Posts: 2751 Joined: Fri Mar 18, 2011 6:20 pm Location: Illinois
 Posted: Sat Oct 14, 2017 11:54 am
Ok. With that being said, you will probably need to continue doing the relay toggling. Here's some code for you to test out. I have it toggling the relay port and put a comment in about removing the line if you didn't need to toggle the port. Also, I have the outlets turn on at the specified times in the arrays and the lights start to slope up/down appropriately. The slope values / percentages are based off of the internal memory values BUT could be changed and handled in the code if you wanted to (it would be pretty simple actually). Just so you know, I just copied the code for the PWM slope function and tweaked it so it could be controlled manually outside of the libraries. Anyways, here's the code. I know it compiles against the libraries version 1.1.3. I just tested the compile but I have not uploaded it to a controller to test out everything fully. The only thing that I changed was the code for the lights. So, you will want to verify that the times used for the lights are what you want. - Code: Select all
#include <ReefAngel_Features.h> #include <Globals.h> #include <RA_Wifi.h> #include <Wire.h> #include <OneWire.h> #include <Time.h> #include <DS1307RTC.h> #include <InternalEEPROM.h> #include <RA_NokiaLCD.h> #include <RA_ATO.h> #include <RA_Joystick.h> #include <LED.h> #include <RA_TempSensor.h> #include <Relay.h> #include <RA_PWM.h> #include <Timer.h> #include <Memory.h> #include <InternalEEPROM.h> #include <RA_Colors.h> #include <RA_CustomColors.h> #include <Salinity.h> #include <RF.h> #include <IO.h> #include <ORP.h> #include <AI.h> #include <PH.h> #include <WaterLevel.h> #include <Humidity.h> #include <DCPump.h> #include <PAR.h> #include <ReefAngel.h>
void SeasonalDaylight () { static int daylightArray[][4] = { {13,0,22,0}, // default in case of error in month=0 (May) {15,0,22,0}, //January (winter) {14,30,22,0}, //February (winter) {14,0,22,0}, //March (early spring) {13,30,22,0}, //April (spring) {13,0,22,0}, //May (spring) {12,30,22,0}, //June (early summer) {12,0,22,0}, //July (summer) {12,30,22,0}, //August (summer) {13,0,22,0}, //September (early fall) {13,30,22,0}, //October (fall) {14,0,22,0}, //November (fall) {14,30,22,0} //December (early winter) };
// Port 2 is power supply for Day lights ReefAngel.PWM.SetDaylightRaw(PWMSlopeHighRes( daylightArray[month()][0], daylightArray[month()][1], daylightArray[month()][2], daylightArray[month()][3], InternalMemory.PWMSlopeStartD_read(), InternalMemory.PWMSlopeEndD_read(), InternalMemory.PWMSlopeDurationD_read(), ReefAngel.PWM.GetDaylightValueRaw() )); /* TODO comment out the next line if the power supply for the lights is not needed and the lights are plugged into a power strip. Otherwise, if the lights are plugged into the relay, you will need to toggle the port to turn the lights off */ ReefAngel.StandardLights(Port2, daylightArray[month()][0], daylightArray[month()][1], daylightArray[month()][2], daylightArray[month()][3]); }//end SeasonalDaylight
void SeasonalActiniclight () { static int actinicArray[][4] = { {12,30,22,30}, // default in case of error in month=0 (May) {14,30,22,30}, //January (winter) {14,0,22,30}, //February (winter) {13,30,22,30}, //March (early spring) {13,0,22,30}, //April (spring) {12,30,22,30}, //May (spring) {12,0,22,30}, //June (early summer) {11,30,22,30}, //July (summer) {12,0,22,30}, //August (summer) {12,30,22,30}, //September (early fall) {13,0,22,30}, //October (fall) {13,30,22,30}, //November (fall) {14,0,22,30} //December (early winter) };
// Port 1 is power supply for Actinic Lights ReefAngel.PWM.SetActinicRaw(PWMSlopeHighRes( actinicArray[month()][0], actinicArray[month()][1], actinicArray[month()][2], actinicArray[month()][3], InternalMemory.PWMSlopeStartA_read(), InternalMemory.PWMSlopeEndA_read(), InternalMemory.PWMSlopeDurationA_read(), ReefAngel.PWM.GetActinicValueRaw() )); /* TODO comment out the next line if the power supply for the lights is not needed and the lights are plugged into a power strip. Otherwise, if the lights are plugged into the relay, you will need to toggle the port to turn the lights off */ ReefAngel.StandardLights(Port1, actinicArray[month()][0], actinicArray[month()][1], actinicArray[month()][2], actinicArray[month()][3]); }//end SeasonalActinics
void setup() { // This must be the first line InternalMemory.LCDID_write(0); //this line was added when i got a replacement RA+ board ReefAngel.Init(); //Initialize controller ReefAngel.Use2014Screen(); // Let's use 2014 Screen // Ports toggled in Feeding Mode ReefAngel.FeedingModePorts = Port5Bit | Port6Bit; // Ports toggled in Water Change Mode ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit; // Ports toggled when Lights On / Off menu entry selected ReefAngel.LightsOnPorts = Port1Bit | Port2Bit; // Ports turned off when Overheat temperature exceeded ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit; // Use T1 probe as temperature and overheat functions ReefAngel.TempProbe = T1_PROBE; ReefAngel.OverheatProbe = T1_PROBE;
// Feeeding and Water Change mode speed ReefAngel.DCPump.FeedingSpeed=0; ReefAngel.DCPump.WaterChangeSpeed=0;
// Ports that are always on ReefAngel.Relay.On( Port4 );
////// Place additional initialization code above here }
void loop() { //ReefAngel.ActinicLights( Port1 ); //ReefAngel.DayLights( Port2 ); // Light code SeasonalDaylight(); SeasonalActiniclight();
ReefAngel.StandardHeater( Port3 ); ReefAngel.Relay.DelayedOn(Port5 ); ReefAngel.DosingPumpRepeat1( Port7 ); ReefAngel.DosingPumpRepeat2( Port8 ); //ReefAngel.PWM.DaylightPWMSlope(); //ReefAngel.PWM.ActinicPWMSlope(); ReefAngel.DCPump.LowATOChannel = Sync; // WP40 ReefAngel.DCPump.HighATOChannel = AntiSync; // SW-8 ReefAngel.DCPump.AntiSyncOffset = 125;
// Wavemaker
if ( ((hour() >= 2) && (hour() < 8)) || ((hour() >= 15) && (hour() < 19)) ) // off from 2am-8am & 3pm-7pm { ReefAngel.Relay.Off(Port6); } else { ReefAngel.WavemakerRandom( Port6, 30, 150 ); // random between 30 and 150 seconds }
// DC pumps.................................... static int rmode; static boolean changeMode=true;
// These are the modes we can cycle through. You can add more and even repeat... byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, Else, Gyre, NutrientTransport };
if (now()%1800==0 || changeMode==true) // Change every 30 mins (1800seconds) or controller reboot { rmode=random(100)%sizeof(modes); // Change the mode by picking from our array changeMode=false; }
// Set timer when in feeding mode static unsigned long feeding; if (ReefAngel.DisplayedMenu==FEEDING_MODE) feeding=now();
// Continue NutrientTranspot Mode for 30 minutes after feeding if (now()-feeding<1800) { ReefAngel.DCPump.UseMemory=false; ReefAngel.DCPump.Duration=InternalMemory.DCPumpDuration_read(); ReefAngel.DCPump.Mode=ReefCrest; ReefAngel.DCPump.Speed=75; }
// Night/Quiet mode else if (hour()>=2 && hour()<8 ) // 2am to 8am { ReefAngel.DCPump.UseMemory=false; ReefAngel.DCPump.SetMode( Gyre,40,10 ); } else if (hour()>=15 && hour()<19) // 3pm and 7pm { ReefAngel.DCPump.UseMemory=false; ReefAngel.DCPump.SetMode( ShortPulse,40,30 ); }
//Storm mode else if (hour()>=1 && hour()<2) // 1am and 2am { ReefAngel.DCPump.UseMemory=false; ReefAngel.DCPump.SetMode( Else,70,15 ); } else if (hour()>=11 && hour()<12) // 11am and 12pm { ReefAngel.DCPump.UseMemory=false; ReefAngel.DCPump.SetMode( ReefCrest,80,15 ); }
// Custom Mode and nothing else going on else if (InternalMemory.DCPumpMode_read()==11) { ReefAngel.DCPump.UseMemory=false; ReefAngel.DCPump.Duration=InternalMemory.DCPumpDuration_read(); ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :) ReefAngel.DCPump.Speed=InternalMemory.DCPumpSpeed_read(); // Set speed from portal } else { ReefAngel.DCPump.UseMemory=true; // Will reset all values from memory } ////// Place your custom code above here
// This should always be the last line ReefAngel.Portal( "" ); ReefAngel.DDNS( "" ); // Your DDNS is ReefAngel.ShowInterface(); }
Hopefully everything makes sense to you. If you need to alter any of the times, you should be able to figure it out from the code (arrays). This code also allows for both the Actinic and Daylight channels to be controlled independently. We could simplify things if they always used the same schedule OR if they were always 30 minutes (or whatever time offset) apart. Let me know if you have any further questions or comments.
