lights. So, you will want to verify that the times used for the lights are what you want.
void SeasonalDaylight ()
  static int daylightArray[][4] = {
    {13,0,22,0},  // default in case of error in month=0 (May)
    {15,0,22,0},  //January (winter)
    {14,30,22,0}, //February (winter)
    {14,0,22,0},  //March (early spring)
    {13,30,22,0}, //April (spring)
    {13,0,22,0},  //May (spring)
    {12,30,22,0}, //June (early summer)
    {12,0,22,0},  //July (summer)
    {12,30,22,0}, //August (summer)
    {13,0,22,0},  //September (early fall)
    {13,30,22,0}, //October (fall)
    {14,0,22,0},  //November (fall)
    {14,30,22,0}  //December (early winter)
  // Port 2 is power supply for Day lights
  ReefAngel.PWM.SetDaylightRaw(PWMSlopeHighRes(
    daylightArray[month()][0],
    daylightArray[month()][1],
    daylightArray[month()][2],
    daylightArray[month()][3],
    InternalMemory.PWMSlopeStartD_read(),
    InternalMemory.PWMSlopeEndD_read(),
    InternalMemory.PWMSlopeDurationD_read(),
    ReefAngel.PWM.GetDaylightValueRaw()
  TODO comment out the next line if the power supply for the lights is not needed
       and the lights are plugged into a power strip. Otherwise, if the lights
       are plugged into the relay, you will need to toggle the port to turn
       the lights off
  ReefAngel.StandardLights(Port2, daylightArray[month()][0], daylightArray[month()][1],
                                  daylightArray[month()][2], daylightArray[month()][3]);
}//end SeasonalDaylight
void SeasonalActiniclight ()
  static int actinicArray[][4] = {
    {12,30,22,30},  // default in case of error in month=0 (May)
    {14,30,22,30},  //January (winter)
    {14,0,22,30},   //February (winter)
    {13,30,22,30},  //March (early spring)
    {13,0,22,30},   //April (spring)
    {12,30,22,30},  //May (spring)
    {12,0,22,30},   //June (early summer)
    {11,30,22,30},  //July (summer)
    {12,0,22,30},   //August (summer)
    {12,30,22,30},  //September (early fall)
    {13,0,22,30},   //October (fall)
    {13,30,22,30},  //November (fall)
    {14,0,22,30}    //December (early winter)
  // Port 1 is power supply for Actinic Lights
  ReefAngel.PWM.SetActinicRaw(PWMSlopeHighRes(
    actinicArray[month()][0],
    actinicArray[month()][1],
    actinicArray[month()][2],
    actinicArray[month()][3],
    InternalMemory.PWMSlopeStartA_read(),
    InternalMemory.PWMSlopeEndA_read(),
    InternalMemory.PWMSlopeDurationA_read(),
    ReefAngel.PWM.GetActinicValueRaw()
       the lights off
  ReefAngel.StandardLights(Port1, actinicArray[month()][0], actinicArray[month()][1],
                                  actinicArray[month()][2], actinicArray[month()][3]);
}//end SeasonalActinics
    InternalMemory.LCDID_write(0); //this line was added when i got a replacement RA+ board
    ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
    ReefAngel.Relay.On( Port4 );
    //ReefAngel.ActinicLights( Port1 );
    //ReefAngel.DayLights( Port2 );
    // Light code
    SeasonalDaylight();
    SeasonalActiniclight();
    ReefAngel.Relay.DelayedOn(Port5 );
    ReefAngel.DosingPumpRepeat1( Port7 );
    ReefAngel.DosingPumpRepeat2( Port8 );
    //ReefAngel.PWM.DaylightPWMSlope();
    //ReefAngel.PWM.ActinicPWMSlope();
    ReefAngel.DCPump.LowATOChannel = Sync; // WP40
    ReefAngel.DCPump.HighATOChannel = AntiSync; // SW-8
    ReefAngel.DCPump.AntiSyncOffset = 125;
    // Wavemaker
    if ( ((hour() >= 2) && (hour() < 8)) || ((hour() >= 15) && (hour() < 19)) ) // off from 2am-8am & 3pm-7pm
        ReefAngel.Relay.Off(Port6);
        ReefAngel.WavemakerRandom( Port6, 30, 150 ); // random between 30 and 150 seconds
    // DC pumps....................................
    static int rmode;
    byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, Else, Gyre, NutrientTransport };
    if (now()%1800==0 || changeMode==true)  // Change every 30 mins (1800seconds) or controller reboot
    rmode=random(100)%sizeof(modes); // Change the mode by picking from our array
    changeMode=false;
    static unsigned long feeding;
    // Continue NutrientTranspot Mode for 30 minutes after feeding
    if (now()-feeding<1800)
    ReefAngel.DCPump.Mode=ReefCrest;
    ReefAngel.DCPump.Speed=75;
    // Night/Quiet mode
      else if (hour()>=2 && hour()<8 ) // 2am to 8am
    ReefAngel.DCPump.SetMode( Gyre,40,10 );
      else if (hour()>=15 && hour()<19) // 3pm and 7pm
    ReefAngel.DCPump.SetMode( ShortPulse,40,30 );
    //Storm mode
    else if (hour()>=1 && hour()<2) // 1am and 2am
    ReefAngel.DCPump.SetMode( Else,70,15 );
      else if (hour()>=11 && hour()<12) // 11am and 12pm
    ReefAngel.DCPump.SetMode( ReefCrest,80,15 );
    else if (InternalMemory.DCPumpMode_read()==11)
    ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :)
    } else {
    ReefAngel.Portal( "" );
    ReefAngel.DDNS( "" ); // Your DDNS is
Hopefully everything makes sense to you. If you need to alter any of the times, you should be able to figure it out from the code (arrays). This code also allows for both the Actinic and Daylight channels to be controlled independently. We could simplify things if they always used the same schedule OR if they were always 30 minutes (or whatever time offset) apart.
Let me know if you have any further questions or comments.
PostPosted: Sat Oct 14, 2017 12:54 pm
that looks great Curt, I'll give it a try.
I do have a questions though:
how does the controller use the default month? and why do we need it?
{774,778},// default in case of error in month=0 (May)
thanks a bunch!
PostPosted: Sat Oct 14, 2017 5:55 pm
that's added in for 2 reasons: 1) on the off chance the controller gets a 0 returned when it calls the month function, which should never happen since there's not a month 0 but you never know (so it's a sanity check) 2) the month function returns a value between 1 and 12 inclusive. arrays in c/c++ always start with an index of zero. since there's not a zero month, in order for the months to match up with the indices, you would either have to subtract 1 from the month function call (which there is lots of them) or you pad the array (like we did). either option would work, however our option would result in less instructions/operations being called and it's a simple index to the array. it can also yield a little easier to read code as well.
so the default values should never be used but are there just in case. hopefully this explanation makes sense.
Previous
Return to How do I code ...
