Delay Ato switch
PostPosted: Wed Jan 31, 2018 4:29 am
by anderzon_
Is it possible to add a delay for a couple of hours after the float swich has become active? The reason is that the float swtich stands and bumps a bit in when it is on the edge of unloading witch causing my solenoid to open and close many time before it stands open and fill up water. Im running on single low switch.
